Pioneer sc-73 shutting down at power up! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-04-2012, 08:41 AM - Thread Starter
jenkzy56's Avatar
Not sure what's going on, the sc-37 is shutting itself off after the screen displays
HDMI-5
I'm only using 2 inputs and 1 output, BD input and HDMI-1 input
And the 1st HDMI output.
Have had the unit for almost 2 years without any issues.
If anyone has an insight or experience with this, please feel free to
Chime in.
jenkzy56 is offline
post #2 of 4 Old 07-04-2012, 09:14 AM
Selden Ball's Avatar
Quoted: 3198 Post(s)
Liked: 1571
Double check your speaker wiring to make sure there are no shorts at the binding posts or in the cables themselves. Pets chewing on them could have caused damage, for example.
Selden
Selden Ball is offline
post #3 of 4 Old 07-04-2012, 09:44 AM - Thread Starter
jenkzy56's Avatar
thank you for that suggestion!
just inspected all wiring, we do have a cat so I thought that might have been the problem but
every thing looks ship shape.
going to keep trying to figure it out until I run out of
quick fix options.
Not looking forward to dealing w/ warranty issues but it may come to that.
jenkzy56 is offline
post #4 of 4 Old 07-04-2012, 10:41 AM
M Code's Avatar
Quoted: 734 Post(s)
Liked: 442
EZ to check..
Disconnect ALL speaker wires from the back of the AVR.
Now power UP the AVR, what happens?
1. If the AVR doesn't shut down, then the problem is either the wiring or loudspeakers
2. If the AVR does shut down, then the problem is internal within the AVR
M Code is offline
