The *Official* Onkyo TX-NR515 Owners Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 344 Old 07-31-2013, 10:47 AM
Lwood's Avatar
i bought this receiver one year ago. i am loving it. i am a big onkyo fan, this will be my Second onkyo.
i have a question that i couldnt figure out . or im just over looking it.
on the remote to turn on receiver by pressing a input button . for example the game, where the receiver will turn on with the game source . how do i activate that to work??
with my last onkyo i was able to press the input source and my receiver would turn on with what ever source button i pressed.
Lwood is offline
post #272 of 344 Old 08-05-2013, 04:22 PM
Lwood's Avatar
anyone know of a way??
Lwood is offline
post #273 of 344 Old 08-09-2013, 11:12 AM
Morten Bruun's Avatar
Hi Onkyo-people
Im having problems trying to update my firmware on my new Onkyo TX-NR525.
I have read the instructions, and i seem to have done them right.
THE problem is I can`t choose update via USB under setup..... it is not highlited....... and on Wired network, the line update via network is there but still not highlited....?????
so both lines are there, but can`t chooes them ????
How do i fix this.
my current firmware version is 1010-2110-0000
Please Help
Morten Bruun is offline
post #274 of 344 Old 09-14-2013, 02:44 AM
33coupe's Avatar
Hopefully someone can help me.
I used to be able to stream music from my laptop to the receiver. I could just go into my folders on my laptop, select a song and send/play to the nr515. It would create its own playlist that I could add to etc.
Im not sure what happened but I can no longer do this. Ive changed the streaming options in Windows Media Player, but the receiver is not being picked up / recognised by the laptop.
Ive uninstalled WMP and reinstalled, but to no avail. I can stream from my phone ok. I can also access the files from my laptop onto the receiver (client I think), but the userface isnt very user friendly, and would prefer to use it the other way around.
Does anyone have a suggestion on how it can be fixed?
Also, I have an external hard drive plugged into the usb port (for music), but can only play one album at a time.
Has anyone found a way to play random songs from all albums / folders?
33coupe is offline
post #275 of 344 Old 09-28-2013, 01:36 PM
djtoodles's Avatar
Quoted: 18 Post(s)
Ok so I have a few questions....
- Is there a way for me when I turn on the receiver to stop defaulting to tv/cd and make it an input that I choose?
- I have a samsung smartTV so in order to get audio from those apps I need to use an optical cable. I also plug in a bluetooth receiver into the tv/cd audio ports so I can listen to music while there is background tv going. Problem is the optical port takes priority over the audio ports so i have to unplug the optical cable for the bluetooth audio to work... Ideas?
- what do you guys use as the default preset option for sound? like the All stereo channels, neo6, etc... for movies, tv and music?
djtoodles is offline
post #276 of 344 Old 09-28-2013, 10:09 PM
33coupe's Avatar
I have set mine all to Dolby Pro Logic II, unless the signal is 5.1, then I use 'Straight Decode'. Its much better than 'All Stereo'
33coupe is offline
post #277 of 344 Old 09-29-2013, 03:20 PM
djtoodles's Avatar
Quoted: 18 Post(s)
what is straight decode? you mean direct?
post #278 of 344 Old 09-29-2013, 04:09 PM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
Hi djtoodles, no need to disconnect the optical cable. Just select "Analog" in the Audio Selector menu.
On the remote press Home button select Setup -> Source Setup -> Audio Selector -> Analog
JChin is offline
post #279 of 344 Old 09-29-2013, 04:38 PM
33coupe's Avatar
Nah, under Dolby D Dolby D Plus / True HD & the two below there is an option for 'straight decode'. Thats what I use.
33coupe is offline
post #280 of 344 Old 09-29-2013, 05:04 PM
djtoodles's Avatar
Quoted: 18 Post(s)
Yeah but then it needs to be changed every time I want to do one or the other.
post #281 of 344 Old 09-29-2013, 05:04 PM
djtoodles's Avatar
Quoted: 18 Post(s)
Where are you finding this?
post #282 of 344 Old 09-29-2013, 05:19 PM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
If nothing is assign to PC input, use it instead.
JChin is offline
post #283 of 344 Old 09-29-2013, 05:20 PM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
Its under Listening Mode Preset menu.
JChin is offline
post #284 of 344 Old 10-09-2013, 12:05 AM
c2h5oh's Avatar
The new firmware as of 1st oktober 2013 doesnt apply to this reciever I understand. Anyone got an idea if we are getting the new features aswell?
c2h5oh is offline
post #285 of 344 Old 10-23-2013, 09:37 PM
ebco's Avatar
Hi there.I have another Onkyo ampTX 8030 and was wondering if the was any way to connect my Nr 515 to it so I can run my front speakers off the 8030 and the others off the 515.I know the 515 has a bi amp feature but that reduces it to a 5.1 not a 7.1.Any advice would be grand!!
ebco is offline
post #286 of 344 Old 11-25-2013, 01:36 PM
toddbigeasy's Avatar
What kind of Wireless USB Adapter works good with this unit? I am viewing the Onkyo UWF-1 Wireless LAN Adapter on Amazon, but I am also seeing a few negative reviews. Does this one work?
thanks,
Todd
toddbigeasy is offline
post #287 of 344 Old 12-24-2013, 04:16 AM
PiwiKiwi's Avatar
I'm using this one:
http://nl.tp-link.com/products/details/?model=TL-WN722N
So far, so good. Had to do a manual configuration though, no biggie.
PiwiKiwi is offline
post #288 of 344 Old 01-21-2014, 12:37 PM
tspitzer's Avatar
I bought the Onkyo UWF-1 Wireless LAN Adapter from Amazon a couple weeks ago, and it seems to be fine. Cheap solution.
tspitzer is offline
post #289 of 344 Old 02-16-2014, 11:18 AM
FulhamRev's Avatar
On the "NET" menu, is it possible to add Netflix to "My Favorites", allowing me to access Netflix directly through my receiver?  Currently, I have to access Netflix via my Wii, which isn't ideal.
FulhamRev is offline
post #290 of 344 Old 02-16-2014, 11:44 AM
spunkyaz's Avatar
The NET source supports only audio playback including Internet radio and DLNA music servers on your local network..Netflix will not work.
The network function of the receiver also allows you to use an Onkyo smart phone app to control playback.
spunkyaz is online now
post #291 of 344 Old 02-19-2014, 10:27 AM
tmart512's Avatar
Randomly upon turning on my NR515 I will get audio but just a blank bright green screen. After selecting different inputs and or powering off the unit it will work. Has anyone had this happen to them before or have a thought on what might cause this?
tmart512 is offline
post #292 of 344 Old 02-19-2014, 01:22 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
What model is the Tv/Display?
What devices are connected into the Onkyo?
What order are you powering on the Tv, Onkyo, & source device?
Was this setup working good before and just started acting up, or has it always been like this?
While the screen is blank bright green, grab the original Tv remote and press MENU. Does the Tv menu look ok?
While the screen is blank bright green, grab the Onkyo remote and press MENU. Does the Onkyo menu look ok?
Things to try-
Pull power cords of Tv, Onkyo, source devices for 3 minutes.
Power on equipment in different orders.
Replace hdmi cables.
Update Tv firmware.
Update Onkyo firmware.
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #293 of 344 Old 02-19-2014, 02:10 PM
tmart512's Avatar
Things to try-
Update Tv firmware.
Thanks for the response and tips hammerdwn
I have a 55 inch Panasonic 3D TV, PS3,PS4, Apple TV,and a Directv box all hooked up via HDMI.
I use a Harmony One remote. So off the top of my head I don't recall the order that everything is powered on, but I do know that it is the same order each time the system is started.
My setup was working great from the start, then the last couple of months I noticed the green screen once or twice, and now twice in one week.
If this happens again I will open up the menu on the TV and Onkyo.
Usually it will correct itself if I change inputs and switch to my PS3 or Apple Tv and then back to TV so I was thinking this was a HDMI issue.
I have not updated my firmware with the last update from December 13. I will do that tonight when I get home.
Thanks again!
tmart512 is offline
post #294 of 344 Old 03-18-2014, 12:24 PM
zagman1's Avatar
Hello-
Helping a friend dial in his system at vacation home. We just updated to the latest firmware on the Receiver. He previously was not set up for passthrough (is that the correct term?). We hooked up HDMI cable to the HDMI input named "MAIN" on receiver, and the other end went to HDMI 1 on his TV. I then hooked up HDMI cable to the input on Receiver named "Cab/Sat" and the other end to the HDMI slot on his Dish Receiver
I then hooked up HDMI cable to the input named "BD/DVD" on Receiver and the other end to HDMI cable to the HDMI slot on Memorex Blu Ray player. (do not have model number?)
When I select CAB/SAT input on Onkyo remote, TV switches to that input and voila, I have a picture. When I plug iphone or ipod in front USB input on Onkyo, and select "USB" on Onkyo remote, I get the playlist, artist , album etc. showing up on tv screen, so that input works as well. However, when I turn on Blu Ray player and select "BD/DVD" on Onkyo remote, I only get a blue screen on the TV. (Initially, the words BD/DVD, or Blu Ray show up) but then just goes to Blue screen. Do you have any idea what is wrong? Are there any settings etc. that need to be set? Should I have him try a newer Blu Ray player?
Very frustrating as he had it set up so it all worked before, and then I came along and said "You know, there is an easier way to do this"....
Thanks in advance for your help!
Z
zagman1 is offline
post #295 of 344 Old 03-18-2014, 02:52 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
What happens if you plug the bluray player directly into the Tv (bypass the Onkyo)?
post #296 of 344 Old 03-19-2014, 06:09 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
come on , you know what happens, you get TV audio, and nothing from the AVR unless there is a digital coax or an optical connection from blue ray to AVR. Have to ask why bypass the AVR?
Phil17108 is offline
post #297 of 344 Old 03-19-2014, 07:44 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
It's a TEST not a solution. You suggested he replace the Bluray player but said nothing about checking if it is good when connected directly. That is rule number zero. Next is testing the hdmi cable (even if the cable is new) by getting a different one.
If you don't get anything out of those two TESTS then besides getting a blue screen, go into the INFO screen and see what comes up under audio/video signal format.
If you want specific settings in the bluray player then give us the full model number of the player.
post #298 of 344 Old 03-27-2014, 06:55 AM
Viper187's Avatar
Quoted: 43 Post(s)
WTF my receiver just suddenly decided to stop outputting audio entirely in the middle of using it. I've tried every input both HDMI and optical. Nothing. The HDMIs all show video fine, just no audio. I don't get it.
Viper187 is online now
post #299 of 344 Old 03-27-2014, 08:00 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
If you activate Test Tones, do you hear anything? What about AM/FM? Have you tried the simple stuff like pulling the power plug for 5 minutes? or doing a factory reset? do you have the latest firmware? Next would be disconnecting all speakers except one known good speaker and good speaker wire...
post #300 of 344 Old 03-27-2014, 10:00 AM
Viper187's Avatar
Quoted: 43 Post(s)
Nothing. Dead. Is it supposed to pass the HDMI audio through to my TV? Cause that doesn't happen either.
Onkyo Tx Nr515
