The "Official" Yamaha AVENTAGE RX-A1020, RX-A2020 and RX-A3020 Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 23Likes
post #541 of 2024 Old 03-28-2013, 11:03 AM
Ross Ridge's Avatar
Liked: 81
There is very little difference in the power of the two receivers. The reason to get the RX-A3010 over the RX-A2020 would be because it offers a better set of features. Notable improvements with the RX-A3010 are more video processing controls, rear presence speakers, upgraded DACs, a backlit remote and a second mini remote. The RX-A2020 has AirPlay as you noted.
Another option for getting AirPlay with the RX-A3010 would be to use an even cheaper AirPort Express, which could also double as a wireless gateway for your receiver.
Ross Ridge is offline
post #542 of 2024 Old 03-28-2013, 01:21 PM
Stepalex's Avatar
Originally Posted by Ross Ridge View Post
There is very little difference in the power of the two receivers. The reason to get the RX-A3010 over the RX-A2020 would be because it offers a better set of features. Notable improvements with the RX-A3010 are more video processing controls, rear presence speakers, upgraded DACs, a backlit remote and a second mini remote. .
Well, as far as remotes are concerned, I am leaning towards using the iOS app anyway. But where do you see 'upgraded DACs'? Can't find them in the specs.
Which would you choose between the two?
Stepalex is offline
post #543 of 2024 Old 03-28-2013, 01:40 PM
Ross Ridge's Avatar
Liked: 81
I'd get the RX-A3010 because I could use the second remote and have no use for AirPlay. Obviously you have much different priorities than me, so I can't really say which receiver you should get.
Hmm... I can't find anything to confirm that the RX-A3010 has different DACs than the RX-A2020, but the RX-A3000 definately had improved DACs over the the RX-A2000.
post #544 of 2024 Old 03-28-2013, 01:46 PM
SARHENTO's Avatar
Originally Posted by treetops View Post
Buying 2020 or 3020 in Canada:
Long time Canadian Yammy user located near Ottawa. Now need HDMI etc. Time for a new receiver, so:
1. Anyone out there who has priced the 2020 or 3020 in canada?
2. What prices and sources have you found?
3. Am I better to cross the border and buy from authorized US dealer?
4. How about a US self warranty job?
(I presume Yamaha Canada will not honor the warranty on US authorized dealer units?? So I would have to bring it south to do repairs.)
PS 1st posted in general receiver discussion by mistake
You should be able to purchase the A3020 for as low as $1550 in Canada. I got mine for that price 2 days ago.
SARHENTO is offline
post #545 of 2024 Old 03-29-2013, 12:33 AM
benw07's Avatar
Gurus, I have just purchased the a2020 (actually the RX-V2073). Airplay works great and I can see airplay content on TV.
BUT I am stumped on getting cable TV working. I have an HDMI input from cable box and then the HDMI out to the TV. But I get no sound and the video remains as the Yamaha screensaver.
I have read the manual cover to cover - cannot find a solution. Is my avr faulty? Or is there a hidden setting that i need to tweak?
benw07 is offline
post #546 of 2024 Old 03-29-2013, 01:17 AM
Chris England's Avatar
Originally Posted by kriktsemaj99 View Post
Did you install the latest firmware (version 1.41 that came out recently)? This fixed a problem with multi-point YPAO that could be causing what you describe. After updating I assume you'll have to run YPAO again.
As a test you could also run the single point YPAO (or disable YPAO competely) and see if your problem goes away. If it does, then try the new firmware and go back to multi-point YPAO.
Hi - thanks for you suggestions
I do have firmware 1.41 and have set up YPAO from this
I'll try the single point and pure direct and off etc and see what results I get
My local AV shop have also kindly offered to test the speaker for me in case it is damage of any kind - Sevenoaks are very helpful like that here in the UK
I'll report back after more tests
Chris England is offline
post #547 of 2024 Old 03-29-2013, 10:34 AM
theabs's Avatar
Originally Posted by jadziedzic View Post
Good price on the 3020 - was the purchase from an authorized dealer? If so, could you PM me with the seller details? There's an eBay seller with some 3020s for around that price, but it's a "self" warranty, which implies grey market to me.
I picked up an "open box" from One Call through Amazon for $1600, what came was a brand new, internally sealed in every way 3020.
theabs is offline
post #548 of 2024 Old 03-29-2013, 10:38 AM
Ross Ridge's Avatar
Liked: 81
It's not uncommon for AV receivers to have problems with cable and satellite boxes. You can try fiddling around with options on your cable box to see if it can be solved that way. You may end up having to running a digital optical or coaxial audio cable from the box to the receiver and either HDMI direct to the the TV or component to the receiver.
It could also be a cable problem, try switching the HDMI cables.
post #549 of 2024 Old 03-29-2013, 12:15 PM
jvinhj240's Avatar
Quoted: 38 Post(s)
I am ready to buy Yamaha RX-A3020. I am updating from Onkyo 1009. Nothing wrong with Onkyo, I just heard too many about Xt32. Can you guys give me some tips that I might look for this receiver?
Any problems?
What is a good price for this unit?
Pro/Con?
Appreciated all inputs. Thanks
jvinhj240 is offline
post #550 of 2024 Old 03-29-2013, 04:39 PM
gsamples's Avatar
If you in an area that you can order from new egg.com you can catch them sometimes with new egg gift cards. I was able to get a RX-A2020 with a $710.00 gift card when I bought the receiver for $1599.00. The have the gift cards on the 3020 sometimes also but I am not certain the amount.
gsamples is offline
post #551 of 2024 Old 03-29-2013, 04:51 PM - Thread Starter
FilmMixer's Avatar
Quoted: 1732 Post(s)
Liked: 2093
Call Abt.
FilmMixer is offline
post #552 of 2024 Old 03-29-2013, 05:10 PM
jvinhj240's Avatar
Quoted: 38 Post(s)
Newegg and Abt. = ~$2000
I found ebay for $1500. I usually don't buy receiver from ebay. What do you guys think?
post #553 of 2024 Old 03-29-2013, 05:40 PM
SARHENTO's Avatar
I would not buy from ebay. Buy from an authorized dealer for obvious reasons.
SARHENTO is offline
post #554 of 2024 Old 03-29-2013, 05:53 PM
jvinhj240's Avatar
Quoted: 38 Post(s)
Thanks, I am waiting for Abt. to call me back.. He says he can give me previous price. I don't know what on sale price with abt. So, ~$1600 is best price here?
edit: I able to get that price $1600 shipped brandnew. THanks all and filmmixer.
post #555 of 2024 Old 03-29-2013, 09:03 PM
SARHENTO's Avatar
edit: I able to get that price $1600 shipped brandnew. THanks all and filmmaker .
First thing you should find out is the firmware version. The latest is 1.41
Update first before you do YPAO. You will get a more accurate result. Whatever tweaking you want to do after running YPAO, never change the default for DYNAMIC RANGE which is MAXIMUM. If you change it, it will sound awfull.
SARHENTO is offline
post #556 of 2024 Old 03-29-2013, 09:17 PM
jvinhj240's Avatar
Quoted: 38 Post(s)
OK, that's a great info. there. Also, it says upscale 4k, does it means the picture quality improve up to 4x?
post #557 of 2024 Old 03-29-2013, 09:30 PM
SARHENTO's Avatar
Theoretically, yes, but if your display device is not 4K compatible you,ll benefit nothing from it. I don't think there are 4K TVs that are widely available to consumers yet.
SARHENTO is offline
post #558 of 2024 Old 03-30-2013, 01:24 PM
se2k's Avatar
You can do it if you set up a scene for each source, then always switch sources by selecting the appropriate scene. See page 107 in the 3020 manual, where it describes (under "Detail") the different things that can optionally be loaded as part of a scene. If you enable Video settings as part of a scene, then Video Mode is one of the things that will be associated with each scene. Video Mode can be Direct, to disable processing.
I picked up a RX-A3020 a few days ago and have been trying to solve this myself. I have found that SCENE modes do not capture the Video Processing setting. The Video Processing setting can be defined per input, but I am trying to have 2 different SCENE settings for my PS3 on Input 1. The reason for this is because I use my PS3 for Blurays as well as games, and I want Video Processing enabled for Blurays but disabled for games (to minimize input lag).
I am trying to set my SCENE modes up as follows:
SCENE 1: Video Games - PS3
Input 1 (Playstation 3)
Sound Program: Action Games
Video Processing: Direct
Enhancer: Disabled
SCENE 2: Movies - PS3
Sound Program: Surround Decode
Video Processing: Processing
Enhancer: Enabled
SCENE 3: Games - XBOX 360
Input 2 (XBOX 360)
Enhancer: Disabled
SCENE 4: Home Theatre PC
Input 3 (Computer)
Enhancer: Enabled
All settings seem to change except for Video Processing.
If this can't be done, is there at least an easy way to assign the Video Processing setting to buttons so that I can enable/disable as needed without going through the on-screen menu? On my RX-V3900, settings could be assigned to the Memory keys on the remote.
se2k is offline
post #559 of 2024 Old 03-30-2013, 01:53 PM
jvinhj240's Avatar
Quoted: 38 Post(s)
The new Ultra HD tv should able to have that resolution but it won't be available in the next 2 years or so, but at least some 720p or lower it should upscale and able to watch better resolution? Anyhow, my receiver will ship out Monday and should receive sometime next week. Very excited. smile.gif
post #560 of 2024 Old 03-30-2013, 04:01 PM
Ross Ridge's Avatar
Liked: 81
Originally Posted by se2k View Post
I picked up a RX-A3020 a few days ago and have been trying to solve this myself. I have found that SCENE modes do not capture the Video Processing and Enhancer settings.
The Enhancer setting should work with SCENEs by default, but you have to first enable it for a scene before video settings to be recalled. [On Screen] -> Scene -> -> Load -> Detail -> Video.
se2k likes this.
post #561 of 2024 Old 03-31-2013, 02:33 AM
se2k's Avatar
You rock. That did the trick.
What a very odd place to put the option to enable and disable settings to be applicable to SCENE. Why make that option off the "Load" menu?
Anyway, thank you!
se2k is offline
post #562 of 2024 Old 03-31-2013, 04:17 AM
benw07's Avatar
Have my a-2020 up and running in basic form. Next steps are:
1.) DLNA streaming from my PC
How do I stream digital movies from PC to the AVR using DLNA? I assumed I would need Windows Media Centre for this, which I now have on my Windows 8 PC. However I cannot find an option to output to the AVR (which is simple when using Airplay). How do I set this up? And is there a PC app that will make this easier?
2.) Optimising dialogue audio in 2.1 for TV/Movie
There are various sound modes - but which is the right one to use with a 2.1 setup? I use "stereo" for music and have bass turned up. When I switch to TV this is okay but can make some dialogue harder to hear than it should. So, without the luxury of the surround sound settings, which audio modes are best suited for dialogue?
Also, have read some articles about using phantom centre speakers. Would love to try this out to see if this boosts dialogue - any tips on how to set this up on the Yamaha?
PS: L/R Speakers are Paradigm Studio 60
benw07 is offline
post #563 of 2024 Old 03-31-2013, 06:19 AM
kriktsemaj99's Avatar
Quoted: 645 Post(s)
Liked: 364
1) There's no video streaming (only audio). You need to connect a separate media streamer for video.
2) Try turning up the Dialog Level in the Option menu (that's a new feature for Yamaha). Also turning up the bass may make it harder to hear dialog.
kriktsemaj99 is offline
post #564 of 2024 Old 03-31-2013, 09:21 AM
Jupazuba's Avatar
Hello,
I Just pre-ordered Yamaha Adventage RX-A2020. I`m not getting the amp to my self until after a few weeks but I have read the intruction manual from the web. I didn`t found direct answer to one question. I use to watch movies from a different seat than where I play games. So those two places would need different settings from the amp. I know that Scene functions can do a lot but is it possible to add different time corrections behind different scene buttons? Input source would be the same all the time(PS3).
I found out that it is possible to make two YPAO settings and use the better one(?) Would this make possible to add other YPAO setting to game use and other one to movie use?
Even if this kind of adjustment isn`t possible I`m sure the amp is wonderful!
English isn´t my native language so I hope I made my question clear smile.gif
Jupazuba is offline
post #565 of 2024 Old 03-31-2013, 10:41 AM
Quoted: 645 Post(s)
Liked: 364
Originally Posted by Jupazuba View Post
... I use to watch movies from a different seat than where I play games. So those two places would need different settings from the amp. I know that Scene functions can do a lot but is it possible to add different time corrections behind different scene buttons?
You should set up two different speaker "setting patterns" (page 114 of the manual). Then when you switch between pattern 1 and pattern 2, everything related to speaker setup is switched (including distances and levels, EQ, etc.).
post #566 of 2024 Old 03-31-2013, 02:13 PM
BGS14's Avatar
Hello,
I am about to buy the 3020 but just wanted to make sure that it will meet my needs.
I have a main room with a TV and 5.1 set-up and another room with a TV and two external speakers. I have an Apple TV, BD player, XBox that I will connect to the 2030 via HDMI. The main room will be using the HDMI1 as the output. Will it be possible to watch a movie in the second room with the video sent to the TV using the “HDMI OUT2” and the audio for the movie running as Zone 2 Extra SP1 on the external speakers?
BGS14 is offline
post #567 of 2024 Old 03-31-2013, 02:45 PM
Ross Ridge's Avatar
Liked: 81
Yes, you'd be able to watch a movie on the second TV and listen to it on the Zone 2 speakers. The one potential snag is that unless you're watching the same source in the main zone then the source you're watching in Zone 2 has to be using 2.0 stereo PCM. Many devices should detect this and automatically switch to 2.0 PCM but it's possible you may have to manually configure them to force them to use stereo instead of a surround sound audio formats.
post #568 of 2024 Old 03-31-2013, 05:28 PM
BGS14's Avatar
Many thanks Ross!
BGS14 is offline
post #569 of 2024 Old 03-31-2013, 05:58 PM
benw07's Avatar
Anyone figured out how to have a video source on Tv, but with music playing through speakers (airplay, radio etc)
i.e. choosing a separate input for video and separate input for audio? Should be possible, but dont see how this can be done on Yamaha's settings. I have the A-2020.
benw07 is offline
post #570 of 2024 Old 03-31-2013, 08:35 PM
Jupazuba's Avatar
Thanks a lot! That`s great. For some reason I didn`t notice that page of the manual but found it now!
Jupazuba is offline
Yamaha , Yamaha Rx A1020 7 2 Channel Network Aventage Av Receiver , Receivers Amplifiers , Yamaha Rx A2020 9 2 Channel Network Aventage Av Receiver
