Test Tones - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-28-2012, 06:23 AM - Thread Starter
merpud1's Avatar
I have an Onkyo 706 Receiver and would like to run the test tones
through all of the speakers as a stand-alone test without having
to run through the calibration/setup process. Is that possible and
how would I do it?
Reason: No sound is coming out of rear center speaker. It used to
but I had to disconnect it during the Holidays and now I do not get
any audio from it and I want to be able to run the test tones.
Many Thanks for any information..
merpud1 is offline
post #2 of 6 Old 06-28-2012, 06:43 AM
jdsmoothie's Avatar
Quoted: 15074 Post(s)
Liked: 7274
Did you reconnect it to the Surr Back (L) speaker posts as required? Otherwise check for a "Level Calibration" section in the Owner's manual.
jdsmoothie is offline
post #3 of 6 Old 06-28-2012, 06:51 AM
hakstone's Avatar
Check to see it is selected/on in setup. Maybe you disabled it when disconnected.
hakstone is offline
post #4 of 6 Old 06-28-2012, 07:15 AM - Thread Starter
merpud1's Avatar
Thanks for the information.
The wires were reconnected.
I will do a calibration check for that speaker.
Is it possible to send the test tones through the
speakers without doing anything else?
merpud1 is offline
post #5 of 6 Old 06-28-2012, 07:17 AM - Thread Starter
merpud1's Avatar
Maybe it did get disabled. That's a good thought.
I'll check.
Many Thanks...!!!!
merpud1 is offline
post #6 of 6 Old 06-28-2012, 07:30 AM
hakstone's Avatar
Most receivers have a speaker identification test pattern.
Go into 'speaker setup, then 'calibration'.
hakstone is offline
