green power strip for non triggered amps? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-12-2012, 09:10 PM - Thread Starter
smfins's Avatar
Quoted: 36 Post(s)
I have been looking at some of the various green power strips out there. I'm wanting to hook my receiver into the controlling outlet and hook my 4 amps into the switching outlets since they don't have remote triggers. My questions are......Does anybody know how this will work or if it will work? Will one of these be able to handle 4 amps hooked to it? 3 of them draw about 300 watts max and the other draws about 600 watts max. Here is the link to one that i was considering.
http://www.monstercable.com/productdisplay.asp?pin=5730
smfins is offline
post #2 of 4 Old 06-13-2012, 11:18 AM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
Smartstrip, good for 15 A, which is probably same as your circuit breaker.
Noah
noah katz is offline
post #3 of 4 Old 06-13-2012, 08:59 PM - Thread Starter
smfins's Avatar
Quoted: 36 Post(s)
So The Smart strip should be fine for this aplication? I would be going from 4 seperate chords down to one feeding all 4 devices. i guess i could always just give it a shot! It would be great for a simple fix like this for my dilema. Thanks for the info!
smfins is offline
post #4 of 4 Old 06-14-2012, 02:18 AM
SoundChex's Avatar
Quoted: 350 Post(s)
Liked: 295
I purchased a Rocketfish - 7-Outlet Home/Office Surge Protector ('smart strip') from BestBuy to control 2x power amps without triggers, plus 2x subs. Worked ok with my RX-V667.
[Home Office system schematic]
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is online now
