TrueHD or DTS-HD over S/PDIF? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 07-16-2012, 10:41 AM - Thread Starter
kklarson's Avatar
I'm trying to get a HTPC to bitsream to my VSX-1120. The Windows 8 AMD ATI HDMI audio driver isn't working, so I'm trying S/PDIF (optical). I'm getting DD5.1 and DTS to work, but not TrueHD or DTS-HD MA. I've read that other Pioneer receivers needed these signals to go over HDMI, but I don't see that in the VSX-1120 manual. Can anyone confirm whether TrueHD or DTS-HD MA works over S/PDIF to the VSX-1120? Thanks.
kklarson is offline
post #2 of 12 Old 07-16-2012, 11:22 AM
ccotenj's Avatar
Liked: 101
no can do... regardless of avr, you need to be connected by hdmi to stream the lossless codecs...
- chris
ccotenj is offline
post #3 of 12 Old 07-16-2012, 11:22 AM
Greg121986's Avatar
Quoted: 48 Post(s)
Liked: 35
It is my understanding that DTS-HD and Dolby TrueHD, Dolby Master Audio, are only transmittable through HDMI. This is due in part to bandwidth requirements for the multi channels, but more so due to Dolby making this decision. If you have to transmit through SPDIF, your HTPC will have to down-sample to Dolby Digital.
Greg121986 is offline
post #4 of 12 Old 07-16-2012, 11:30 AM
ccotenj's Avatar
Liked: 101
neither of those are the reasons... it's for copy protection...
spdif technically has more than enough bandwidth, and dolby has nothing to do with the decision to copy protect lossless codecs...
- chris
ccotenj is offline
post #5 of 12 Old 07-16-2012, 01:52 PM - Thread Starter
kklarson's Avatar
Thanks for all of the quick responses. Will save me more hours of head banging. Hopefully AMD will get its HDMI audio driver for Windows 8 out soon since the full release is in October.
kklarson is offline
post #6 of 12 Old 10-05-2012, 05:40 AM
Cow000's Avatar
Hello AVS people!
I have a question :
With a 2.1 Home cinema, which can decode DTS HD & True HD, connected with SPIDIF, how the Home cinema will react ? It will automaticly decode the DTSHD & TrueHD in DTS (or something like that) for playing it ?? The qualit will be degraded if so ?
Many Thx
Cow000 is offline
post #7 of 12 Old 10-05-2012, 05:44 AM
jdsmoothie's Avatar
Quoted: 12076 Post(s)
Liked: 5499
No. As previously noted, HDMI is required to pass HD DD/DTS audio codecs. S/PDIF can only pass standard DD/DTS and PCM 2.0. So if the source is connected to the home cinema with S/PDIF, it will only pass the standard DD/DTS audio track and not the HD audio track.
jdsmoothie is offline
post #8 of 12 Old 10-05-2012, 05:58 AM
Cow000's Avatar
Yes i understand this.
I ask one more time to be sure of the answer before making my move,
So
i play my Bluray audio in DTSHD & TrueHD with SPDIF
my Home cinema 2.1 channel can decode TrueHD & DTSHD & many more
My Home cinema is going to play DTS (PCM or something else) insteed of DTSHD
or
no audio will be play at all by the homecinema ???
(i mean the spdif is going to "compress" the DTSHD audio and sent it to the homecinema or simply not allow it to pass so the home cinema is not reciving anyting ?)
Thx again for your time
Cow000 is offline
post #9 of 12 Old 10-05-2012, 06:01 AM
jdsmoothie's Avatar
Liked: 5499
As I already noted, the Blu Ray player will detect there is no HDMI connection and therefore will pass the lossy/standard DD/DTS track instead of passing the HD DD/DTS track if an HDMI cable was connected so your home cinema will simply play that standard DD/DTS audio track.
post #10 of 12 Old 10-05-2012, 06:27 AM
Cow000's Avatar
Got it thx a lot
So DTSHD track include DTS ?? Because the bluray movie has no DTS track....
Cow000 is offline
post #11 of 12 Old 10-05-2012, 07:51 AM
jdsmoothie's Avatar
Liked: 5499
Yes, the BD will also include a "core" DD/DTS track so even when the HD DD/DTS track is selected, the "core" non-HD DD/DTS track will be played by the home cinema when connected via a S/PDIF cable.
post #12 of 12 Old 10-05-2012, 08:23 AM
Cow000's Avatar
Perfect.
Thanks a lot for your time and have a nice day
Bye
Cow000 is offline
