Onkyo TX-NR717 or TX-NR709? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-17-2012, 06:01 PM - Thread Starter
chs4000's Avatar
Hello folks,
In deciding what to recommend to a dear friend of mine, I'm torn between the 2012-model TX-NR717 and the 2011 model TX-NR709. Which of these two would you recommend getting? My cost on the TX-NR717 is about 50% higher than my cost on the TX-NR709. Should the absence of Audyssey MultEQ XT in the TX-NR717 factor in my decision? I don't have a separate subwoofer calibration processor/dsp. On the other hand, the 717 is one year newer. It just seems to be expensive to purchase it from an authorized dealer, so expensive that the decision appears to be one between the 709 and the 818.
Which way should I go folks? 709, 717, or 818?
Thank you for any advice you can impart.
chs4000 is offline
post #2 of 4 Old 07-17-2012, 11:28 PM
aznattic's Avatar
Quoted: 12 Post(s)
If the 717 is 50% higher cost than the 709, i would definitely go with the 709. Besides the name change, i don't see much change, both support 8 hdmi inputs, 2 hdmi outputs, same watts per channel and the same features (at least audio wise) other than the fact the 717 doesn't have MultiEQ XT and instead drops down to 2EQ which is odd.
http://www.audyssey.com/audio-technology/multeq On the bottom of the site you'll find the differences of the 2EQ, MultiEQ XT and MultiEQ XT32.
I have a 709 and an 809 and while i haven't used the Audyssey on the 809, the 709 did a fine job with Audyssey.
From there you have the 818 which is like the 809, more power than the 709 or 717 but with MultiEQ XT32 instead.
If the 717 is 50% higher than the 709, i'd personally jump on the 709 in a heartbeat and even if they were the same price i'd still go with the 709 for the MultiEQ XT. If the 818 is the same price as the 709, i'd go with the 818. Newer isn't always better smile.gif
On a side note, the 709 had an issue where it would not do HDMI pass through with audio for me. It was fixed after i did a firmware update. I have yet to experience any HDMI failures on either receiver.
aznattic is offline
post #3 of 4 Old 09-24-2012, 10:10 AM
bodean's Avatar
Quoted: 170 Post(s)
Liked: 43
Does the 709 have apple airplay so I can stream itunes from pc to the receiver?
Sony KDL65W850A 65" LED HDTV  || Bose Soundtouch 130 soundbar || Synology DS716+ NAS || XBOX One ||
Xbox Live : BoDEAN
bodean is offline
post #4 of 4 Old 09-24-2012, 10:19 AM
jdsmoothie's Avatar
Quoted: 12101 Post(s)
Liked: 5507
No, Onkyo AVRs don't feature Airplay; however, adding an Apple TV will add Airplay to any AVR (to include video as well).
jdsmoothie is offline
Onkyo Tx Nr717 , Onkyo Tx Nr709
