3312 surround sound problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-09-2012, 11:35 AM - Thread Starter
BBH49's Avatar
AVR3312CI surround sound encoding modes worked correctly since installation and now suddenly do not. For example with any of the DOLBY modes the audio is distorted and you cannot hear voices. Audio fine in multi-channel stereo mode. Resetting the Microprocessor and manual set-up does not correct the problem. ROKU and Apple TV2, both with separate HDMI connections have this problem. Is there a solution to this problem, or is the AVR3312CI defective?
BBH49 is offline
post #2 of 7 Old 06-09-2012, 12:13 PM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
Don't quite get what the problem is. Between installation and "now suddenly' was anything changed in your setup?
mogorf is offline
post #3 of 7 Old 06-09-2012, 12:35 PM - Thread Starter
BBH49's Avatar
No changes, worked fine one day, not the next. Have installed the upgrades to the AVR via the WEB as they come, but the problem did not occur immediately after an upgrade.
BBH49 is offline
post #4 of 7 Old 06-09-2012, 12:56 PM
80sGuy's Avatar
Quoted: 179 Post(s)
Liked: 34
Occasionally I've been experiencing the same problem with my 2310CI, but it usually works fine after a re-boot. Maybe blowing some compressed air might correct the problem?
80sGuy is offline
post #5 of 7 Old 06-09-2012, 01:08 PM
mogorf's Avatar
Liked: 613
You mean compressed air INTO THE HEADPHONE PLUG!
mogorf is offline
post #6 of 7 Old 06-10-2012, 12:50 PM - Thread Starter
BBH49's Avatar
Further research provided enlightenment! Dolby 5.1 (7.1) uses the center speaker for voice. Found that one of the center speaker wire terminals was dead. Changed center speaker and all OK, have both the sound track and voice. Thank you for the suggestions.smile.gif
BBH49 is offline
post #7 of 7 Old 06-10-2012, 12:53 PM
jdsmoothie's Avatar
Quoted: 12255 Post(s)
Liked: 5584
Great! For more help/information on your 3312CI join us in the dedicated Denon AVR-XX12 Owner's thread linked in my sig.
jdsmoothie is offline
