Size of receivers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-31-2012, 04:27 PM - Thread Starter
taolit's Avatar
Can someone tell me what is the largest, as well as the most common, height size of new receivers? I'm going to build a flexy stand that will go underneath my TV and need to know what room to leave for a receiver. Most likely, the tallest item will be the center speaker, but I just wanted to make sure.
I've done a few searches on AVS for sizes of receivers, but I couldn't find anything quick and specific enough without going through lots of threads.
taolit is offline
post #2 of 11 Old 06-01-2012, 06:30 AM
jdsmoothie's Avatar
Quoted: 15354 Post(s)
Liked: 7508
Can't speak for other brands, but Denon AVRs < $2000 are generally 6-7" in height. You'll want at least 3"-4" clearance on top for proper ventilation so the shelf height should be at least 10"-11". If fully enclosed you may also want to consider adding a small USB fan that can exhaust the warm air from a hole in the back of the stand.
jdsmoothie is online now
post #3 of 11 Old 06-01-2012, 10:24 AM
turbobuick86's Avatar
http://usa.yamaha.com/products/audio...9_66063_66062_
Old bookmark, but most manufacturers websites list the dimensions.
turbobuick86 is offline
post #4 of 11 Old 06-01-2012, 11:06 AM
chikoo's Avatar
Design it with center channel in vertical position. I am running my CC vertically and really enjoying the SQ.
chikoo is offline
post #5 of 11 Old 06-01-2012, 12:17 PM
mogorf's Avatar
Quoted: 1127 Post(s)
Liked: 723
Hi taolit,
Please be double careful when planning room for your AVR. FYR, here's my experience:
As you can see I also planned room (2.5") for ventilation above my Denon:
But after about 1.5 years the side lamination of the shelf above the Denon started to loosen up although Denons are not notoriously known to be thermal power plants, nonetheless this is what happened on my side:
I also have shelves under the TV for other components; please feel free to visit my setup (link in my sig line) for a quick look-around.
mogorf is online now
post #6 of 11 Old 06-01-2012, 05:45 PM
Stutz320's Avatar
http://www.crutchfield.com/g_10420/H...ers.html?avf=N
click on a brand and then model then click details
Stutz320 is offline
post #7 of 11 Old 06-01-2012, 07:43 PM
YeuEmMaiMai's Avatar
Originally Posted by mogorf View Post
Hi taolit,
I had my yamaha on a wood coffie table's bottom shelf for 10 years and never seen heat damage let alone anything like that
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #8 of 11 Old 06-02-2012, 10:43 AM - Thread Starter
taolit's Avatar
Thanks for the size and ventilation heights. I'll check out the links, too. I've decided my flexy stand will be 24 inches tall, with a bottom, middle, and the top for tv. It looks like the receiver and center speaker will go on the same middle shelf (for the 11" height), unless I design the stand with separations in the middle shelf for height variations. I'm going to use the steel rods and nuts idea and cover them with pvc pipe, that way the stand can be very open for ventilation.
Mogorf, that's amazing what that receiver did. I'll definitely keep that in mind, since I am considering using front attachments to the wood.
taolit is offline
post #9 of 11 Old 06-02-2012, 11:34 AM
gregzoll's Avatar
Liked: 33
Actually had nothing to do with the heat from the avrs in the picture. What happened most likely was that the contact cement was not properly applied, or there was dust in that spot. Basically poor workmanship that can be fixed with just a little effort. Definitely not caused by the heat of the avrs.
gregzoll is offline
post #10 of 11 Old 06-02-2012, 11:52 AM
Ross Ridge's Avatar
Liked: 81
Or maybe they just used some sort of adhesive that melts when heated.
Ross Ridge is offline
post #11 of 11 Old 06-02-2012, 12:04 PM
gregzoll's Avatar
Liked: 33
That is usually what is on the cheaper veneers, but the heat from a avrs is not hot enough to cause what is being seen in the picture. If that was the case, the whole strip of veneer or the faces would have become unattached from the shelving.
gregzoll is offline
