The *Official* Onkyo TX-NR515 Owners Thread - Page 12 - AVS Forum | Home Theater Discussions And Reviews
post #331 of 346 Old 07-04-2015, 06:33 AM
Liked: 0
Can't control volume--too loud
Glad to see this thread is still alive. I just picked up the 515 used off Craig's List after having the owner do a demo of the unit, and all seemed to work well. Got it home, did a factory reset, made all the connections, and zero sound except from Pandora, which comes out at full-blast (master volume knob doesn't adjust)--the only way to kill the audio is to switch input or turn off the unit. This happens with each main speaker (tested individually--not touching the sub yet). Another oddity: the center channel sets itself to full when the master volume is set to "min," but at 1+, it behaves normally (I assume--still can't get a signal through, just hearing the "fuzz" of a maxed-out speaker).
FWIW, all video connections (so far) work--I haven't changed my Xbox360 output resolution yet--but audio is throwing me here. It's annoying that I can set up and run a concert audio rig in my sleep (17 years of doing that), but home theater audio is all "durrrrrr".
Audio Output Setup:
--C - Klipsch KCS-C1
--L/R - Cerwin Vega D-3
--Sub - Elan THP1200SW
Inputs:
--HDMI 7 - Chromecast (video good)
--HDMI 6 - AppleTV (video good)
--RGB - Xbox360 (not tested yet)
--TV - not tested yet
--Ethernet - Pandora audio works but no volume control (set to max)
Thanks in advance for any feedback.
soundsmithCLT is offline
post #332 of 346 Old 07-30-2015, 10:54 AM
christoofar's Avatar
Quoted: 262 Post(s)
Liked: 166
Recently got a used TX-NR515, it had the network dropping/audio issue, went onto the Onkyo forums & found out about the extended warranty offer if serial number qualified, mine did, so I sent it in & they repaired it for free.
Connected it to my Tosh Regza 55SV670U set & speakers, and all is working fine...except...the TV is turning itself off after a time. I have a WD Live SMP, and a Chromebox running openelec, and whether playing music or video, at some point it...just...turns..off. I have pored thru both manuals and setting of TV & AVR , but can't find anything that would cause this.
Anyone suggest something to look for? This is driving me batty.
christoofar is offline
post #333 of 346 Old 08-20-2015, 09:43 AM
Liked: 0
The repair for the no sound/network was QUICK. Sent my receiver off Tuesday, they got it last Thursday, and shipped it back Friday and I got it back Tuesday and had everything set back up last night.
Still have to get used to the way DirecTV does the audio becasue when I had uVerse it would be DD 5.1 and I had it set to output in DTS Neo6 and now when I see the input/output it says 7.1 multichannel PCM/7.1 Multichannel and it seems like my center channel is getting drowned out more by the L/R channels than it used to. Also I have to raise the volume higher than I used to with uVerse.
Looking forward to more time with this receiver since it suits my needs perfectly now
El Beaner is offline
post #334 of 346 Old 08-20-2015, 04:25 PM
frantic1049's Avatar
Quoted: 22 Post(s)
Just ordered the packing materials & shipping label to send mine back tonight. I hope I also get a quick turnaround but I don't look forward to getting it all set up the way it was before.
frantic1049 is offline
post #335 of 346 Old 09-05-2015, 11:12 AM
Quoted: 22 Post(s)
One week turnaround for no sound repair. What a pain having to get it setup all over again, but glad it was repaired. When first connnected it kept shutting off but support got right back to me & suggested disconnecting speakers & unplugging for one hour and so far so good.
post #336 of 346 Old 09-13-2015, 01:45 PM
Quoted: 22 Post(s)
Well, "repaired" receiver will not stay on. Have to send it back again. What a pain. We've been without it nearly a month now.
post #337 of 346 Old 09-25-2015, 09:28 AM
Bill Milford's Avatar
Question Is this the symptom of the network recall?
The HDMI audio will not output at all on any input. Analog audio can still be selected and it works. Excessive clicking when fast forwarding on DVR and sometimes it will work if you power cycle the receiver?
Bill Milford
Working for Toshiba - TAEC not TACP.
Bill Milford is offline
post #338 of 346 Old 09-26-2015, 07:25 AM
Quoted: 22 Post(s)
Not exactly what happened to mine. Never checked with analog audio.
Have you gone to the website & entered your serial number?
post #339 of 346 Old 09-26-2015, 02:54 PM
I will check it soon. I cannot read it easily where it is installed.
Bill Milford
post #340 of 346 Old 10-18-2015, 02:04 PM
itm2's Avatar
HDMI auto-switching not working after board replacement
My TX-NR515 has just been repaired, having had its HDMI board replaced. Since I got it back I've noticed that it no longer automatically switches to my Chromecast HDMI source when I cast something to it. I now need to manually select the HDMI source that the Chromecast is connected to. Does anyone know why this might be, and whether there is a way of restoring the previous behaviour?
itm2 is offline
post #341 of 346 Old 11-05-2015, 08:15 AM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 57
No audio on any inputs just hit my unit. Serial number is covered by recall. After it comes back from repair, I will be buying new/other AVR and selling this off, mostly to upgrade to 4K hdmi 2.0 hdcp 2.2 and better Audyssey level.
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is online now
post #342 of 346 Old 12-03-2015, 08:38 PM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 57
Unit back from repair and is up for sale. $200 + shipping. PM any offers.
post #343 of 346 Old 12-18-2015, 07:59 PM
THS89's Avatar
Mine just died. Looks like it needs repairs.
THS89 is offline
post #344 of 346 Old 12-29-2015, 07:37 AM
Rajdawg73's Avatar
so i am having trouble figuring out what listening modes to use.
I have the TX-NR515 setup as a 5.1 setup
when just watching TV should I use All CH Stereo or something else
What about when I am watching a movie that has Dolby Digital sound what should I set the receiver too?
Rajdawg73 is offline
post #345 of 346 Old 06-16-2017, 11:42 AM
bwillcox's Avatar
Quoted: 484 Post(s)
Liked: 270
I'm trying to get my TX-NR515 to play music from a USB drive while displaying different video. Can anyone give me a clue on how to do this?
Bob
1) JVC DLA-X750, Yamaha CX-A5100, Outlaw Audio 7900 & 7700, Oppo UDP-203, Roku 4, Sony HAP-Z1ES
2) Sony XBR-75Z9D, Yamaha RX-A3070, 2xOutlaw Audio 2200s, Oppo UDP-203, Roku Ultra, Sony HAP-Z1ES
3) Sharp LC-70UH30U, Yamaha RX-A2050, Oppo BDP-103, Roku 4
bwillcox is offline
post #346 of 346 Old 08-30-2017, 07:03 AM
TrendyGUy's Avatar
Quoted: 42 Post(s)
Has anyone used the ARC functionality of this receiver? I have a Samsung UN65KS8000 and wondering if I would be able to use the ARC output from the TV with the receiver?
TrendyGUy is offline
Onkyo Tx Nr515
