Daisy chaining AV receivers and mono amps - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-19-2012, 12:54 PM - Thread Starter
MKan's Avatar
Hi, I'm trying to set up a bit of a confusing system at home and I was wondering if I go for the VSX-1122-K or similar AVR can I use the zone 2 output as a source, plug that into a mono amp and use it to spread the signal across a bunch of mono speakers I'm dotting around the garden?
The second thing is, is there any way I can hook up some sort of long range remote to change tracks etc. from the outhouse at the end of the garden?
Thanks a bunch,
M
MKan is offline
