need help - AVS Forum
post #1 of 7 Old 07-01-2012, 12:46 AM - Thread Starter
Seanyj's Avatar
I have the amp 5.1 set up at one end of my room for movies and a set of speakers at the other end of room for music, can anyone tell me how to enable switching of the speakers please.
Seanyj is offline
post #2 of 7 Old 07-01-2012, 03:30 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 274 Post(s)
Liked: 1302
What model AVR do you have? If it has a Front A and Front B option, then you can connect the music speakers to the Front B speaker posts and select Front B for STEREO mode only.
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - AVSForum sponsor for 15 years
Mon - Fri: 8am – 8pm EST (Sat/Sun, leave message)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Oppo, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #3 of 7 Old 07-01-2012, 04:05 AM - Thread Starter
Seanyj's Avatar
Yea sorry forgot to put the model, it is the Marantz SR6004
Seanyj is offline
post #4 of 7 Old 07-01-2012, 05:10 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 274 Post(s)
Liked: 1302
So then, yes, the SR6004 does have Front B speaker posts (see image below) to which you can connect the music only speakers.
154
Use the "Spkr A/B" button on the remote to select "A, B, or A+B" speakers.
220
post #5 of 7 Old 07-01-2012, 06:03 AM - Thread Starter
Seanyj's Avatar
Thank you very much for this, one more question must this be biwired, my speaker wires are buried in wall so hoping not, the confusing instructions suggest biwired, hoping not
Thanks again
Seanyj is offline
post #6 of 7 Old 07-01-2012, 06:17 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 274 Post(s)
Liked: 1302
No, simply connect the music speaker wire connections to the Front B L/R speaker posts.
post #7 of 7 Old 07-01-2012, 08:04 AM - Thread Starter
Seanyj's Avatar
All done thanks again working perfect.
Seanyj is offline
User Tag List
