Marantz SR7007 AV Receiver Owner's Thread - Page 33 - AVS Forum
post #961 of 976 Old 08-11-2014, 10:16 AM
augerpro's Avatar
Liked: 27
I'm trying to set the Dynamic Compression level, but only get that option with Dolby Digital streams. Is DC not available when playing DTS?
augerpro is offline
post #962 of 976 Old 08-11-2014, 04:28 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 625 Post(s)
Liked: 1374
Correct as noted on pg. 113 in the Owner's manual.
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AV Gear
Mon - Fri: 8am – 8pm EST (Sat/Sun too, will return call if I don't pick up)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Oppo, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is offline
post #963 of 976 Old 08-11-2014, 10:29 PM
punprankster's Avatar
Liked: 0
Would it make sense to hook up a marantz sr7007 to an emotiva upa-700 power amp or will i need something more substantial to notice any difference in the sound quality?
punprankster is offline
post #964 of 976 Old 08-12-2014, 04:16 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 625 Post(s)
Liked: 1374
Something more substantial (eg. XPA-2, XPA-3), although even then likely no difference in sound quality, rather simply more power for low ohm speakers.
post #965 of 976 Old 08-15-2014, 03:46 PM
amairphoto's Avatar
i wish they would release a patch that addresses the sirius player, where it changes channels randomly. So annoying when im trying to listen to a channel
amairphoto is offline
post #966 of 976 Old 08-17-2014, 06:28 PM
Liked: 0
Thanks jd. Diving into and getting immersed in the hi fi pool as opposed to just sipping your toes in is much more of a. Challenge and learning.
post #967 of 976 Old 08-18-2014, 07:36 AM
blue13x's Avatar
Liked: 26
Originally Posted by rbajwa13 View Post
Hi,
new owner of the SR7007 and I have a quick question and would greatly appreciate anyone that can help. I browsed through most of this thread looking for answers, but could not locate my specific question. In all likelihood the question is very stupid, but I am not very adept at this so would appreciate any help.
I was wondering how I can connect my phone (Nexus 4) to my receiver? I would like to play some music on my phone on my surround sound, and was wondering the best way to go about that. I heard of the term media server thrown around in here, is that something that could get this done? For some reason when I go to media server on the receiver it's not recognizing my phone. I was hoping to connect my phone to the receiver using bluetooth, but if I'm not mistaken you have to purchase the pretty pricey RX-101 to connect bluetooth devices?
Sorry for the long question/bunch of questions. Would really appreciate some help!
I have a Galaxy Note 3. Both my SR7007 and the phone are on the same network. And in the music player a stream to button appear in the music player, this way i can stream via wifi to the receiver. Works great. Not sure if the Nexus has it, but im sure you can download an app that can stream via DLNA.
Sent from my SM-N9005 using Tapatalk
blue13x is offline
post #968 of 976 Old 08-18-2014, 09:20 PM
amairphoto's Avatar
I also can do this with my HTC One M8.
post #969 of 976 Old 08-19-2014, 07:12 AM
blue13x's Avatar
Liked: 26
Great, so theres no need to buy the bluetooth accesory. DLNA works with many devices, im sure the nexus too.
blue13x is offline
post #970 of 976 Old 08-19-2014, 09:33 PM
Liked: 0
I had a few questions about the receiver, if anyone could help me out that would be great!
1.) I ran Audussey setup and at an initial volume at 12 o'clock the dB level on the subwoofer was maxed out around -12. I got it down to about -3dB when it was set at around 7 or 8 o'clock (almost minimum). I increased this to around -1db because I prefer more bass. However, now when I listen to music or watch a movie, etc. I can't really feel any bass from the subwoofer, I could barely even tell the subwoofer was working. Any recommendations regarding this?
2.) I read that the front speakers should be set to 'small' to let the subwoofer work as intended. However, when I run Audussey, it automatically labels my front speakers as large. After calibration, I had to manually set up the speakers as small using manual setup. Is this okay (i.e. is it okay if during calibration the speakers were large and then setting them to small after the fact?).
3.) My receiver is currently connected to my Sharp aquous lc-80le650u through an HDMI cable. The HDMI cable runs from the TV (ARC compatible) to the TV output on my receiver. However, when I play apps on my TV (Netflix, YouTube) it doesn't use my external/surround sound speakers. I called sharp but they said the customer support agent said that any app that streams, which includes Netflix and YouTube, will not use external speakers. From what I know, this is not true but he seemed pretty adamant. I was wondering if anyone had similar issues or know a solution in regards to this. I think maybe it has to do with the fact that the HDMI cable running from the TV to the "TV output" is perhaps old and not ARC compatible? Or perhaps I need a separate cable from the TV to go in one of the inputs?
4.) Lastly, I have a DLNA-certified application on my phone, but the app rarely ever recognizes the marantz receiver (I would say about 20% of the time). My TV is almost always recognized by my phone, so I have no idea why it fails to pick up the marantz. Just for refernce purposes, the app I am using is BubbleUPnP.
I know its a lot of questions, but I would really appreciate any help! Thanks, and I really appreciate the community here
rbajwa13 is offline
post #971 of 976 Old 08-20-2014, 12:07 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 625 Post(s)
Liked: 1374
1. Sure. Ensure the FL/C/FR speakers are set to SMALL with no lower than an 80Hz crossover. Also, you can bump the Subwoofer Level setting up a few more db (eg. from -1db to +2db).
2. Yes. Audyssey does not set the speakers to LARGE, rather the AVR does, so resetting them to SMALL/80Hz is correct. If Audyssey had their way, all speakers would be set to SMALL during the Audyssey setup, however, AVR mfr's have refused to extend this control.
3. In order for HDMI(ARC) to work both the TV and the AVR must have this feature. Please review my post below for assistance. Although written for the Denon models, the same applies to your 7007.
The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ
4. How is the AVR connected to the home's Wifi router? Wired directly is more reliable. If connected wirelessly, you may want to consider a different "bridge" router. Review my post below for more assistance.
rbajwa13 likes this.
post #972 of 976 Old 08-20-2014, 07:29 AM
Liked: 0
Thanks for the help JD!
1.) I made sure all speakers were set to small and had a crossover frequency of 80 Hz, and even tried increasing the dB setting of the subwoofer even higher (tried 1 dB, 2 dB, etc.). Still to no avail. This may be because during calibration, I did not use a mic stand or tripod as requested, though I did not think that would make such a big difference in terms of the bass from the subwoofer (I could be wrong). I will try properly calibrating my sound system with a tripod/mic stand, and perhaps that will solve this issue.
2.) Great, exactly what I thought (manually change speakers to small/80 Hz after calibration)
3.) Awesome! Did not know HDMI control on the AVR was automatically set to "off"
4.) I have wired the AVR directly, not through wireless. I don't believe the marantz sr7007 can connect to the network wirelessly, I could be wrong. Despite being connected directly, the marantz is still not visible on the device, and I'm not sure the reason why. The unit is in my basement, and the WiFi connection isn't that strong so perhaps I should get a WiFi signal booster to combat this?
Appreciate the help!
rbajwa13 is offline
post #973 of 976 Old 08-20-2014, 07:47 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 625 Post(s)
Liked: 1374
1. Correct. A camera tripod will make a difference and a mic boom stand an even bigger one.
4. The unit can be connected "wirelessly" by using another router in "bridge" mode or using PowerLine adapters. If the app works when in the basement but not in other parts of the house, then yes, you would need a booster.
post #974 of 976 Old Yesterday, 04:01 PM
augerpro's Avatar
Liked: 27
Having a problem here, I'm sure I'm just missing something simple. I'm trying to connect my pre-outs to a minidsp, then to an external amp. I'm getting no sound. I've gone over the minidsp settings and it should be working. To test the signal I touched the speaker cable to the RCA connector pin/shield from the pre-out figuring I should at least hear something, and I don't. I don't think my receiver is outputting anything through the pre-out. What am I missing?
augerpro is offline
post #975 of 976 Old Yesterday, 04:07 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 625 Post(s)
Liked: 1374
Take the miniDsp out of the loop.
post #976 of 976 Old Yesterday, 04:24 PM
augerpro's Avatar
Liked: 27
Yeah I just wired the pre-out direct to the amp and got sound. Something with the minidsp I guess. Hope it wasn't damaged in the move.
augerpro is offline
Marantz Sr7007 Home Theater Av Receiver
Gear in this thread - Sr7007 by PriceGrabber.com
