vsx 1326k 7.1---setting up mcacc as a 5.1 only..a lil help please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-16-2012, 08:34 AM - Thread Starter
nismosis's Avatar
Hi there,
I am currently trying to set up my 7.1 vsx 1326 pioneer to run in a 5.1 only setup. I am only running the one main zone, and my speakers are NOT bi-amped.
The problem i am having is when i run the mcacc full auto setup i am having trouble choosing which speaker setup t choose via the gui. the only option that shows a five speaker set up is one that says the fronts are bi-amped. All the other setups show 7 or more speakers, high fronts, or second rears, or second sides; all of which i do not have. so was i right in choosing the five speaker setup with front bi-amped even though they are not?
I have my center, two towers, sub, and surrounds. 5.1 goodness, which speakers setup do i choose?
Thanks for any info.
Also, is there a way to manually adjust treble, mid, and bass? Everything seems pretty automatic, and the manual is not that user friendly to me. thanks
Steve
nismosis is offline
post #2 of 2 Old 07-16-2012, 06:22 PM
Kilian.ca's Avatar
Liked: 37
Of course you can override it. User Manual p.69-70 Manual Speaker Setup lets you set SB to none.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
