The *Official* Onkyo TX-NR515 Owners Thread - Page 11 - AVS | Home Theater Discussions And Reviews
post #301 of 329 Old 03-27-2014, 09:13 AM
hammerdwn's Avatar
Quoted: 105 Post(s)
Liked: 42
Turning speakers off and passing sound to Tv is on page 62 of the manual. MENU, SETUP, HARDWARE SETUP, HDMI, Tv Audio OUT - Off/On.
hammerdwn is online now
post #302 of 329 Old 03-27-2014, 09:25 AM
Viper187's Avatar
Quoted: 20 Post(s)
Awesome. That doesn't work either.
Viper187 is offline
post #303 of 329 Old 03-27-2014, 09:40 AM
hammerdwn's Avatar
Quoted: 105 Post(s)
Liked: 42
If you turn everything on so you get a picture on the Tv then on Onkyo goto quick menu, information, audio - does it tell you input name, input format, & output format? What does it say for input format?
post #304 of 329 Old 03-27-2014, 10:42 AM
Viper187's Avatar
Quoted: 20 Post(s)
Yes. Everything is accurate.
Viper187 is offline
post #305 of 329 Old 03-27-2014, 12:31 PM
hammerdwn's Avatar
Quoted: 105 Post(s)
Liked: 42
time for RMA and/or shopping for an upgrade
post #306 of 329 Old 03-27-2014, 12:55 PM
Viper187's Avatar
Quoted: 20 Post(s)
It's like 3 years old. I'd say RMA is out.
Viper187 is offline
post #307 of 329 Old 05-31-2014, 02:54 PM
tspitzer's Avatar
Has anybody seen/solved this problem?
1. With most inputs (take NET or PC as examples), I cannot change the audio mode. When I press one of the audio mode buttons, the receiver display shows the message "Not Available".
2. In the Quick Setup options I cannot get to the "Audio" menu. The cursor skips over it.
3. In the full Setup (Home) menu, I cannot get to the Speaker settings. The cursor skips over it.
This has been going on for months. I'm tearing my hear out. I actually have two of these receivers, and one of them behaves as I would expect it to, but the other is acting .... weird.
I've tried to compare all the settings to see if I have done anything differently but I cannot figure it out.
Thanks for any suggestions.
tspitzer is offline
post #308 of 329 Old 05-31-2014, 03:42 PM
hammerdwn's Avatar
Quoted: 105 Post(s)
Liked: 42
Factory Reset yet?
Both units have same Firmware?
post #309 of 329 Old 05-31-2014, 11:04 PM
tspitzer's Avatar
Yes to the firmware.
No to the reset. Guess I'll try that and start over.
... hour later. OK, done. It worked. Thanks for the push. I knew I needed to do that but the thought of reentering all those passwords through the on-screen keyboard kept me looking for another solution. rolleyes.gif
Why can't it display passwords? Its past midnight, and there's no one looking over my shoulder!
thanks.
tspitzer is offline
post #310 of 329 Old 08-14-2014, 04:58 PM
Liked: 0
tspitzer,
Did that fix work for you very long? I'm having the exact same problem, but it recurred shortly after my reset. I tried it again, but no joy this time. I'm worried it's truly dead.
Anyone else have any ideas?
Michael Laxton is offline
post #311 of 329 Old 08-14-2014, 09:40 PM
tspitzer's Avatar
Red face have not had to reset again
Michael, it has been stable since that 6/1 reset.
Sorry to hear it didn't work for you.
tspitzer is offline
post #312 of 329 Old 08-15-2014, 04:45 PM
Liked: 0
Thanks, glad to hear your's is still working. It gives me some small hope that I might get it fixed.
post #313 of 329 Old 08-17-2014, 03:05 AM
Quoted: 53 Post(s)
Hello. Does this unit Full Mono mode retain the full dynamic range or is a limiter applied? Is there a volume level attenuation in Full Mono and how much?
luca_frontino is offline
post #314 of 329 Old 08-31-2014, 04:07 PM
33coupe's Avatar
Just a quick post to say that after 1.5 years problem free my NR515 has failed me
Looks like the HDMI Out stopped working. Luckily a factory reset fixed the problem. Fingers crossed it doesnt happen again.
33coupe is offline
post #315 of 329 Old 09-06-2014, 03:00 PM
Finsta's Avatar
Hey there,
Was hoping someone can help me out. I have a HD shared via USB through my Asus RT-AC66R router, when I go to my NET preset on the 515 I am able to access the drive through the Home Media app but not through the DLNA app, also it's not seeing my playlists which are saved in both .m3u and .wpl extensions.
I'd appreciate any insight.
Finsta is offline
post #316 of 329 Old 09-27-2014, 02:47 PM
copterdrvr's Avatar
What do I have to do to get the audio that's passing through the 515 to the house surround speakers to pass to the speakers of my Samsung tv via the HDMI connection?
My cable box is connected to the TV via HDMI and the sound output is normal as would be expected-I'm confused as to why the audio from the BluRay to the 515 is not being passed to the TV.
copterdrvr is offline
post #317 of 329 Old 11-06-2014, 10:48 AM
DragonQ's Avatar
Has anyone else had a firmware update of this machine recently? I've been running the 03/12/2013 firmware (1161-3110-0500) since early 2014 (installed via USB) and yesterday the AVR told me there was a firmware update and it was installed via the internet. It now has version 1161-3110-0300, which means it's downgraded itself. Maybe this old version was made available for auto-update by mistake?
Aren't you describing two different things here? If you have:
Cable Box --> TV --> AVR
then the TV can play the audio if you disable the AVR, and the AVR can play the audio if you're using an ARC-enabled HDMI socket on your TV (you might need all the auto-HDMI-detect fancy stuff enabled too).
However, if you have:
BD Player --> AVR --> TV
then the TV will never see the audio, as I understand it. I have always assumed that AVRs in general only pass through video because, after all, their main purpose is to deal with the audio side of things.
DragonQ is offline
post #318 of 329 Old 11-24-2014, 10:31 AM
Liked: 0
Hey guys...there's a recall on the NR515. Hit up Onkyo's site. They are sending me a paid shipping box to send mine back for repairs. Warranty is not an issue.
Cootmo is offline
post #319 of 329 Old 11-26-2014, 07:09 PM
megabyzus's Avatar
TX-NR616 blew Dayton Audio BS36 36" LCR Speaker Bar Black?
Any thought's on my question below greatly appreciated (I know the 616s are under new special warranty):
Question: Can a faulty 616 blow my Dayton Audio speaker bar? I never blast and rarely use the system.
Summary:
I own a Dayton Audio speaker bar with 3 internal speaker pairs connected to the right, center, left audio outs of the 616.
1. Suddenly noticed recently no audio from the 616 through the Dayton Audio BS36 36".
2. Finagling with the 616 remote and switching it on and off, sound returns randomly but only in the center speaker pair on the bar.
Two days pass, switch on the 616 again no sound again. Also no network OR USB indicators on the 616 setup screen. Called support and confirmed the 616 is broken. I hang up and switch on the 616 and the sound is back again and again on the center internal speaker on the bar.
I decide to rotate the wires on the speaker and notice that ALL the 616 audio outputs are working and the SPEAKER's left and right pairs are in fact damaged somehow (to reiterate the 616's audio is randomly working properly at this point). So there are two broken items: the 616 and the Dayton Audio speaker bar.
BTW, both are under warranty so I can replace them.
megabyzus is offline
post #320 of 329 Old 11-27-2014, 07:12 AM
Liked: 0
Got a link? I don't see anything about a recall
mantekka is offline
post #321 of 329 Old 11-28-2014, 11:31 AM
megabyzus's Avatar
Summary:
Bumped up.
post #322 of 329 Old 12-11-2014, 02:43 PM
rickinyorkshire's Avatar
Liked: 0
Hi All!
I've recently purchased this amp - i have some small Onkyo speakers but i don't have a subwoofer - can anyone recommend one for say £100?
This thread is fantastic btw
rickinyorkshire is offline
post #323 of 329 Old 12-26-2014, 11:43 AM
YouWantMYUserNAm's Avatar
Done with this thing. Anybody want it?
Bought mine about 27 months ago. Been a PAIN in my side ever since. Developed a known issue of needing to be power cycled all the time to temporarily fix an issue with no video being sent to television. Installed the every couple week firmware update that was to resolve the issue but it never did. I kept a power strip accessible with only the unit plugged into it just for this purpose. The use of wireless with the onkyo usb adapter was never stable enough for actual use. A separate issue was/is video would cut in and out while watching so frequently that I ended up just buying a Yamaha Aventage 1020 and putting this thing in the kids play room to run games and TV. That was about 6 months ago and recently the audio just stopped working. Dead. Video still processes. Tried hard reset then a firmware update but the USB ports are no longer functioning. Used the same USB stick as always and the light doesn't even turn on. So yeah, I'm done. I'm not sending it to a service repair place and trying to get it replaced under warranty. Not worth it to me given the history. Someone about a month ago on this thread mentioned that there was a recall on Onkyo's website but the page I found didn't have the TX-NR515 as one of the models affected.
So any ideas? Anyone want a unit for parts?
YouWantMYUserNAm is offline
post #324 of 329 Old 12-27-2014, 01:42 PM
Repair Submission Form
Corrected. I did finally find the right place to request repair and on this forum.
won't let me post link so... this forum thread named...
1652514-onkyo-acknowledges-failed-units-extending-warrranties-until-2018-a
This form accepted my serial number for the 515. We'll see how the repair process goes.
post #325 of 329 Old 03-02-2015, 10:01 AM
Liked: 2
how did the repair process go YWMUN ??
what firmware version did it come back with ?
http://www.intl.onkyo.com/support/fi.../tx-nr515.html
Notice of Firmware Update for TX-NR515 / TX-NR515AE / HT-R791
A firmware update for the TX-NR515 / TX-NR515AE / HT-R791 network A/V receiver is available through the unit’s network connection or USB input. The latest update includes the following content:
Latest Firmware Number (12 digits):1171-6110-0500 (TX-NR515 and HT-R791)
Latest Firmware Number (12 digits):1171-6110-0501 (TX-NR515AE)
As of 18 December 2014
pcourtney is offline
post #326 of 329 Old 03-02-2015, 10:22 AM
I didn't check the firmware but it was returned in working order. Haven't had any issues with it yet.
post #327 of 329 Old 03-02-2015, 10:33 AM
Liked: 2
I upgraded to get Spotify Connect support ( finally ) , and Spotify in the kitchen using Zone 2 :-)
http://www.pocket-lint.com/news/1323...does-it-matter
Support for Spotify Connect
Spotify Connect can be supported by updating the unit’s firmware. To enable Spotify Connect, install the Spotify application on your smartphone or tablet first. Then, create a Spotify premium account.
For details on getting Spotify, refer to: www.spotify.com/connect/
Simply clicking the Connect icon and selecting the unit on the playback screen of Spotify application will automatically turn on the unit (Auto Power On function), with the “NET” selected as the input, starting a high quality music streaming service. Be sure to set “Network Standby” to “ON” in the “Setup” menu to enable the Auto Power On function.
Notes for using multi-zone function with Spotify Connect
To enjoy Spotify music in a separate room, select a ZONE you desire, then manually specify “NET” as the input of the
ZONE. Finally, select the unit on the Spotify application.
Volume adjustment with the Spotify application is possible only for the equipment connected to the ZONE2/3 speaker
terminals and ZONE2/3 PRE OUT terminals (compatible model only - Set “Zone2/3 Out” to “Variable” in the “Setup” menu.).
If any other terminal is used for connection, adjust the volume on the audio equipment placed in a separate room.
To enjoy Spotify music in the main room after playing it in a separate room, select “NET” as the input of the main room.
Note: It’s not possible to control your connected devices from the desktop app for Mac and Windows, but that functionality is coming real soon according to Spotify. It's also not possible for Connect to play any local files on any device, which is to be expected, that's not how they roll !
post #328 of 329 Old 04-02-2015, 01:52 AM
Liked: 0
I've intermittently encountered the issue where no video was output (unplugging from the mains solves this temporarily each time) and have now come up against the missing audio and Network menu, which sometimes goes away after a few power cycles but is generally a massive problem.
So I've just started the process to get this repaired - will keep you all updated.
Was looking forward to trying out the Spotify Connect feature that I've only just realised is now available as well
StixxUK is online now
post #329 of 329 Unread Today, 01:43 AM
Liked: 0
So I started the process on Thursday, someone came to collect it on Saturday. So far so efficient! Now to see how long the repair itself takes (and obviously make sure it gets completely fixed)...
Onkyo Tx Nr515
Gear in this thread - Nr515 by PriceGrabber.com
