Can't get DD or DTS through HDMI, only PCM - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 06-17-2012, 10:10 PM - Thread Starter
NickRRood's Avatar
Hey guys,
I've been racking my brain over this...reading through forums, scouring instruction manuals, etc... I need help!
Granted I'm pretty new to this surround world, I feel like my setup is correct - just not working. Here's what I'm working with:
I have a 5.1 speaker setup, a Sony BDP-S570 BluRay Player, and an Onkyo TX-SR309. I have the Blurray Player connected via HDMI directly into the receiver, with another HDMI cable connected from the receiver to my TV. I've gone through all the settings on the blurray player and it looks like it is fully ready to transmit DD and DTS signals. When I select a Bluray to watch I make sure the audio settings on the BD are correct (in the case of what I am testing now, it is set for DTS-HD Master Audio.) When the movie begins playing though, the receiver only seems to be reading in PCM audio, and not DTS as I feel it should be. What steps am I potentially missing here?
I've also gone through all the receiver setup options and can't seem to find any answers there either. From what I can tell it is fully ready to receive DTS or DD surround audio.
Any suggestions? Thanks!
NickRRood is offline
post #2 of 25 Old 06-17-2012, 11:12 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
First, if your player is decoding the lossless track, then PCM is the best possible audio. It doesn't matter whether the player or the receiver does the decoding. The resulting PCM is the same either way.
As to why your player is doing the decoding rather than sending DTS-HD Master Audio to your AVR for decoding, we'll need to know the player's audio output settings. This is almost certainly a player setting issue. Also, are you getting multichannel PCM or just stereo?
BIslander is offline
post #3 of 25 Old 06-17-2012, 11:17 PM - Thread Starter
NickRRood's Avatar
You know, I think I actually figure it out. Continued reading through threads and found that someone suggested turning off the "BD Audio MIX Setting" on my particular bluray player. Bingo.
Suddenly DTS Master HD is an option and sounds WORLDS better.
I posted too soon. tongue.gif But thank you!
post #4 of 25 Old 06-18-2012, 06:13 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Yes, that's the player setting that usually causes a PCM output. Mix = On is the default.
But, again, PCM is the same quality as lossless decoded by your AVR. And PCM enables menu sound effects and other secondary audio. It may also facilitate room correction and other DSPs that some moderately priced AVRs cannot do when decoding lossless tracks themselves.
Sent from my ADR6400L using Tapatalk 2
post #5 of 25 Old 06-18-2012, 06:22 AM
jdsmoothie's Avatar
Quoted: 12096 Post(s)
Liked: 5507
What you perceive as "world's better" is simply due to the "bitstream" audio being a few db louder. wink.gif
As BIslander noted, the audio quality is the same either way.
jdsmoothie is offline
post #6 of 25 Old 06-18-2012, 07:01 AM
Guindalf's Avatar
I disagree!
I bought a new Yamaha RX-V673 on Saturday to replace an Onkyo TX-NR616, returned after three weeks of aggravation with problems (another story, another thread!) and I was frustrated with it because it was only outputting PCM. After reading this thread, I had the Mix=On and changed the setting and now I'm outputting TrueHD from the BD Player (Sony BDP=580) and the difference is immediately much, much better.
Of course, this is with 10 minutes of playing before I had to leave for work this morning, but last night, I was on the brink of returning another receiver because it wouldn't do what it was supposed to.
Made me realize, too, that because of the Onkyo problems, I hadn't watched a BD movie in over three weeks!
There is no dark side of the moon really - as a matter of fact, it's all dark
Guindalf is offline
post #7 of 25 Old 06-18-2012, 07:12 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
While I would never disagree with someone's personal expediences, the fact remains there is no difference between the PCM produced by player and receiver decoding. Lossless codecs are like zip files whose sole purpose is saving space on a disc. The decoders on all players and receivers unzip lossless codecs exactly the same way. They have to. Otherwise the outputs would not be lossless. So, perhaps the differences you hear are simply volume. Or, maybe you applied other processing to the PCM in your player, something like Dynamic Range Compression.
post #8 of 25 Old 06-18-2012, 02:26 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
+1/ PCM is the original data. The high def lossless codecs are just lossless codecs. To be lossless, by definition, when you decode them, you have to get the PCM that started.
I note JDSmoothie suggested there may be a volume difference between the output with bitstreamed lossless codecs and that with PCM from the player, and AFAIK it has been established beyond question that normal human beings uniformly will hear small differences in volume as increases in clarity, detail, etc. and likely never notice the volume difference. People constitute bad measurement devices!
JHAz is offline
post #9 of 25 Old 06-18-2012, 08:12 PM
BMaugans's Avatar
It's entirely possible for the PCM to sound different than the bitstream if the 'mix' setting is enabled. Many players will downsample the output to regular Dolby Digital when the 'mix' setting is enabled.
BMaugans is offline
post #10 of 25 Old 06-18-2012, 09:10 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Some players use lossy when mixing secondary audio. But, not this player.
post #11 of 25 Old 06-19-2012, 08:19 AM
Guindalf's Avatar
I don't know too much about the technical side, but I do know what I like! Whether my Rx wasn't processing the PCM or recognizing it I have no idea, but when I changed the setting, I was getting TrueHD or DTS Master Audio where I wasn't before and it sounds a whole lot better!
This is not intended as an attack, but sometimes I feel people put too much importance on facts and figures when all that matters is whether someone is happy with what they're hearing.
Guindalf is offline
post #12 of 25 Old 06-19-2012, 12:57 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Facts are good. Nobody can tell you what to hear, but there's nothing wrong with knowing the underlying facts. If yit leads a person to assess whether, like all other human beings, they are subject to biases that comme from all over the place (including subconscoius biases that require double blind testing just to figure out if a pill really reduced pain) that's okay too.
JHAz is offline
post #13 of 25 Old 06-19-2012, 01:30 PM
Guindalf's Avatar
Ok, so explain to me why my Sony BDP says it has options to output "Dolby Digital" or "DTS" or "Downgrade PCM" and the manual says "only enable PCM if your receiver is not capable of decoding DD or DTS"?
Guindalf is offline
post #14 of 25 Old 06-19-2012, 01:41 PM
jdsmoothie's Avatar
Liked: 5507
Well .... unless I missed it, the word "only" is not mentioned in the manual, rather simply that you would use PCM if the AVR cannot decode the audio and DD if it can, as most folks prefer to see the words DD/DTS on their front panel rather than seeing "Mult CH In". There's no implication that one format is better than the other.
106
post #15 of 25 Old 06-19-2012, 03:04 PM
Guindalf's Avatar
Really?
I'd say those instructions are pretty clear. The word "only" may be implied rather than stated, but to most, this would be read as 'only".
The word "Downmix" clearly suggests that it's an inferior option.
Guindalf is offline
post #16 of 25 Old 06-19-2012, 03:21 PM
jdsmoothie's Avatar
Liked: 5507
In your eyes perhaps .... bottom line is use the format you enjoy the most. wink.gif
post #17 of 25 Old 06-19-2012, 06:23 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
You do understand that everything recorded in digital that's not SACD is PCM? That PCM is the original, native recorded "sound" and that the lossless codecs take PCM, reduce the data load, then allow reconstruction back to PCM? It's not possible AFAIK for the zipped and unzipped system to be better than the original recording . . .
JHAz is offline
post #18 of 25 Old 06-19-2012, 06:35 PM
Kilian.ca's Avatar
Liked: 37
I have a Sony 770. In the manual, the Dolby Digital vs. Downmix PCM options refer to Coax/Optical output, so downmix (NOT downgrade) implies (as in normal use) channel reduction to 2.0 (stereo). There is a similar set of options for DTS for Coax/Optical. Coax/Optical can only carry max. stereo PCM, not multi-channel PCM. All this is irrelevant for the above scenario with HDMI connection.
The set of options for HDMI are Auto or PCM.
That aside, I'm puzzled why the volume difference between PCM and bitstream which seems to happen in the Onkyo. Why should a zipped and upzipped stream have different volume?
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #19 of 25 Old 06-19-2012, 07:00 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
That's a really interesting question. Maybe Filmmixer or soembody else in the biz understands how that happens. I assume it's anAVR anomaly, but IDK. Makes no sense to me, but I accept that it happens becuase it's been reported by reputable folks. Many players use the lossy stream if they are set to play the commentary etc. directly. Might be possible to detect the difference between the higher bitrate lossy used on BD and the original PCM/lossless stream, at least in some circumstances . . . .
JHAz is offline
post #20 of 25 Old 06-20-2012, 06:23 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Guindalf, as you have acknowledged, you know little about the technical side. Perhaps you can accept the information from the several posters here who do have that knowledge, and then try to figure out why your experience is different. Is the volume simply louder? Studies have shown people tend to believe louder is better. Have you applied settings in your player that modify the PCM differently than your AVR? The use of DRC would be something that would account for an audible difference. There are lots of reasons why bitstreaming lossless to your AVR may seem to sound better to you. But, that doesn't mean bitstream is higher quality, which is what your position seems to be.
And please don't take your interpretation of implications in a user manual as meaningful technical distinctions. Downmix has a specific meaning - reduction in the number of channels - and in the context of that part of the manual, it is talking about sending stereo PCM instead of encoded multichannel audio because optical and coax connections cannot support multichannel PCM. Even with that difference, the stereo downmix of a lossless source would be higher resolution audio, just not discrete 5.1. For movies, most people would prefer the lower resolution DD 5.1 or DTS output because they are mixed for surround. But, with a concert, many might actually find the high resolution stereo output sounds better than lossy multichannel. And, with concerts, applying PLII to a stereo source often produces the same surround experience as the 5.1 mix, which generally won't have specific surround channel effects.
post #21 of 25 Old 06-20-2012, 06:41 AM
ccotenj's Avatar
Liked: 101
you mean the "i have no clue how it works, but i'm certain that those who know how it works in great detail are wrong" pov doesn't work for you?
- chris
ccotenj is offline
post #22 of 25 Old 06-20-2012, 07:19 AM
Szeppelin75's Avatar
You know, you are so right about the last part. There's not a common rule saying this sound output or encoding is better than that onw.
For movies, like you say lower resolution DD 5.1 or DTS output is much better for me because the mixed surround sound.
For concerts, like you say, i find myself constantly changing and trying between the DD 5.1 and the PCM options, sometimes the PCM sounds better (louder) and you don't care too kuch for the "surround mix", but other times concerts in 5.1 sound fuller, like the mix is better and you hear the difference. last night i watched Billy Joel's Last Play at Shea, and the 5.1 mix was fantastic, but with another concert i watched the other day Eric Cplaton and Steve Winwood, the PCM 2.0 option was a better expereince for me than the 5.1 mix.
So, in the end, it's up to us to play with the different options and find the one we prefer for different sources and inputs. Nothing is written in stone.
Szeppelin75 is offline
post #23 of 25 Old 06-20-2012, 08:43 AM
Guindalf's Avatar
No, that is not my position. All I am saying is that I am following the manuals as I interpret them and getting something that sounds good to my lay ears. I just want to get as good an experience as I can from my new system and, the settings I have seem to do that for me. I have a life, and a wife, so I don't have the time to devote to the technical aspect of this. I just want it to work, which is seems to do with this setup. Obviously, my requirements are a step up from the HTIB crowd, but not as high as some who see it as their mission to get every nuance of sound from their system - NTTAWWT.
Several things here. First, I haven't said that ANYONE is wrong - until now. This post is completely unnecessary, demeaning and just plain wrong. Get your details straight if all you can add to the conversation is an insult!
This paragraph sums this up perfectly. I really don't care about the technical details enough to worry about it. As long as I'm getting the best I personally feel I can from my equipment, I'm happy, without being insulted, getting into p*ssing contests or anything else.
Guindalf is offline
post #24 of 25 Old 06-20-2012, 08:52 AM
No pissing everyone.
post #25 of 25 Old 06-20-2012, 07:54 PM
Kilian.ca's Avatar
Liked: 37
Personal preference for 2.0 PCM + DPLII vs. MCH lossy DD isn't the same argument as that between MCH decoded PCM and bitstream HD track. Preference isn't written in stone but there is solid science behind all this and it isn't exactly rocket science, not even college (university) degree level. But for someone who boldly proclaims "I disagree!" (post 6), admits to not caring about the technical side, bases his preference after "10 minutes" of listening and justifies his stance based on the wording in a wrong part of the product manual isn't in the best position to stand up and invite a sympathetic hearing in a predominantly technical forum such as this.
