Yamaha RX-V471 question - AVS Forum | Home Theater Discussions And Reviews
Old 07-05-2012, 07:28 AM - Thread Starter
jhteeters's Avatar
Hello to all...
Components:
Receiver: Yamaha RX-V471
Blu-Ray: Sony BDP-S480
Plasma TV: LG 50PV-450
I am connecting HDMI from the blu-ray player to receiver and HDMI from receiver to TV. In order to stream Netflix, I have to select Netflix from the blu-ray home menu, which won't display on the TV. It is like the receiver doesn't see a video signal and therefore it doesn't show the menu on the TV. If I play an actual blu-ray movie, it works just fine.
If I can't get to work, I am stuck using HDMI from the blu-ray to TV and then back to receiver. I would rather have all inputs to the receiver and then to the TV.
I have scoured manuals for all three components and can't seem to find a setting that will fix this? Anybody with similar experience or have a solution?
Thanks in advance.
jhteeters is offline
Old 07-05-2012, 01:49 PM
Brocken_5110's Avatar
1) Are your cables HDMI 1.4 rated? Do you have extra HDMI cables to swap in?
2) Have you tried connecting the blu-ray player to a different HDMI-in port?
3) Can you get menus when there's a blu-ray disc in the player?
Brocken_5110 is offline
Old 07-05-2012, 10:15 PM - Thread Starter
jhteeters's Avatar
Thanks for the response. I tried some other cables, but I think I am looking at a connector problem on the blu-ray player. I noticed that the words "HDMI" and "OUT"....are not steady on. They blink on and off.
I moved the hdmi cable around to try to seat better on the connector. I can get the HDMI/OUT to stay on for the most part, but it still goes out.
I went back and tried a dvd (not a blu-ray) and the video cuts out as well....confirming a connector problem even more. I will go buy a brand new 1.4 just in case and try out.....or got to fix the connector.
Thanks again.
Old 07-06-2012, 03:14 PM
Sounds like you've isolated the problem - good luck.
Yamaha Rx V471bl 5 1 Channel Av Receiver
