Emotiva XPR-5 - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #271 of 277 Old 01-22-2016, 04:31 AM
steady teddy's Avatar
Quoted: 97 Post(s)
Liked: 49
Just had a fault condition on channel 1 after shutting down my HT system this morning.
I'm no longer using that channel either so I can rule out a bad speaker connection. Damn!
Gonna call Emotiva later.
steady teddy is offline
post #272 of 277 Old 01-22-2016, 07:14 AM
DonH50's Avatar
Quoted: 1795 Post(s)
Liked: 1330
So nothing connected on the input to Channel 1?
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #273 of 277 Old 01-22-2016, 07:23 AM
Quoted: 97 Post(s)
Liked: 49
Nope
post #274 of 277 Old 03-28-2016, 05:25 AM
t-well's Avatar
Quoted: 20 Post(s)
How is the situation of your xpr-5 today?
Studying English Language, Thanks for Understanding.
Panasonic VT 60 -----------------Space 120" Sound-Transparent Screen.
Emotiva XMC-1-------------------Emotiva XPA-5
Svs SB 13 ULTRA (x2) -----------Klipsch RP-280F- Klipsch RP-450C- Klipsch RP-250S
t-well is offline
post #275 of 277 Old 03-28-2016, 11:13 AM
Quoted: 97 Post(s)
Liked: 49
No fault conditions lately. Emotiva said it was nothing to be alarmed about, unless it happens repeatedly. Perhaps it was static electricity from the dry weather conditions during the Winter. I also noticed this past week as I was installing all new speaker wire that the binding post is loose on that same channel. I never paid attention since I've always used banana plugs until now. Not sure if there is a correlation between the two issues since I wasn't using that channel when the fault occurred. I have two free channels on the XPR-5 anyway as an ATI 6002 is now powering my mains.
On a side note, I have swapped my old rack for a Mid Atlantic Slim 5. I don't have as much head room for the XPR-5 on the new rack as I did on the old one so I put some 12 volt triggered cooling fans on top of the amp. I can run the system all day and it doesn't get too warm whereas it used to get pretty hot without just being powered on without much use. Is a cooling fan a good idea in the long run?
ID:	1344098   Click image for larger version
ID:	1344130   Click image for larger version
post #276 of 277 Old 03-28-2016, 11:56 AM
t-well's Avatar
Quoted: 20 Post(s)
In my modest opinion there is nothing wrong in cooling electronic gear by fresh air.
azz7686 likes this.
t-well is offline
post #277 of 277 Old 03-28-2016, 12:32 PM
DonH50's Avatar
Liked: 1330
+1. Especially for equipment in a closet... I have usually added some sort of air inlet and return when sticking equipment in an enclosed space. Sometimes just a ceiling vent and louvers on the doors with fans in the rack. Make sure the fans draw cool air from the bottom and sides and blow out the top, don't have them blowing down into the amp.
IMO - Don
DonH50 is offline
Emotiva Xpr 5 Reference Five Channel Power Amplifier
