What are the worst speaker brands to match with the NAD 326bee? I have other questions also - AVS Forum | Home Theater Discussions And Reviews
Old 07-17-2012, 04:46 PM - Thread Starter
keyboardcat's Avatar
Does anyone know what kind of bare speaker wire it can accept like gauge numbers? I don't want to get into using banana plugs. I don;'t know how to solder to get them on. I finally have the money to buy this amp. I am still deciding if I really want it. I saw a review online today of a guy saying that it made his Polk Audio speakers sound to bright. That made me nervous. I hear that sometimes you can buy a good amp, but match it with the wrong speakers. Any NAd owners please tell me your :)experience with brands that didn't sound good with it.
keyboardcat is offline
Old 07-17-2012, 04:48 PM - Thread Starter
some people online also said that this amp tends to run hot sometimes and overheat. anyone had that problem?
Old 07-17-2012, 05:02 PM
Charles R's Avatar
Liked: 536
Try these... http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=2801&seq=1&format=2
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
Old 07-17-2012, 05:40 PM
Paraneer's Avatar
Quoted: 30 Post(s)
Liked: 85
Congrats on purchasing a NAD. It's a fine product. I had a NAD 3020 amp for over thirty years til it finally gave up the ghost. Guess I got my money's worth. I recently replaced it with a NAD 316BEE in a secondary system. The 316 is driving vintage ADS L-520's, a 4 OHM speaker with no difficulty or overheating. I don't think you would have any overheating problems with a 326 unless it were enclosed with no ventilation driving a speaker that really digs down in impedence.
I would think the 326BEE would match up well with any quality speaker that is no lower than 4 OHMs impedence. Sorry, but I really don't get into the certain amps liking certain speakers thing that would produce either a warm or clinical sound. I am sure the NAD 326 will play nice with just about any speaker out there.
Good link above regarding closed end Banana Plug that Charles provided. No soldering needed and they will accept up to 12 gauge. I use a similar type of plug with 14 guage wire into my 316. It's a fast and easy way to hook everything up. Good luck and happy listening.
Marantz PM15S2 LE, Oppo BDP-103, Simaudio Moon 100D DAC
VPI Traveler V2 with an Ortofon Rondo Blue and Simaudio Moon 110LP, Technics SL-1400 with an Audio Technica AT-14sa and Pro-ject Phono Box S
Dynaudio Focus 260's, Rel T-1 and a Panasonic TC-P54S1.
Paraneer is offline
Old 07-17-2012, 05:56 PM
Ryan1's Avatar
Quoted: 12 Post(s)
Liked: 41
Dude, you might be putting the cart before the horse.
Since it sounds like you may be on a budget, my suggestion would be to invest in the best speakers you can afford, then worry about the amp (but don't worry too much about it - any modern mainstream amp or receiver should be transparent in the audible band).
While the 326bee is not expensive, you will likely achieve exactly the same results with any decent amp or receiver at half the price and likely with more features.
Ryan1 is offline
