Denon AVR-2312CI remote prgramming - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-30-2012, 10:38 AM - Thread Starter
MontereyJake's Avatar
I find it hard to believe that none of my components are compatible with the AVR 2312CI remote. I cannot get any to work following the setup instructions.
Includes Motorola cable box, & LQ B-R player
Any thoughts?
MontereyJake is offline
post #2 of 9 Old 06-30-2012, 12:23 PM
jdsmoothie's Avatar
Quoted: 15333 Post(s)
Liked: 7488
There are generally multiple codes for each brand .... did you try them all via the procedure listed in the Owner's manual?
jdsmoothie is online now
post #3 of 9 Old 06-30-2012, 03:23 PM - Thread Starter
jdsmoothie "There are generally multiple codes for each brand .... did you try them all via the procedure listed in the Owner's manual?"
Yup, but I'm not sure I'm doing it correctly. The instructions say to
1) push input: I've tried the button dedicated to e.g. the TV, and I've tried it pushing the Input Selection 1st;
2) hold "On" button for 3 sec.: which ON button? I 've tried the red upper right AVR ON, the Stand-by, and the dedicated e.g. TV button;
3) Enter the code:seems straight forward;
4) Push a function for the component such as ON: so I've tried the AVR ON after re-pushing the dedicated component button.
The TV, Samsung LED, and LQ Blu-ray are pretty new - .5 & 2.5 years respectively.
Thanks for any further clarification on the correct buttons.
post #4 of 9 Old 06-30-2012, 03:35 PM
jdsmoothie's Avatar
Liked: 7488
The below picture of the remote control on p. 120 shows the Zone/Device | button to press/hold ....
214
post #5 of 9 Old 06-30-2012, 04:19 PM - Thread Starter
Thanks JD, got the remote programed.
Next I'll tackle the zone2 remote speakers solution.
Really appreciate your help, guess I'll keep it after all (well the thought crossed my mind B4 my son suggested this forum).
post #6 of 9 Old 06-30-2012, 04:52 PM
afrogt's Avatar
Quoted: 1432 Post(s)
Liked: 982
LQ Blu Ray player? You typed that twice now. Did you mean LG?
Afro GT
afrogt is offline
post #7 of 9 Old 06-30-2012, 05:19 PM
Stilly77's Avatar
214
That is where I got confused with the 3312 remote when setting up the AVR.
I kept hitting the upper "I" button and never seen the 2 flashes.
I read the book and saw it was exactly as you posted above.
I was too used to my Pioneer remote, where you select your source and use the upper button to turn on and off the source.
Stilly77 is offline
post #8 of 9 Old 07-01-2012, 06:45 AM - Thread Starter
Yes, LG. Just got a bit frustrated I guess. It is all set up now.
post #9 of 9 Old 07-01-2012, 06:48 AM - Thread Starter
Following the setup wizard led to my confusion. Set-up wizard did not make clear which buttons. To make matters worse, the CD the manual came on does not load. I've since downloaded it on-line.
Denon Avr 2312ci Receiver
