2 easy qystion im new :) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-14-2012, 04:13 PM - Thread Starter
waheeb512's Avatar
Hello i am New. At this
Stuff
I have Yamaha rcv rx-v467 on the speakers port written. 6 omega. Min. And i have. Samsung speakers with 3 omega can i connect it to the rcv?
And i also have Samsung subwofer Samsung only got +- port like normal speakers how i can connect it too
thanks
waheeb512 is offline
post #2 of 4 Old 06-14-2012, 05:21 PM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
The Samsung speakers and subwoofer are likely part of a HTIB setup designed to only be used with the receiver that was part of the HTIB. Suggest you sell the HTIB and get new speakers and a new "powered" sub to use with the Yamaha.
waheeb512 likes this.
jdsmoothie is offline
post #3 of 4 Old 06-14-2012, 05:25 PM
buggs1a's Avatar
Quoted: 179 Post(s)
Liked: 24
Hi.
If there's no sub connection as you say it has + - only, you might be able to use that with your sub if it has them too.
You can connect your speakers fine in my opinion. I don't see an issue but that's also in part because I don't know much about ohms on speakers and amps. What i do know is I've got 4ohm speakers and have had them on 8ohm recovers and never had an issue.
Your receiver might say 6ohm but less can work fine too. Maybe the thing is volume played that is a factor in ohms. So if not blasting then no problem in my opinion.
buggs1a is offline
post #4 of 4 Old 06-15-2012, 07:10 AM - Thread Starter
waheeb512's Avatar
Thanks all for the help
And bro i plug it the Samsung speakers and its work good but the problem
My tsi100 speakers is the right n left speakers and the Samsung speakers in the rear left n right
But when i listen to music "stereo 7 ch " its works fine bu t the tsi100 so much laoder than
The Samsung speakers even when i set beside the Samsung speakers i hear the tsi100
laoder and don't feel like its working and the speakers are for HTX 725
One more thing how i can connect my yamha rcv to my pc i have 7.1 soundcard
