receiver 7.1 and 9.1 ( can i run 4 speakers off 2 lines) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-06-2012, 12:11 AM - Thread Starter
flyhigh123's Avatar
So i'm looking at 7.1 and 9.1(2) receivers currently. The jump in price from for an example a pioneer 1122 to a Onkyo NR-1009 is around double the cost.
I am planning on running 9 speakers,
1 ccenter
2 fronts
4 in the middle above seating area downward firing ( ceiling mounted), 2 slightly in front of seats and 2 slightly behing
2 rears
1 sub
If I do this setup, if i use a 7.1 receiver, can i splice the wire for the side speakers the (4)? basically the 2 left sides are the same line and the 2 right sides are the same.
Or should i splurge for the 9.2 receiver?
This is for a somewhat theater room.
thanks!
flyhigh123 is offline
post #2 of 2 Old 07-06-2012, 04:41 AM
jdsmoothie's Avatar
Quoted: 12366 Post(s)
Liked: 5646
Not familiar with other brand 9.1 AVRs, but on the Denon side, there are only a few AVRs (upper level only) that support Surround A and Surround B speaker setups, as even the 9.1 AVR (4311CI) will only support a single set of "side" surround speakers which would still require you to wire 2 sets in parallel/series.
jdsmoothie is online now
