Can I use a 7.1 receiver for whole home audio? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-16-2012, 08:06 AM - Thread Starter
nickg2027's Avatar
I have 5 rooms that I would like to be able to play pandora, AM/FM, iPad dock etc. I realize all five listening areas will be hearing the same thing if I use a 7.1 receiver and that is ok.
I will install 3 speakers in main listening area and 1 speaker in the remaining 4 rooms. I am looking at a refurbished Denon AVR-1712 from accessories 4 less. I will install line level volume controls in each room and leave the receiver volume at approximately 3/4.
My question is, can this receiver or any other 7.1 receiver play a mono signal across all 7 speakers so that the same audio is heard in all rooms.
I am trying to do this as cheap as possible so any other solutions to this will be greatly appreciated.
nickg2027 is offline
post #2 of 11 Old 07-16-2012, 08:11 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Pretty much any 5.1, 7.1, 7.2, 9.2 receiver will be able to play Mono signal to all channels. You do know that if someone in any of the rooms doesn't want to listen to the music you will have to disconnect the speaker for this? Or if the AVR you get can do zones, you can connect the bedrooms to one zone and the other room to the other zone. That way if you want people in the bedroom to go to bed without the music you just turn that specific zone off wink.gif.
GusGus748s is offline
post #3 of 11 Old 07-16-2012, 08:20 AM - Thread Starter
nickg2027's Avatar
Also, you should of put this thread in the AMPS, RECEIVER and PROCESSORS section. You will get better support there.
Sorry, I thought this was posted in the AMPS, RECEIVER and PROCESSORS section. At least that is what my computer shows.
The line level volume controls wouldn't be able to turn the volume all the way to mute?
post #4 of 11 Old 07-16-2012, 08:31 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Never mind it was in the correct place. It was me. I was switching back and forth between forums / threads. I'm not familiar with line level volume with mono settings. May be someone else has done something similar. With my AVR HT-R960 if I put it on Mono all my speaker sound the same.
post #5 of 11 Old 07-16-2012, 08:40 AM - Thread Starter
nickg2027's Avatar
post #6 of 11 Old 07-16-2012, 08:46 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Ok, now I got you. I thought you mean controlling the volume via AVR. That volume controller should work just fine. That's an excellent idea too. You just gave me an idea on putting speakers outside in the patio and garage area by using the zones option. Excellent. I learn something new all the time on this Forum.
post #7 of 11 Old 07-16-2012, 10:15 AM - Thread Starter
nickg2027's Avatar
Sweet, glad we helped each other out.
What exactly is the mode called when pushing mono to all 7 speakers? I just wanted to read the manual on how to accomplish this.
Does anyone else have a cheaper solution?
Thanks again.
post #8 of 11 Old 07-16-2012, 11:15 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
My AVR has mono, stereo, and all channels stereo.
post #9 of 11 Old 07-16-2012, 03:18 PM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
Mid/lower level Denon AVRs (including the 1712 you are considering) in your price range do not have a "mono" option. If you are passing the same audio to all speakers, you can use the Denon's "Multi CH Stereo" feature with the FL/C/FR speakers connected in the main room and 2 "stereo" (ie. single speaker with stereo connections) speakers connected to each of the SL/SR and SBL/SBR speaker posts (either wired in parallel or using an impedance matching speaker selector).
jdsmoothie is offline
post #10 of 11 Old 07-16-2012, 06:59 PM - Thread Starter
nickg2027's Avatar
Could you recommend a cheap speaker that would have the stereo connections? I was looking at the Polk atrium or Polk monitor 30 and both only have one set of speaker terminals.
Sent from my SGH-I997 using Tapatalk
post #11 of 11 Old 07-16-2012, 07:04 PM
jdsmoothie's Avatar
Liked: 5508
