Denon AVR-888 audio issue... time to replace the reciever? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-06-2012, 06:56 PM - Thread Starter
gridbug's Avatar
It's happened twice so far. The left front speaker in my 5.1 system suddenly goes quiet. All other speakers and sub continue to work fine, and so far the only fix has been to turn the receiver off and on, at which point the problem is gone. Is this a sign of age? Could it be the speaker? Using Polk RM6750's and have not had any issues with them ever.
Any info would be appreciated... thanks!
gridbug is offline
post #2 of 5 Old 06-06-2012, 07:00 PM
jdsmoothie's Avatar
Quoted: 15345 Post(s)
Liked: 7501
If power cycling the AVR resolves the issue, it's not likely speaker related but confirm speaker wire is secure just in case. Try resetting the microprocessor on the AVR and see if that resolves the issue permanently. Note however, it will return all settings to factory default by doing so.
jdsmoothie is offline
post #3 of 5 Old 06-07-2012, 07:19 PM - Thread Starter
gridbug's Avatar
Thanks for the advice... it's only happened twice in about a month's time, so I'm not really sweating it much yet. Was thinking that at some point I'll probably switch it out for a new one, this one was a floor model bought during Circuit City's last gasps but it's lasted a good couple years. Been scouting for a potential replacement in my price point ( sub 500.00) but there don't seem to be many that have the outlets in the back like my AVR-888 does. Very handy for my bias lighting behind the display. Any replacement suggestions?
gridbug is offline
post #4 of 5 Old 06-07-2012, 07:34 PM
jdsmoothie's Avatar
Liked: 7501
The newer Denon models have dropped quite a few legacy analog inputs as well as the switch outlets, although these can be very easily replicated with a smart power strip. Aside from that, the best deal in your budget range would be a Denon AVR-2112CI or possibly 2312CI (maybe a bit more for this one), both of which can be had under your budget if you "call" around to a few authorized resellers. Review the Purchasing section in the link below.
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100#user_H
post #5 of 5 Old 06-07-2012, 07:57 PM - Thread Starter
gridbug's Avatar
Excellent, will check your links. Thanks!
gridbug is offline
