Denon 4311 update problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 06-16-2012, 10:56 PM - Thread Starter
hukeys's Avatar
Hi everyone,
This is my first time here, and wonder if someone might be able to assist. I bought an AVR 4311 yesterday but the display is constantly giving me a message that it's waiting for upgrade. I decided to connect the receiver to the internet; all was ok. It was updating nicely, counting back from 6 mins, 5 mins, then all was cancelled and this process has now gone into a continuous loop. It gets to 4 mins then aborts. I did not interrupt the connection in any way at the time so wondering what is causing this.
Any ideas would be very much appreciated.
hukeys is offline
post #2 of 13 Old 06-17-2012, 12:58 AM
jdsmoothie's Avatar
Quoted: 15089 Post(s)
Liked: 7282
Welcome to AVS Forum.
There are two types of firmware information notices, an "update" (fixes) and an "upgrade" (new feature), the latter referring to the Airplay "upgrade" which can be done after you're able to successfully "update" the firmware. If you don't have a "wired" connection from the AVR to your router, ideally that is what's best for firmware updates/upgrades. Regardless, as noted in the Owner's manual p. 106, either press/hold the ON/STANDBY button for more than 5 seconds, or unplug the AVR for a few minutes at which point the AVR will attempt the update again.
Also note there is a dedicated Denon AVR-4311CI Owner's thread ---> http://www.avsforum.com/t/1274153/the-official-denon-avr-4311ci-avr-a100-thread-no-price-talk/0_50
jdsmoothie is offline
post #3 of 13 Old 06-17-2012, 01:15 AM - Thread Starter
hukeys's Avatar
Thanks very much for your reply; much appreciated. I did try your suggestion but it is caught in this endless loop, it would seem. I do have the connection via ethernet cable; it acknowledges the update, counts back from 6 mins, then stops at 4 mins and goes back into the loop, over and over...
I get the message: Please wait, update retry, then Ether IMG, Updating 6 mins... back to the loop each time. It won't go down beyond the 4 mins...
Very strange...
hukeys is offline
post #4 of 13 Old 06-17-2012, 01:30 AM
jdsmoothie's Avatar
Liked: 7282
Let it continue and eventually it should complete successfully. Once it does, you can register for the Airplay Update on Denon's website ---> http://usa.denon.com/us/Airplayus/index.html
post #5 of 13 Old 09-16-2012, 12:16 PM
Rottenronnie's Avatar
Hi,
Did you eventually get this resolved? If so, how? I have the exact same problem. I have turned off update and upgrade notifications ( quickly when it cycles) to no avail as the loop continues. Unplugging does not do anything either although I will try several minutes vs seconds next time. Should really have a "try again?" prompt or something. Has been looping for a few hours now, very frustrating. Anyone else find a solution? AVR unusable at this point.
Ron
Rottenronnie is offline
post #6 of 13 Old 09-16-2012, 12:20 PM
Hi,
Like Huey's, the registration for AirPlay upgrad was done first, then install/upgrade process is started, then stuck in loop. Another thread here suggested the "turn off notification" which has been done with no effect.
Ron
post #7 of 13 Old 09-16-2012, 12:21 PM
NeogeoG's Avatar
Quoted: 29 Post(s)
Originally Posted by Rottenronnie View Post
Hi,
Ron
¿Did you try a fabric reset?
NeogeoG is offline
post #8 of 13 Old 09-16-2012, 12:54 PM
Not sure what you mean by fabric reset?
post #9 of 13 Old 09-16-2012, 01:01 PM
Socketman's Avatar
Quoted: 163 Post(s)
Liked: 170
he means factory reset, was probly using a smart phone and it auto corrected his spelling , incorrectly i might add. Look in you manual on how to do a factory reset.
Socketman is offline
post #10 of 13 Old 09-16-2012, 01:06 PM
NeogeoG's Avatar
Quoted: 29 Post(s)
Thats what I meant, the problem is not my phone, its my english because I am from Spain.biggrin.gif
Try the factory reset, see if you can get it to go back before you where experiencing the problem.
NeogeoG is offline
post #11 of 13 Old 09-16-2012, 01:21 PM
Thanks guys, I have tried the processor reset to no avail. I have now read that ther might be way to reset the internal network card, I will try that next . Have to wait agin until safe to do so, right after reboot. Any other thoughtsZ.
post #12 of 13 Old 09-17-2012, 10:30 AM
For those interested, holding the up and down arrow and power at the same time resest the network card (I think) and stopped the AVR from the infinite loop so it least now I can use the amp. Not sure where I go from here but traveling for a few days so it will have to wait.
Ron
post #13 of 13 Old 11-26-2012, 09:31 AM
missing_link7918's Avatar
@ Ronnie
Thanks for the network reset information. I was having trouble connecting my 4311 with AirPlay and that did the trick. Typically I would go straight to the owner's manual, but Denon manuals are infuriatingly confusing confused.gif Thanks for your tip!
missing_link7918 is offline
