Picking a receive for emp tek speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-04-2012, 09:54 PM - Thread Starter
Scottyp3's Avatar
Towers
Recommended Power: 50-200 Watts
• Impedance: 6 Ohms
• Frequency Response: 40Hz-20kHz ±3dB
• Crossover Frequencies: 120 Hz / 3,000 Hz
• Sensitivity: 88dB (2.83V@1m)
Center
• Recommended Power: 50-175 Watts
• Impedance: 6 Ohms
• Frequency Response: 50Hz-20kHz ±3dB
• Crossover Frequency: 600 Hz, 3,000 Hz
• Sensitivity: 87dB (2.83V@1m)
Rear
Recommended Power 30-100 Watts
• Impedance 8 Ohms
• Frequency Response 60Hz-20kHz ±3dB
• Crossover Frequency 3,000 Hz
• Crossover Slope 12dB/Octave
• Sensitivity 86dB (2.83V@1m)
Room is 11 x 16 and would listen to it moderately loud.
Dont need 3-D.
Would like the speakers to sound good and have enough power and that's about it.
I live in Canada.
Links
http://www.emptek.com/e41b_js.php#252
http://store.emptek.com/e56ci_js.php#244
http://store.emptek.com/e55ti_js.php#235
Scottyp3 is offline
post #2 of 7 Old 07-05-2012, 10:36 PM - Thread Starter
Scottyp3's Avatar
:O
Scottyp3 is offline
post #3 of 7 Old 07-07-2012, 02:12 PM - Thread Starter
Scottyp3's Avatar
ok
Scottyp3 is offline
post #4 of 7 Old 07-09-2012, 07:26 PM - Thread Starter
Scottyp3's Avatar
bump
Scottyp3 is offline
post #5 of 7 Old 07-09-2012, 07:38 PM
Socketman's Avatar
Quoted: 128 Post(s)
Liked: 148
Emp Tek is a budget line for RBH a well known speaker manutacurer. At the emp tek website they have may good reviews on their speakers. Gene De Salla is quite impressed with the brand. I suggest reading his articles and use them as guidelines. Not knowing what features are important to you i can only make very vague assumptions. Most receivers will be fine in the 100w range, go by what you can afford and the features that you want.Buying a last year model will let you get a full featured receiver at a discount price. hope this helps.
richard
Socketman is online now
post #6 of 7 Old 07-21-2012, 04:21 PM - Thread Starter
Scottyp3's Avatar
kk thanks
Scottyp3 is offline
post #7 of 7 Old 07-21-2012, 07:02 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
Originally Posted by Scottyp3 View Post
kk thanks
I'm familiar with Emptek. Decent value. If I were you I would consider adding a subwoofer.
Not that brand though. Then most receivers will easily power that room. What is your budget for receiver?
And what do you connect to it? How do you mostly use it?
kikkenit2 is offline
