Klipsch RB - 61 or RB - 51? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-12-2012, 01:51 PM - Thread Starter
isaacstaco's Avatar
For all you guru's out ther, I have a HK AVR 3600 (80 watts per channel) and looking to upgrade my speakers. I'm wondering if my AVR 3600 will do a good job pushing the RB - 61's (100/rms) or if I should go with the RB - 51's (75/rms).
Also, i'm dead set between these two speakers. So please don't suggest another speaker.
isaacstaco is offline
post #2 of 5 Old 10-17-2012, 09:12 PM
Bill Valley's Avatar
Did you go with the RB-61's? I am running an AVR 2600 and looking to upgrade my front stage.
Panasonic P50S1
PS3
Harman Kardon AVR 2600
HSU Research STF-2
Infinity Primus F/R/C
Running 5.1 (for now)
Bill Valley is offline
post #3 of 5 Old 11-11-2012, 10:54 AM - Thread Starter
isaacstaco's Avatar
I just pulled the trigger on the 61's along with a rc52 center. They will be here Wednesday. They should be a nice upgrade from my current Sony b3000 speakers, which I'll be using as surrounds when my Klipsch's come in.
I'll let you know how they sound.
post #4 of 5 Old 05-26-2013, 11:27 PM
meltrust's Avatar
How did they sound?
meltrust is offline
post #5 of 5 Old 05-27-2013, 06:43 AM
abba1's Avatar
Quoted: 23 Post(s)
Originally Posted by meltrust View Post
How did they sound?
I just purchased this exact set-up (61/52) It took a little while to get used to the horns, but when I did I concluded I made the right decision.
Let me begin by saying that I bought these speakers for a clearer dialogue that I wasn't getting from my former Ascends (in all fairness my AV room is a tough one...12 x 12). The RC 52 presented a much clearer better defined dialogue which was what I was looking for. Even though the woofers are smaller on the 52's (5.25 vs 6.5) the sound the seamless across the board (as witnessed by scenes in Top Gun!). There is plenty of bass even after adjusting Audyessy Reference Level and setting it to Music / flat (these speakers are ''bright''). I would add that I have an Onkyo 818 (great receivers by the way!)
abba1 is offline
