I just received an email from Emotiva with the information about the XPR-5. So, who is going to buy one of this monsters?
http://shop.emotiva.com/collections/amplifiers/products/xpr5
SPECIFICATIONS
Topology: Fully discrete, dual differential, high current, short signal path Class A/B amplification with Optimized Class-H™ power supply topology.
Number of Channels: 5
Power Output
(rated power; THD
400 watts / channel (x5); all channels driven; into 8 Ohms.
600 watts / channel (x5); all channels driven; into 4 Ohms.
500 watts / channel (x2); two channels driven; into 8 Ohms.
750 watts / channel (x2); two channels driven; into 4 Ohms.
575 watts / channel (x1); one channel driven; into 8 Ohms.
1100 watts (1 .1 kW) / channel (x1); one channel driven; into 4 Ohms.
Rated Power Bandwidth (at rated power; 8 Ohm load): 20 Hz to 20 kHz + /- 0.01 dB.
Minimum Recommended Load Impedance (each channel): 4 Ohms (which equals one 4 Ohm load or two paralleled 8 Ohm loads per channel).
Frequency Response: 10 Hz to 80 kHz (+ 0 / - 1 dB).
THD + noise:
Signal to Noise Ratio (8 Ohm load):
> 93 dB at 1 watt (A-weighted).
> 109 dB at rated power (A-weighted).
Damping Factor (8 Ohm load): > 500
Speaker Output Connections:
Super heavy duty audiophile speaker binding posts - with clear acrylic insulators and heavy duty gold plated contacts; designed to accept heavy-gauge bare cables, lugs, or banana plugs.
Power Supply:
3.3 kVA toroidal power transformer.
180,000 uF of storage capacitance.
Input sensitivity (for rated power; 8 Ohm load): 1.875 V
Gain: 29 dB
Input Connections:
Unbalanced (Tiffany style, audiophile quality, gold plated RCA); one per channel.
Balanced (XLR); one per channel.
Each input may be independently switched to either unbalanced or balanced.
Input Impedance:
47 kOhms (unbalanced).
22 kOhms (balanced).
Trigger:
Trigger Input: 5 - 20 V (AC or DC);
SPECIFICATIONS
Power Output
(rated power; THD
THD + noise:
Power Supply:
Gain: 29 dB
Input Connections:
Input Impedance:
Trigger:
