TX-NR3010 / 5010 Info - Page 38 - AVS Forum
 2Likes
post #1111 of 1118 Old 08-19-2014, 05:45 PM
turnne1's Avatar
Quoted: 274 Post(s)
Liked: 76
Originally Posted by SeekingNirvana View Post
I am actually a owner of a 3009, but I also follow this thread. I follow this thread because the activity on the 3009 is slow and being the 09 and 10 units are mostly the same.
I just took the 3009 out of my system to send in for repairs. I've owned it for a year and a half, but started to have problems about a year in. I called tech support and they ran me through a bunch of tests, and over the phone they determined the HDMI board was starting to fail.
Fwiw
thats been the story for years now
I have a 5009 that may have ...like 6 hours on it
It was a warranty replacement for a 905 that had failed a few times
During the course of all the back and forth I went ahead and bought another receiver
then they decided they were replacing the Onkyo 905 with a new 5009 unit
In the closet it sits
Warren
Rm 1 Samsung 64F8500 Onkyo 5508 prepro Sherbourn 5/1500A amp Atlantic technology System 350 THX Ultra speakers
Rm 2 LG 47LE8500 Pioneer SC37 Celestion 305 speaker system
Rm 3 Samsung 51E8000 Yamaha A2010 Kef 2005.2 speaker system
Rm 4 Panasonic 50ST50 Onkyo 5009/906 Mirage Omni sat speaker system
turnne1 is offline
post #1112 of 1118 Old 08-19-2014, 05:53 PM
Quoted: 44 Post(s)
The X010 models seem to be the year they fixed their HDMI board issues...or at least we should be proving that around now.
htpcforever is offline
post #1113 of 1118 Old 08-20-2014, 02:30 AM
cablebandit3's Avatar
Originally Posted by ClawAndTalon View Post
I've got my eye on the 3010. Amazon has it at $1300 which I believe is a steal for what you get with it.
My other thought was the Denon x4000. The Onkyo seems better in all respects for the same price.
Does anyone use the THX setting? Difference?
Thoughts?
I have both and enjoy the X4000 better. The hdmi switching is much more solid on the x4000. The 3010 does have more features and a better gui
cablebandit3 is offline
post #1114 of 1118 Old 08-20-2014, 02:32 AM
My 3010 is at Onkyo now for hdmi issues. I dont think it is an inherit problem with the 3010 but a problem of having cable tv line grounded.
post #1115 of 1118 Old 08-20-2014, 08:04 AM
ClawAndTalon's Avatar
Quoted: 62 Post(s)
Liked: 100
So does your 3010 have a lag or drop signals with HDMI? Explain?
Also what about the power differences? Do you feel that the Onkyo is more powerful?
ClawAndTalon is offline
post #1116 of 1118 Old 08-20-2014, 08:41 AM
The hdmi on the Onkyo just seems to take awhile to sync while the Denon does not and the denon acts like the hdmi switching/syncing is very solid.
As far as power, I believe on paper that the 3010 has more power....i forget the specs. I use an external amp to power my fronts so I am not able to tell a difference in power as my center/surrounds are very efficient Klipsch speakers which dont take a lot to power.
When I get the 3010 back, I will run it in place of the x4000 a bit and see what my impressions are and report back. I should have it back within a week or 2 according to Onkyo. Again, I don't THINK the 3010 has hdmi issues like the 3007 it replaced. It seems that not having the cable splitter/feed grounded probably zapped the hdmi port during a storm. I just got my x4000 back for hdmi board replacement, as well as changing out the motherboard on my htpc because it lost hdmi at the same time. I lost an hdmi port on my tv as well when the 3010 lost hdmi and the only thing I find consistent is the Comcast wasnt grounded when I lost hdmi. I DO think the 3007 actually had a design problem...3010 I dont think so YET.
post #1117 of 1118 Old 08-20-2014, 05:57 PM
turnne1's Avatar
Quoted: 274 Post(s)
Liked: 76
the 3010 is more comparable to the Denon 4520...if you were cross shopping brands
Warren
turnne1 is offline
post #1118 of 1118 Old 08-20-2014, 06:00 PM
turnne1's Avatar
Quoted: 274 Post(s)
Liked: 76
actually in 6 -12 months would be a better litmus test
the XX09 models are starting to fail now
if its the same deal next year with the XX10's...we will know nothing has really changed
Warren
turnne1 is offline
User Tag List
