Should i upgrade my power cord on my high current amp? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-31-2012, 01:02 AM - Thread Starter
smfins's Avatar
Quoted: 36 Post(s)
I just purchased a used parasound HCA 2205a that weighs about 95 pounds and draws alot of current. I noticed that in my opinion it has a pretty skinny power cable that looks more like something you would see on a computer. I'm not sure if it's the original cord or not, but should i look into upgrading it? i see some on ebay for around $50 that seem to be much better. I';ve also read on many forums that upgrading the power cord is a waste of time??? Any advise? Thanks!
smfins is offline
post #2 of 5 Old 05-31-2012, 01:44 AM
Roger Dressler's Avatar
Quoted: 1523 Post(s)
Liked: 710
^^ If the amp is not clipping, it seems to be doing the job. But if the cord is not rated to at least the same as the current draw spec of the amp, would be good to find a better match.
Your amp states power consumption at 1500w. That's 12.5 amps at 120 V. 15A cords are readily available for $5-10. First, check to see the rating of the cord you're using. Just have a look at the end that plugs into the amp. The current rating will be molded into it.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #3 of 5 Old 05-31-2012, 07:00 AM
Michael Sargent's Avatar
Quoted: 179 Post(s)
Liked: 164
Run the amp at a fairly high volume for 1/2 an hour or so. Then feel the power cord (don't forget both ends). If it feels warm to the touch anywhere, you might want to consider a better cord. Otherwise, save your money.
Mike
Michael Sargent is offline
post #4 of 5 Old 05-31-2012, 07:32 AM
commsysman's Avatar
Quoted: 970 Post(s)
Liked: 523
The wire gauge of the cord should be molded into the surface of the cord. It should be #14 or #12 for your amplifier. Many cords are 16 gauge, which is probably marginal.
commsysman is offline
post #5 of 5 Old 06-09-2012, 12:33 AM - Thread Starter
smfins's Avatar
Quoted: 36 Post(s)
Thanks for the info, however, the amp rating isn't molded on the plug. it seems to be fine though.
smfins is offline
