Your usual volume setting number - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-05-2012, 08:41 AM - Thread Starter
purplerain's Avatar
Quoted: 42 Post(s)
Liked: 27
Just wondering what your usual volume setting is during regular programming.....I'm usually between -19 and -30. I have a Marantz SR7001. Don't think I ever went into the + zone.......biggrin.gif
*ENTERTAINMENT PURPOSES ONLY - PIONEER KRP-500M*
(2) Monitor Audio RX6 towers - (1) Monitor Audio RX center - (2) Monitor Audio RX FX surrounds - (1) NAD T758 AVR - (1) Velodyne Optimum 8 Sub
purplerain is offline
post #2 of 3 Old 07-05-2012, 09:34 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
volume settings are relative.
Audyssey sets "0" as reference in your receiver for each channel.  If you change the level(gain) on any of the channels the number settings no longer correlate to anything.
I normally listen with my volume setting at -15 for normal listening and might push to -12 for an action or sci-fi flick with heavy bass and sound depending on mix.  My speakers realistically cannot get to reference without an enormous amount of distortion so thats where I cap the dial.
NicksHitachi is offline
post #3 of 3 Old 07-05-2012, 09:42 AM
ozar's Avatar
Liked: 152
On my Onkyo 809, I usually start at about 68 for blu-ray movies and adjust accordingly depending on the mix for any particular disc. I hate it when previews and other features aren't included by default at the same volume level as the movie itself.
oz
ozar is offline
