Lexicon MC-8 low volume with one movie - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-01-2012, 02:32 AM - Thread Starter
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
Playing a movie last night on the HTPC and it was much lower in volume than the same file played back on the Oppo BD player (from USB stick)
Audio track
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 39mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 454 MiB (21%)
Language : Japanese
OS is Windows 7, media player is Media Player Home Cinema. Realtek onboard soundcard. Lexicon MC-8 av processor. In Logic 7 mode. I had to set to 00db.
Normally -20dB is correct level.
Playing the same movie from the other digital output (two feeds to two seperate systems) Yamaha RX-671 and that is fine.
Any ideas?
fatbottom is offline
