Does Audyssey remove the need of THX processing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 06-19-2012, 07:37 AM - Thread Starter
kdp99's Avatar
Hi Folks,
Seeking some advice or even better experience. I have a great, but older Denon amp (the European version of the 5800 with upgrade). And am thinking of getting the 4520 when it comes out.
I will clearly lose the THX certification. I am not to worried about the loss of the 'badge' for the power amps, as I have several THX power amps I can use for the front array if needed.
I am more worried about losing the THX post processing, re-equilisation, timber matching, etc.
I use THX ultra2 Cinema mode for most movies as I find this does a great job of filling in the surround back channels when they are not actually encoded.
Will Audyssey take care of all this THX post processing or not, and if it does how well does it do it ?
kdp99 is offline
post #2 of 17 Old 06-19-2012, 09:03 AM
cmoore55's Avatar
Im no expert in this area but I know someone who is one of the best Home Theater designers in the world.
In fact I went with him about a decade or more back to Skywalker ranch to meet with the lead engineer for the Home THX project when the THX standard was rolled out to the home theater space. It was a big cutting edge deal back then and it blew out our socks off.
But times have changed and other audio developer muscle has been brought to bear in the market.
Recently I too was interested in THX right now so I asked my friend about it, he told me that the importance or relevance of THX has steadily diminished over the last few years and that he would see no need to have it on his "must have" shopping list right now.
His theaters run from 1 - 8 million dollars for just a room. His client list is pretty impressive and extends around the world .... in these matters, I take him at his word.
For what its worth.
cmoore55 is offline
post #3 of 17 Old 06-19-2012, 01:19 PM
jayray's Avatar
Liked: 25
For what its worth.
I'd agree with that.
John
Jayray
Read the FAQs
jayray is offline
post #4 of 17 Old 06-19-2012, 02:30 PM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
Originally Posted by kdp99 View Post
Hi Folks,
Pro logic 2x will suit your needs
Sent from my SCH-I405 using Tapatalk 2
pokekevin is offline
post #5 of 17 Old 06-19-2012, 04:21 PM
Quoted: 76 Post(s)
Liked: 113
I prefer Audyssey processing myself.
rnatalli is offline
post #6 of 17 Old 06-19-2012, 07:43 PM
Roger Dressler's Avatar
Quoted: 1872 Post(s)
Liked: 1004
These have nothing to do with one another. The OP has a 7.1 system, and Audyssey has no means to create rear surrounds from 5.1.
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #7 of 17 Old 06-20-2012, 06:03 AM
KidHorn's Avatar
Quoted: 1492 Post(s)
Liked: 982
Every 7.1 system I've owned has audyssey modes that can create 7.1 out of 5.1. My 4311 when running audyssey dsx can create 11.1 from a 5.1 source.
KidHorn is offline
post #8 of 17 Old 06-20-2012, 06:05 AM
jdsmoothie's Avatar
Quoted: 15370 Post(s)
Liked: 7517
Only Audyssey DSX can expand 5.1 audio and then only to Front Height and/or Front Wides ... not to rear surrounds as Roger notes.
jdsmoothie is offline
post #9 of 17 Old 06-20-2012, 10:09 AM
KidHorn's Avatar
Liked: 982
OK, so how am I able to hear something from my rear surrounds when listening to a 5.1 source?
KidHorn is offline
post #10 of 17 Old 06-20-2012, 10:11 AM
jdsmoothie's Avatar
Liked: 7517
post #11 of 17 Old 06-20-2012, 11:50 AM - Thread Starter
kdp99's Avatar
Firstly many thanks for the replies.
Two follow up questions:
With the 5.1 7.1 conversion discussed above, am I correct in assuming that DPL2X is used to create the surround back channels, then Audyssey engaged for room correction etc?
With the version of Audyssey that creates the front high and wide channels, does this also create the surround back ones, or are they not used ?
KDP99
kdp99 is offline
post #12 of 17 Old 06-20-2012, 11:59 AM
jdsmoothie's Avatar
Liked: 7517
Yes to your first question ... no to second. As noted in my post above, there is no Audyssey that creates the surround back channels, rather generally either DD PLIIx or DTS Neo:6 is used. Also as Audyssey MultEQ is an equalization process, it would EQ all of the speakers/sub(s) in the setup first and then the AVR uses whatever on board features are available to pass audio to the various speakers and sub(s).
post #13 of 17 Old 06-20-2012, 12:52 PM
KidHorn's Avatar
Liked: 982
Likely using either DD PLIIx or DTS Neo:6.
I press the dsx button on my remote and I get sound from all 11 speakers from a 5.1 source.
KidHorn is offline
post #14 of 17 Old 06-20-2012, 01:09 PM
jdsmoothie's Avatar
Liked: 7517
What does the front panel display read? You're getting DD PLIIx + A-DSX
234
post #15 of 17 Old 06-21-2012, 08:15 AM
KidHorn's Avatar
Liked: 982
234
I'm not quoting exactly but it states something like 'Audyssey DSX Wides + Heights'. I get sound from all 11 speakers,
KidHorn is offline
post #16 of 17 Old 06-21-2012, 08:24 AM
jdsmoothie's Avatar
Liked: 7517
Right ... so DSX is providing the Front Height/Wide audio and PLIIx is proving the Surr Back audio.
post #17 of 17 Old 06-21-2012, 12:03 PM
KidHorn's Avatar
Liked: 982
OK. Thanks for the info. I didn't realize I had multiple surround modes running at the same time.
KidHorn is offline
