Marantz SR6006 vs. SR6007: Dual PLL Anti-jitter Circuit - AVS Forum | Home Theater Discussions And Reviews
Old 06-25-2012, 09:05 AM - Thread Starter
JayNYC's Avatar
Hi. The SR6006 spec sheet lists "Dual PLL Anti-jitter Circuit" as a feature, but the SR6007 spec sheet does not.
Spec sheet SR6006
http://us.marantz.com/DocumentMaster/US/SR6006_noxm.pdf
Spec Sheet SR6007
http://us.marantz.com/DocumentMaster/US/SR6007_0511.pdf
Can anyone confirm, with 100% certainty, if the SR6007 has the Dual PLL Anti-jitter Circuit?
Thank you
--jay
JayNYC is offline
Old 07-03-2012, 02:48 PM - Thread Starter
JayNYC's Avatar
if anyone else is curious, Marantz responded:
Code:
Subject
Discussion Thread From Submitted Question
Response Via Email(NJ Customer Service & Support) - 07/03/2012 02:42 PM
Hello Jay,
The SR6007 does not feature a Dual PLL Anti Jitter Circuit as the SR6006 did. The SR7007 would be the only receiver out of the new lineup to incorporate that feature.
Thank you,
Technical Support / Custom Install
D&M Holdings NA
JayNYC is offline
Old 07-03-2012, 11:40 PM
crisliv's Avatar
Hi JayNYC,
So what is the impact of that? What was this "Dual PLL Anti Jitter Circuit" for? Is it a great loss?
crisliv is offline
Old 07-03-2012, 11:47 PM - Thread Starter
JayNYC's Avatar
jitter is a major issue in digital audio; however, the benefit of this circuit will largely be system dependent.
JayNYC is offline
Old 07-03-2012, 11:58 PM
crisliv's Avatar
So, if I understand well, this impacts audio quality? Or is it related to lip-sync and making sure audio and video clocks are accurately similar?
Thanks for your answer!
crisliv is offline
Old 07-10-2013, 05:30 AM
Femke's Avatar
Hi I talked on the phone for a long time with technical support in the Netherlands. They said that only in the model SR5007 no clock jitter reducer, but it does not affect the sound in general.
Femke is offline
Marantz Sr6006 Av Receiver
