Denon AVR-588 help - AVS Forum | Home Theater Discussions And Reviews
Old 06-28-2012, 11:35 PM - Thread Starter
deboardfam's Avatar
I am checking out a Denon AVR-588 for a buddy who is having an issue. It is giving white noise and a distorted popping sound. I verified is a good audio input, also tried different speakers. Still having the same issue. Do I have many options or should we be looking for a local tech who can work on it? Is it really worth fixing? It looks like a really nice receiver, older, but a 7.1 with an extra zone channel as well.. Thanks for your help / input.
deboardfam is offline
Old 06-29-2012, 04:39 AM
jdsmoothie's Avatar
Quoted: 12105 Post(s)
Liked: 5508
Is this issue with all sources and all type audio tracks? Try resetting the microprocessor (see Owner's manual p. 38). Also try swapping out the HDMI cables.
jdsmoothie is offline
Old 06-29-2012, 08:00 AM - Thread Starter
deboardfam's Avatar
I tried two hdmi and a composite and got the same issue he was having at his house so that's a different source. I'll try resetting the processor after vacation. I'll have to look up the manual, he didn't give me one.
Old 06-29-2012, 08:08 AM
jdsmoothie's Avatar
Liked: 5508
If resetting the microprocessor doesn't resolve the issue, he's likely better served replacing it with a newer model. This was the lowest level model and does not have Audyssey MultEQ which would likely provide a marked improvement in audio quality. Getting a clearance sale on either last year's 1612 or 1712 would be a nice upgrade.
247
Another option would be buying a refurb model ...
http://www.accessories4less.com/make-a-store/item/DENAVR1612/DENON-AVR-1612-5.1-Channel-A/V-Home-Theater-Receiver/1.html
Old 06-29-2012, 08:26 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi deboardfam, give this a whirl ... remove receiver cover and dust off the interior with compressed air. Just note to power off completly, unplug all cables including power cord.
JChin is offline
Denon Avr 588 Dolby Digital Surround Receiver
