The "Official" Yamaha AVENTAGE RX-A1020, RX-A2020 and RX-A3020 Thread - Page 60 - AVS Forum
post #1771 of 1792 Old 09-07-2014, 03:59 AM
Bond 007's Avatar
Quoted: 301 Post(s)
Liked: 852
Originally Posted by jahriel12 View Post
Has anyone had a problem not being able to play the audio from YouTube or Amazon Prime thru their AVR?
I have the LG 55LM8600. Audio works fine for DishTV. I have a Yamaha RX-A3020 for AVR. However, when I try to play a YouTube or Amazon Prime video/movie the audio does not come thru. The YouTube and Amazon Prime apps are on my TV.
Here is how i am connected currently
TV - HDMI 1(ARC) goes to HDMI Out 1 (ARC) on AVR
DishTV goes to HDMI AV2 on AVR
For tv watching i simply go to AV2 on AVR and everything is fine. But when I then try to play videos thru the Smart TV apps on the LG i get no sound thru AVR. In order to get sound I have to change setting on the LG to use the TV speaker not an External speaker.
I want to be able to watch a movie and listen to it through my home theater setup, NOT the wimpy LG tv speakers!!!
Any suggestions?
Thanks in advance!
Turn off ARC in all devices and run a digital optical cable from tv to AVR.
Bond 007 is offline
post #1772 of 1792 Old 09-10-2014, 08:39 AM
duvy56's Avatar
mono
I've got the 3020 and just bought The Beatles in mono. Is there a setting to listen in mono, will the Movie Mono setting do the trick?
duvy56 is offline
post #1773 of 1792 Old 09-10-2014, 08:58 AM
Bond 007's Avatar
Quoted: 301 Post(s)
Liked: 852
Try Straight or Pure Direct.
Bond 007 is offline
post #1774 of 1792 Old 09-10-2014, 09:26 AM
nathan_h's Avatar
Quoted: 82 Post(s)
Liked: 89
Are you trying to have the sound all come from your center speaker?
I have had the best luck with DPLII to get a mono signal to show up in the center channel.
____________________
Build Thread:
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
nathan_h is offline
post #1775 of 1792 Old 09-10-2014, 10:28 AM
duvy56's Avatar
Well since this is my first try with mono vinyl I was looking for the best sound, so far not impressed. Really wasn't sure what to expect.
Tried all the different settings didn't really care for any of them. Now I don't have a mono cart and not sure if what I've tried so far is the optimal way to listen.
Analog Planet has some good reviews on these new mono reissues but it's looking like I'm not a mono guy, oh well guess I'll send it back to Amazon. Thanks for the reply's.
duvy56 is offline
post #1776 of 1792 Old 09-10-2014, 11:00 AM
nathan_h's Avatar
Quoted: 82 Post(s)
Liked: 89
Interesting. For mono vinyl, I'd recommend pure direct like Bond007 recommends AND disattach one of your speakers. That should mean you are getting a full range, mono signal, from one speaker -- as was intended by the original recording.
That way, you will definitely know what it SHOULD sound like -- and then can decide if you like mono.
It takes getting used to, I think, if you haven't listened to mono before. But it is the way lots of older recordings were intended to be heard.
Build Thread:
nathan_h is offline
post #1777 of 1792 Old 09-10-2014, 11:13 AM
Quoted: 22 Post(s)
Liked: 5
I have a LG 65LA9700.
When I run an optical output from my cable PVR box to my old Pioneer Elite VSX-49TXi then I see the receiver light up with 5.1 indicated (5 speaker boxes and LFE) on movies that are shown in the guide as being "5.1".
However, with the same program signal going to the TV via HDMI and optical audio out from the TV to the same receiver input I get sound but no 5.1 lights, not sure if the TV is just outputting 2.0 sound. I have to use some receiver processing mode to get sound to the surround and back speakers.
This old receiver has no HDMI inputs so I'm trying to limp along with it until something with high bit HDMI 2, HDCP 2.2, Dolby Atmos, DTS UHD, etc. comes along (2015 models?).
Last edited by DoDaLeCa; 09-10-2014 at 11:27 AM. Reason: Added some detail for clarification
DoDaLeCa is offline
post #1778 of 1792 Old 09-10-2014, 12:27 PM
Bond 007's Avatar
Quoted: 301 Post(s)
Liked: 852
Your tv is downconverting 5.1 to 2.0 when the signal is from an external source. Most of them will do that. The only time you will get 5.1 output from the tv is from an internal source (built in "smart" apps).
nathan_h likes this.
Bond 007 is offline
post #1779 of 1792 Old 09-10-2014, 05:30 PM
Quoted: 22 Post(s)
Liked: 5
Yeah I knew this but didn't specifically give that conclusion to your recommendation that that person might have a decrease in sound channel information playing it from the TV as opposed from directly from the source to the AVR.
DoDaLeCa is offline
post #1780 of 1792 Old 09-10-2014, 06:12 PM
Bond 007's Avatar
Quoted: 301 Post(s)
Liked: 852
I dont understand what you mean. But youre situation is not the same as his. He is using ARC and HDMI. You are not.
Bond 007 is offline
post #1781 of 1792 Old 09-10-2014, 07:12 PM
JChin's Avatar
Quoted: 86 Post(s)
Liked: 132
Any suggestions?
Thanks in advance!
Hi jahriel12, you didn't mention but enable the TV HDMI Control - Simplink and ARC.
You may be better off using optical cable like Bond 007 suggested.
JChin is offline
post #1782 of 1792 Old 09-10-2014, 08:04 PM
Quoted: 22 Post(s)
Liked: 5
I meant to suggest that if he used the optical audio from the TV to his AVR as per your suggestion that he might lose sound quality or have less channels than a direct connection from the device to AVR or from the TV to AVR via HDMI if ARC functioned correctly.
DoDaLeCa is offline
post #1783 of 1792 Old 09-10-2014, 09:42 PM
Bond 007's Avatar
Quoted: 301 Post(s)
Liked: 852
I see. It would depend on the device. If hes only using optical for the built in apps there would be no loss of sound quality since the apps support nothing higher than DD+. Also since ARC can be finicky and giving him problems the optical connection is simpler and more reliable.
Bond 007 is offline
post #1784 of 1792 Old 09-16-2014, 12:47 AM
Craig Mecak's Avatar
Hi,
I have the RX-V3073 receiver, virtually the same as the RX-A3020.
In the web-based /setup menu, I can see different MUTE levels - OFF/-20dB/-40dB etc.
I want the MUTE button on the supplied Yamaha IR remote to engage the -20dB setting all the time if I select it, but it always engages the fully OFF type of MUTE.
How do I do this without going into the web-based GUI all the time? I can't see an option to "save" the -20dB style of MUTE.
Cheers,
Craig.
Craig Mecak is online now
post #1785 of 1792 Old 09-16-2014, 05:26 AM
kriktsemaj99's Avatar
Quoted: 135 Post(s)
Liked: 155
^ Mute -20dB and Mute -40dB require different discrete IR codes, there's no setting that makes the standard Mute code perform these operations.
However, the 3020 remote is capable of learning any code (see the manual). So you could teach it the Mute -20dB code and assign it to some other button. But first you'll need another learning remote that can emit the code, so that you can teach it to the 3020 remote.
kriktsemaj99 is offline
post #1786 of 1792 Old Yesterday, 12:05 PM
carminepesce's Avatar
Hey guys noticed something last night that the HDMI OUT indicator on the front panel kept lighting up then disappearing randomly but I didn't lose signal at all to my TV. Was just wondering if anyone had ever noticed this & what might have been the reason why it was happening?
Thanks so much guys!!!
Carmine
carminepesce is offline
post #1787 of 1792 Old Yesterday, 12:14 PM
Bond 007's Avatar
Quoted: 301 Post(s)
Liked: 852
Carmine
HDMI OUT blinks on my AVR when everything is off (except the AVR) since I got a new tv. Doesnt seem to affect anything and I dont know why.
Bond 007 is offline
post #1788 of 1792 Old Yesterday, 04:06 PM
Thanks very much Bond!!!!
Carmine.
post #1789 of 1792 Old Yesterday, 04:40 PM
Quoted: 135 Post(s)
Liked: 155
Usually that means the TV is not really off, but in standby mode where it doesn't completely disable its HDMI ports (so the AVR keeps trying to handshake). Maybe there's a setting on the TV that changes that.
post #1790 of 1792 Old Yesterday, 05:26 PM
Bond 007's Avatar
Quoted: 301 Post(s)
Liked: 852
I agree. Its as if the tv is still sending a signal to the AVR even when the tv is off.
No setting to fix it. Ive tried everything. As long as it doesnt affect performance Im ok with it. I dont even notice it anymore.
Btw. Its a very basic tv. Not smart. No ARC or CEC. Youd think it would be the last tv to do such a thing but none of my previous tvs did it. Who knows.
Bond 007 is offline
post #1791 of 1792 Old Yesterday, 07:31 PM
It does it with my Panasonic ST50 but as Bond said it doesn't affect performance at all whatsoever so I'm fine with it too. I just asked about it when I first noticed it happening cause I thought it was a problem with the receiver…
Thanks as always guys!!!
Carmine.
post #1792 of 1792 Old Yesterday, 09:44 PM
Bond 007's Avatar
Quoted: 301 Post(s)
Liked: 852
FWIW I had a 60ST50 and a Yamaha 671 and the 671 didnt flash HDMI OUT.
Bond 007 is offline
Yamaha , Yamaha Rx A1020 7 2 Channel Network Aventage Av Receiver , Receivers Amplifiers , Yamaha Rx A2020 9 2 Channel Network Aventage Av Receiver
Gear in this thread - A1020 by PriceGrabber.com
