Marantz SR7007 AV Receiver Owner's Thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #991 of 1298 Old 09-06-2014, 12:59 AM
jdsmoothie's Avatar
Quoted: 15332 Post(s)
Liked: 7488
I wouldn't buy a refurb (comes with only 1 year warranty) without also buying a 3 year extended warranty as replacement of an HDMI board (rare but does happen) can set you back $500.
jdsmoothie is offline
post #992 of 1298 Old 09-07-2014, 08:58 AM
DMHenrie's Avatar
Marantz SR7007 sound fields ?
I recently upgraded from a Yamaha RX-V2500 non hdmi receiver to a Marantz SR7007 hdmi model. The Yamaha had "pre programmed surround programs" for both audio and video listening. In video mode there were options for different genres "sports/adventure/theatre/etc" in audio there were options for different listening experiences such a Vienna Hall, Jazz room, etc. I can't seem to find anything like this on the Marantz other than the Audessy setup, and pure direct type modes.
What am I missing? Doesnt Marantz have anything like this?
DMHenrie is offline
post #993 of 1298 Old 09-07-2014, 09:05 AM
jdsmoothie's Avatar
Liked: 7488
Not like Yamaha, no. Available modes can be selected by pressing/holding the MOVIE/MUSIC/GAME buttons.
post #994 of 1298 Old 09-09-2014, 04:15 PM
DMHenrie's Avatar
HMM. BUMMER
DMHenrie is offline
post #995 of 1298 Old 09-10-2014, 05:54 PM
Quoted: 20 Post(s)
Liked: 0
Is it true I cannot use Bose 901s with the Marantz SR7007 because the 7007 has no pre-amp out or tape ports? The Bose 901 equalizer needs tape or pre-amp out ports on the receiver.
DavidPalermo is offline
post #996 of 1298 Old 09-10-2014, 05:59 PM
jdsmoothie's Avatar
Liked: 7488
The SR7007 has a full set of 7.1 main zone pre-outs and 7.1 EXT IN inputs; however using them will disable Audyssey which will likely do a much better EQ job then the Bose EQ. Try it both ways and use the config that you prefer.
post #997 of 1298 Old 09-10-2014, 06:08 PM
DMHenrie's Avatar
Why no SUB on Marantz SR7007 Phono ?
I just bought this receiver and it seems I have one question after another.
I got around today to connecting a turntable. Yes, an analog, old fashioned 33 1/3 rpm turntable. (One of 4 I have)
Anyway,
i got the inputs set up, and LP turntable works.
But ..
my Music sound options are:
Stereo L + R
Multi Channel Stereo which is L + R + C + SR + SL (no Sub)
Virtual which is also L + R + C + SR + SL (no Sub)
PLII Music which is L + R
NEO 6 Music which is L + R + C + SR + SL (no Sub)
My question is
WHY NO SUB?
I have it, it's connected, and it works just fine in TV/DVD/BluRay mode.
DMHenrie is offline
post #998 of 1298 Old 09-10-2014, 06:18 PM
Quoted: 20 Post(s)
Liked: 0
jdsmoothie:
I haven't bought the Bose 901s yet... not sure I will. So you think Audyssey will work with the 901s? I don't have any other speakers so the 901s will be my only ones. I heard that the Bose EQ is needed to adjust bass and treble and tune those speakers so they are "just right" but if Audyssey can do that then I don't know why I'd need the Bose EQ.
Thank you!
David
post #999 of 1298 Old 09-10-2014, 06:50 PM
jdsmoothie's Avatar
Liked: 7488
Other than a lot of marketing hype, there are better speakers for 1/2 the price. I'd look at Klipsch and Def Tech.
post #1000 of 1298 Old 09-10-2014, 08:38 PM
Quoted: 20 Post(s)
Liked: 0
Funny you should say that. I just listened to a pair of Definitive Technology speakers yesterday and am picking up a pair this weekend to try out with my system. They are more money than the 901s but if they sound good I'm going to go for it.
post #1001 of 1298 Old 09-11-2014, 12:42 PM
Liked: 0
I find the same thing. I am just in the process of hooking up my new SR7007 and if I play a music CD in my blu-ray, there's no sub either, and it plays only in 2 channel. Hope there's a solution to this.
BobGallant is offline
post #1002 of 1298 Old 09-13-2014, 02:17 PM
patfraley's Avatar
I often get "format error" message when trying to play files via USB. All files are compatible format. Any ideas?
patfraley is offline
post #1003 of 1298 Old 09-14-2014, 06:41 PM
ysgi's Avatar
Liked: 0
Fwiw, I absolutely love my new sr7007. Paired with polk rti10's and a polk csa6 center and kef sub and rears, it brings to life the video from the Sony qualia 004 projector.
Maybe I don't know what to listen for, or maybe I'm too old, but I think it's a great setup.
Ysgi
ysgi is offline
post #1004 of 1298 Old 09-18-2014, 03:40 PM
Quoted: 20 Post(s)
Liked: 0
Will my Sr7007 be able to drive 6 ohm speakers very well? I am considering these speakers:
http://www.sumikoaudio.net/en-us/our...ere/venere-3-0
David
post #1005 of 1298 Old 09-18-2014, 03:43 PM
jdsmoothie's Avatar
Liked: 7488
post #1006 of 1298 Old 09-18-2014, 03:50 PM
Quoted: 20 Post(s)
Liked: 0
Thank you JD!
post #1007 of 1298 Old 09-19-2014, 11:19 AM
JoeNDT's Avatar
Quoted: 54 Post(s)
Liked: 47
Got a problem playing back some SACD on my SR7007. Problem is that some SACD play in multichannel mode and some not. My CD player is a OPPO 103. I got it set up to:
-Play Back Set Up:
SACD Priority-Multi Channel
-Audio format setup:
HDMI Audio- Bitstream
SACD Output- DSD
I got the Oppo connected to the Sr 7007 via HDMI cable. No problem playing multichannel blu-rays dvd’s
Not sure if is a Marantz or Oppo issue.
What you guys think?
Thanks!!!
JoeNDT is offline
post #1008 of 1298 Old 09-19-2014, 11:34 AM
jdsmoothie's Avatar
Liked: 7488
When the issue is on some sources, but not all, more often then not it's a source issue, so either the SACD's themselves or the Oppo.
post #1009 of 1298 Old 09-19-2014, 12:57 PM
onge65's Avatar
I listen to lots and lots of SACD through the SR7007 and mytrusty Marantz DV9500 universal player connecting through 7.1 ch. input. I usethe Audioquest Jaguar interconnects cables and listen through the pure/directsetting on the SR7007.
I only have owned my SR7007 for a little over 8 months and love it. I do have a question to ask about some what off topic. Does any one see any reson for me to up grade to a new SACD/ OPPO or would I gain nothing by doing this ? Thanks.
PS My DV9500 works perfect but just wondering.
onge65 is offline
post #1010 of 1298 Old 09-19-2014, 02:07 PM
jdsmoothie's Avatar
Liked: 7488
Many of the Oppo owners that have posted in the forum generally agree that connecting via HDMI and using Audyssey is better than using the better DACs in the Oppo with multi analog output cables which then disables Audyssey, although there are a few that prefer going the analog route with music listening only. Bottom line, unless you want to upgrade to the better video quality from the Oppo, stand pat.
post #1011 of 1298 Old 09-19-2014, 02:42 PM
onge65's Avatar
I have a Panasonic blu ray I use for movies and just use my DV9500 for music. I will spend my money buying a new tv.I really want to thank you jdsmoothie you always help everyone out with great info.
onge65 is offline
post #1012 of 1298 Old 09-20-2014, 01:27 PM
Quoted: 20 Post(s)
Liked: 0
Do any of you know how to add a "radio station" on Spotify on a marantz SR7007? I don't think it is possible with the current implementation of Spotify on the SR7007. Truly frustrating.
post #1013 of 1298 Old 09-24-2014, 07:10 PM
punprankster's Avatar
Hi all. I have another newbie question. I have a rotel rsx 1067 that i would like to possibly use to biamp(?) a pair of b&w 705s i recently acquired. Does it make sense to use the rotel to power my fronts and use the marantz to drive the other speakers? If it does, what's the proper way of doing so and how would it affect the audyssey calibration? Thanks.
punprankster is offline
post #1014 of 1298 Old 09-24-2014, 09:50 PM
Quoted: 20 Post(s)
Liked: 0
So I am listening to Spotify on my 7007 and all of a sudden the network goes out on the marantz. I go into setup and it doesn't connect. I try unplugging and plugging the ethernet cable back in and it doesn't help. I turn my cable modem off and on as well as the Apple Router etc... the network works fine but the marantz isn't seeing it for some reason. My iPad, laptop, etc... all see the network (this message is being type on a laptop on the wireless network!).
So, I am now looking in the marantz manual and can't really find anything related to this.
By the way, Apple TV works fine through the marantz and it is on the network!
I can manually give it an IP address but I am not sure what address to give it. I think it uses 10.0.0.1 or something like that but I don't know if that will work. Sheesh it was working well a few mins ago!
Any ideas? THANKS!
post #1015 of 1298 Old 09-24-2014, 10:06 PM
Quoted: 20 Post(s)
Liked: 0
Fixed it by unplugging the SR7007 for five minutes. I guess that "rebooted" it. Anyway, it works now. Strange.
post #1016 of 1298 Old 09-25-2014, 09:39 AM
jdsmoothie's Avatar
Liked: 7488
If you want to "bi-amp" the FL/FR speakers, you can only do so using the AMP ASSIGN setting on the AVR which uses the on board amps only. It's not advised to connect the FL/FR speaker posts and an external amp to the same speaker. If you simply want to power the FL/FR speakers with the Rotel (although doing so likely won't make any difference), connect the FL/FR pre-outs to the Rotel.
post #1017 of 1298 Old 09-28-2014, 02:56 AM
robolowski's Avatar
Hi
All of a sudden i lost audio on my tv .It just happend , i have not changed any setting at all.I tried bluray and it all works.It seems like arc failed ? If i press tv audio it doesnt work .Tried to run optical cable from sr7007 to tv and it works.
I have done microprocessor reset and still no sound on tv.
I am really stuck on this one.I think its either hdmi arc on amp or tv that failed .
Or it could be something else i have missed?
Ok just tested it with other tv (arc enabled ) and it is still the same , no sound.
On the other hand i do get video so i am not sure what it is?
robolowski is offline
post #1018 of 1298 Old 10-02-2014, 09:30 PM
Quoted: 20 Post(s)
Liked: 0
Well, tomorrow is the "big day". I am driving to Los Angeles to audition speakers. I am making a USB ThumbDrive of music I like (wav files from CDs). I am dragging the files from iTunes directly onto the USB stick. When I put it into my SR7007 it sees the list of songs but when I press play I get a "file format error" and the music won't play. Do any of you have a Mac and are you able to make a USB stick that plays the music ok? If you are how are you doing it? Do you format using Disk Utility or something? Do you drag the files from iTunes right onto the USB stick?
David
post #1019 of 1298 Old 10-03-2014, 05:02 AM
jdsmoothie's Avatar
Liked: 7488
The USB stick must be formatted using either FAT16 or FAT32.
post #1020 of 1298 Old 10-03-2014, 05:04 AM
jdsmoothie's Avatar
Liked: 7488
Originally Posted by robolowski View Post
Hi
Cycle all ARC/HDMI Control settings OFF/ON on both the TV and AVR. Power both devices off. Unplug for 10 minutes. Plug back in. Power on TV. Wait 5 seconds. Power on AVR.
Marantz Sr7007 Home Theater Av Receiver
