Integra 50.4 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 06-14-2012, 12:05 AM - Thread Starter
bucket23's Avatar
I see the new Integra 50.4 came out last week. It's on their website. It has audeyssee XT32 as well as the Sub EQ. Anybody got their hands on one to test out.
bucket23 is offline
post #2 of 21 Old 06-14-2012, 10:06 AM
Audiodork's Avatar
Liked: 37
Hello,
I believe it is simply Integra's version of the Onkyo TX-NR818. In which case, aside from having 12v Triggers for the Main Zone, a longer Warranty, no Hidden Door, and offers a Silver Volume Knob is internally identical. This would also mean that like the 818, it will not offer Audyssey's stellar SubEQ HT which until these AVR's has been bundled with every prior XT32 AVR/SSP. If only using a single subwoofer, the loss of SubEQ HT really is not a big issue and you still gain the far greater Filtering on the LFE Channel that XT32 offers.
Cheers,
AD
Radio Shack SPL Meter Owner
Audiodork is offline
post #3 of 21 Old 06-14-2012, 12:38 PM
MCF34's Avatar
Quoted: 63 Post(s)
Is the 50.4 worth an extra $500 to $600 over the 818?
Jutter is gone..zipadeedoodah zipadeeday!!!
MCF34 is offline
post #4 of 21 Old 06-14-2012, 05:28 PM - Thread Starter
bucket23's Avatar
Most of the time the Onkyo's and Integras are the same, however the integra 50.4 specially metnions the sub EQ on it's feature list. I don't know if this is worth more, but it does give another option for those that want the sub eq on another reciever.
bucket23 is offline
post #5 of 21 Old 06-14-2012, 08:10 PM
MCF34's Avatar
Quoted: 63 Post(s)
XT 32 on the 818 will EQ a single sub. Sube EQ on Integar will EQ two subs. It is possiblentoneq two subs without sub EQ. Just a little more difficult. For me, with a single sub sub Eq is not worth the extra cost of integra. Any more reasons to pay more for the integra?
MCF34 is offline
post #6 of 21 Old 06-14-2012, 08:30 PM
Mantis10's Avatar
Originally Posted by Audiodork View Post
Hello,
Cheers,
AD
The 50.4 looks awesome. I'm curious on how you know that Onkyo and Integra are exactly the same internally? I heard the Integra's are better built , higher quality amps , preamps and such. Yes the back panel boards are very similar but internally they are different.
Can you direct me to some good reading on this? I wouldn't mind reading all about this.
Mantis10 is offline
post #7 of 21 Old 10-05-2012, 09:45 PM
cfineman's Avatar
Quoted: 35 Post(s)
I was looking at a 50.4 today in a local shop. I believe this is more comparable to the NR1010... not the 818. You have to look beyond the watts (e.g. Push-Pull amp design, different 1080p upscaling)
cfineman is offline
post #8 of 21 Old 10-05-2012, 10:55 PM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
I disagree. Compared to the 818, the 50.4 has the typical additional features found on Integra models but it is for all intents and purposes the same unit.
The 1010 is a different animal entirely. Just look at the build and where everything is laid out on the three models and you'll find the 1010 is the odd man out. The 818 and 50.4 also share similar weights but the 1010 is 5kgs heavier.
fahrenheit is offline
post #9 of 21 Old 10-06-2012, 09:46 AM
Knucklehead90's Avatar
Quoted: 385 Post(s)
Liked: 332
I agree with fahrenheit - the 818 and the 50.4 look to be identical AVRs.
People that have examined the Integra to the Onkyo which it is based from always find the same thing under the hood. The front panels are always different but if you examine the back panel they are nearly always the same.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #10 of 21 Old 10-06-2012, 11:32 AM
cfineman's Avatar
Quoted: 35 Post(s)
Not had a chance to open the two up and look at them side-by-side... I based my statement on differences/similarities on the "feature charts" but you are certainly correct about the weight difference upon further inspection. Having said that, just going on the feature charts listed on the site I found the following
  • NR1010 & 50.4 have Neo:X, the NR818 does not.
  • NR1010 & 50.4 advertise a Push-Pull amp design... NR818 does not have that "checked off"
  • NR1010 & 50.4 have digital crossover processing, 818 does not
  • NR1010 has VLSC and 50.4 & 818 do not
  • NR1010 & 50.4 share the same 1080p upscaling (818 uses Marvell instead of HQV)
Not making any comments on the relative importance of these differences (obviously the weight, presumably dominated by the difference in the power supply, is significant). Just saying that the processing "guts" of the 50.4 appear closer to the 1010 platform than to the 818 platform. I do agree, however, that the backpanel of the 50.4 much more closely matches the 818.
cfineman is offline
post #11 of 21 Old 10-06-2012, 03:37 PM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
I wouldn't base my comparison on those feature charts. Picking over the manuals is really the only way to compare these AVRs.
The 818 certainly does have Neo: X. I don't know about Push-pull but the 818 does have adjustments for crossover, its just coarser than the 50.4's range. Marvell and HQV are not one or the other. It is both. The Marvell chipset is used for 4K upscaling and the HQV chipset handles everything else.
post #12 of 21 Old 12-02-2012, 11:34 PM
rchwallace's Avatar
Sorry to jump on here but it is my opinion that Integra is an AMP which has alot more under the hood than the Onkyo than what you might be able to find in the manual. I just got the 50.4 and love it. But I also spent about 4 hours talking with a dealer/tech who had alot to say about it. Dual independent power supplies, 4 ohm stable, internal design features which are not front and center of which the manual cant tell you all. When I see an electronic device giving a factory 3 yr warranty that says something. Anyway it is just my opinion but I have just got the 50.4 and have no reason to defend it or my purchase. I was looking at the time at the top of the line for Onkyo and Denon and after 4 hours on the phone and some additional research of which the internet was not very useful, I found that this AVR is much better suited than many would guess from reading the manual. (just my opinion)
rchwallace is offline
post #13 of 21 Old 12-03-2012, 12:01 AM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
The top grilles are both easy to see into. You really should compare them with your own eyes before you believe everything a dealer tells you.
post #14 of 21 Old 12-03-2012, 05:10 AM
Theresa's Avatar
Liked: 51
Its been reported by people who have seen the internals that Integra and Onkyo are indeed the same apart from interface and cosmetics.
Theresa is offline
post #15 of 21 Old 02-20-2013, 08:19 PM
jmschnur's Avatar
Does the 50.4 have sub eq or not?. The manual I downloaded does not show it.
jmschnur is offline
post #16 of 21 Old 02-21-2013, 03:20 AM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
Eq for a single subwoofer yes.
post #17 of 21 Old 02-21-2013, 10:42 AM
jmschnur's Avatar
But not for twos like other audyssey xt 32 sub eq system?
jmschnur is offline
post #18 of 21 Old 02-21-2013, 12:08 PM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
Correct.
post #19 of 21 Old 11-30-2014, 10:27 AM
jmschnur's Avatar
Originally Posted by fahrenheit View Post
Correct.
Any problems with audio not working on on the 50.4. Mine has no audio now when turned off and then turned on. Unplugging the unit returns the sound .
jmschnur is offline
post #20 of 21 Old 12-01-2014, 11:35 AM
G I Joe's Avatar
Oh no..
I have a 50.4, & I had a no audio situation but I only had to switch to another input via remote like going from game 1 to game 2 then back & it works fine. The issue only happened a couple of times in the last 2yrs I've had the receiver.
My Onkyo one he other hand,(805),started doing that same thing then the HDMI board went completely bad, per Onkyo Authorized Repair Service. I hope his isn't a sign of the dreaded HDMI issue. I have kept in contact with the Dealer\Repair shop & as of today, they haven't had an HDMI related failure repaired or reported. I hope you just had some type of HDMI interruption that just needed to be reset or something. The input that had the audio drop on my 50.4 was from a HDMI over CAT connection & I know sometimes that can get interrupted from the powered side of the converter. I once unplugged the converter & plugged it back up & it recycled, but I won't do that again unless I power down the unit so not to cause a spike across the HDMI board.
I truly hope your problem is just some simple glitch. Please keep us informed.
G I Joe is offline
post #21 of 21 Old 01-13-2015, 06:21 PM
G I Joe's Avatar
Oh Yea...I Hope
Well, my 50.4 started dropping audio more often. I called the Integra Dealer\Repair shop I bought it from. I was surprised to learn that THEY HAVE HAD UNITS go bad like this. They told me that Integra has acknowledged this & is solving the issue. They told me that I could bring in my receiver & they would ship it back to Integra & I'd get a new receiver instead of mine getting fixed. That sounded too good to be true. I took it to the dealer\authorized repair shop, they said the new unit would be in in no more than maybe a week, but I'd have to pay $28 for shipping. I thought something wasn't right so I called Integra. They told me that they would only repair the unit, send me a box with a label so I had no cost & it may take up to 2 weeks possibly more. I called my dealer & relayed what Integra told me & he said the rep from Integra that he deals with handles this that way if I go through them , swapping out the unit, if I choose to send it myself they'd fix it. I had dropped it off Monday, called Tuesday & was told it just went out. They also said that when they shipped it out, they gave Integra a tracking # & Integra shipped the replacement unit out. I was skeptical. Friday I called & they told me it just came in. I went to pick it up. The dealer again said that Integra didn't send him a shipping lable & box so I had to pay the $28. I opened the box & sure enough there was a new {refurbish) unit in it. I asked why refurbish & he said that because when they went in it to repair it, it can't be sold as new. Again I was skeptical on that but he assured me that it was a new unit & not someone's return. I was eased a little when he told me that the 3yr warranty started again from this point. I paid the $28 , went home & as of today everything seems fine. I will keep everyone updated.
G I Joe is offline
