AVR1912 Pandora "cannot connect" message - AVS Forum | Home Theater Discussions And Reviews
Old 06-22-2012, 11:32 AM - Thread Starter
liunam's Avatar
Hi,
I have an AVR1912 and could not get Pandora to work on it. Searched the forum and did the network reset, microprocessor reset, and 10-minute disconnect trick but nothing worked. When I select Pandora, the "Authenticating" message appears briefly and then a "cannot connect" message pops up. Internet radio works and Pandora works on my other devices.
I emailed Pandora and they told me to contact Denon and when I called Denon, they told me that it was a Pandora issue since the internet radio option works. The guy at Denon also told me that they are "getting the same error on their test box" so Pandora must be down. I asked to speak to a supervisor since I would not accept his explanation and after a long wait he told me that they will get in touch with Pandora and they will give me a call back. I doubt that they will call me back but I do plan to follow up next week.
Anybody has any other ideas to get this to work? I'd rather not turn on my DVD player and TV just to be able to listen to Pandora.
liunam is offline
Old 06-22-2012, 01:20 PM
jdsmoothie's Avatar
Quoted: 12138 Post(s)
Liked: 5527
Not sure what you're expecting if Denon is getting the same issue?
There's a dedicated thread for Denon XX12 Owner's you might also want to check out.
jdsmoothie is offline
Old 06-22-2012, 03:23 PM - Thread Starter
liunam's Avatar
I did not think that it was a Pandora issue because it works on all the other devices (including the BluRay player that is connected on the same router as the Denon).
liunam is offline
Old 01-26-2013, 03:22 PM
soonerfann's Avatar
Getting this same error message on both 3312 in my house. Pandora working on a PC on the same network, so I don't believe it is a network issue.
soonerfann is offline
Old 01-26-2013, 06:14 PM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 757
Have you done the firmware update that fixes the Pandora connection problem?
http://usa.denon.com/us/news/pages/newsdetails.aspx?newstype=news&newsid=89&year=2012
Afro GT
afrogt is online now
Denon Avr 1912 Receiver
