Marantz SR7007 AV Receiver Owner's Thread - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
Old 04-16-2015, 02:32 AM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
Originally Posted by JoeNDT View Post
Bump this post forward because I’m having the same problem. Any ideas of what is wrong?
Thanks!!!!!!!!!!
Most likely your FL/FR speakers are set to LARGE so that when receiving 2CH audio from a turntable, there is no LFE signal to go to the sub as there is with multi channel audio DD/DTS 5.1. If in Manual Setup you set your FL/FR speakers to SMALL/80Hz, the sub will always be active regardless of whether playing multi channel audio or simply 2CH audio from your turntable.
jdsmoothie is offline
Old 04-16-2015, 09:32 AM
wj731's Avatar
Hi all,
For some bizarre reason my On Screen Display has decided to stop working but only when I switch to the Blu Ray input. However the screen still displays the set up page if I click this button.
I've checked the obvious human errors such as making sure the On Screen Info is switched to "On" and volume display etc.
Is there something which I'm stupidly missing?
TIA
wj731 is offline
Old 04-16-2015, 09:45 AM
jdsmoothie's Avatar
Liked: 5508
Originally Posted by wj731 View Post
Hi all,
TIA
The "Video Conversion" setting (p. 122 Owner's manual) must be ON for the Blu Ray source for the OSD/GUI to overlay on the source video.
Old 04-16-2015, 09:52 AM
Liked: 0
You received really bad advice. Audyssey works whether using the internal or external amps.
Nice so if I understand you....I do not lose one function or option of this avr by running a preout into another amp for my FR FL towers.. No matter what im doing or adjusting? sorry just want to be clear.....like I said im green as green here..
u mentioned running the towers small,...I tried that last evening..and didn't hear any difference at all whatsoever.
with my original post in mind....what galls me a lil ...is my friends store bought surround system with a tiny sub, has way more bass sound at low levels than my much more expensive system with a huge sub. Yes its not bad once your above 50 on the volume...but under that an its non exsistant.
newbiejm is offline
Old 04-16-2015, 09:54 AM
wj731's Avatar
JDSmoothie, you are worth your weight in gold! Thank you! Sincerely appreciated.
wj731 is offline
Old 04-16-2015, 09:58 AM
jdsmoothie's Avatar
Liked: 5508
1. Correct, doesn't matter if using internal or external amps .. you can run Audyssey either way. Only caveat is if you are using external amps and can't get the speaker volume setting below -12db after running Audyssey, you would have to purchase a set of -12db attenuators to connect between the AVR and external amp.
http://www.amazon.com/Harrison-Labs-.../dp/B0006N41B0
2. Denon and Marantz AVRs use a logarithmic volume scale such that you will barely hear anything below 50, rather average volume would be 50-70.
jdsmoothie's Avatar
Liked: 5508
Glad to assist.
wj731 likes this.
Old 04-16-2015, 10:09 AM
JoeNDT's Avatar
Quoted: 49 Post(s)
Liked: 44
jdsmoothie, Thank you Sir! I will do that as soon as I get back to it.
JoeNDT is offline
Old 04-16-2015, 10:25 AM
Liked: 0
hmmmm okay....well that kinda stinks.....this system is in a bar/gameroom setting....when people are there, it would be nice to listen to music at a low level and hear bass, rather than have to have the volume to the point you cant have a normal convo....maybe I went with the wrong set up and thinking then........all new to me.
THank you so much jdsmoothie...appreciate it.
newbiejm is offline
Old 04-16-2015, 11:11 AM
jdsmoothie's Avatar
Liked: 5508
You are able to raise the volume level of any speaker or sub by going to Manual Setup - Test Tones, and there you can raise the volume of the sub to suit your preference. Also if you enable Audyssey Dynamic EQ, this will boost the bass level at lower volume levels as well.
Old 04-16-2015, 11:44 AM
JoeNDT's Avatar
Quoted: 49 Post(s)
Liked: 44
I did set up FL/FR to small/80Hz when calibrating with Audyssey. Do I need to do this again in manual set up to be applicable to stereo play back?
Thanks!!
JoeNDT is offline
Old 04-16-2015, 12:09 PM
Liked: 0
Thank you.... I believe when I did the manual set up and raised the sub level...it became muddy at lower and higher volume levels though....I think? ill try again.
when u mention aud dy eq......is that the same as just running the aud option vs the manual? or is that another function. im not aware of. thanks.
also I noticed I have speaker crossover levels I can change.....what would be you recc. for this.........running 8020st def tech, Fronts...through adcom 545. with Lpf to each tower, sub2 output.
Def tech 800 pro series book shelf for surrounds
def tech 1000 center
bose reflects (series?) in rear.
cv sub, self amped... bottom fire. from AVR sub1 out put.
newbiejm is offline
Old 04-16-2015, 12:17 PM
jdsmoothie's Avatar
Liked: 5508
Thanks!!
Audyssey ignores any settings you make prior to running it. You must verify this setting AFTER running Audyssey. As long as still set to SMALL/80Hz you're good to go.
Old 04-16-2015, 12:19 PM
jdsmoothie's Avatar
Liked: 5508
After you run Audyssey, you have the option of setting Audyssey Dynamic EQ and Dynamic Volume. They are separate features from the Audyssey EQ. Speaker crossover values set < 80Hz after running Audyssey should be raised to 80Hz in Manual Setup, and any set > 80Hz should be left as is and not changed. Doesn't matter what speakers you have.
audit13 likes this.
Old 04-16-2015, 12:39 PM
Liked: 0
thank you
newbiejm is offline
Old 04-17-2015, 08:12 AM
Liked: 0
Okay to clarify...sorry im being thick here....emails are tough. After I run the audyssey...which format can I alter or change with out messing up the audyssey settings, once I run it..?.........my room has a stairwell in the middle of it...the rear bose now are at a much louder level...maybe to compensate for the staircase and or distance of the bose speakers from the rest of the sytem? and its taken volume away from the towers on the other end of the room where the tv, couch and bar is........ IF I get in there and adjust the level back up on the towers , am I defeating the entire purpose of even running the audessy?
After I ran the audyssey....then went in and put the everything to 80hz...then raised the sub level like you mentioned. Yes it made a big difference in the low volume bass situation..., and I achieved that, sound great now if you were entertaining...mission accomplished . ...but it also took a lot of the sound and or loundness away or lets say full sound ..away...once I raise the volume to high levels, say if im alone and just want to push the system to a louder level . Is there a setting I need to click back to when I just want to jam loud that would restore this. Ive learned of holding the music button on the remote and I have 4 or5 options to listen too.....before setting Audyseey...I used multi channel stereo to get the loud volume I wanted. Now that I set the audysessy, ive lost that but gained the low level bass. Seems im not getting best of both here?
newbiejm is offline
Old 04-17-2015, 08:51 AM
jdsmoothie's Avatar
Liked: 5508
You can't mess up Audyssey by making speaker/sub level volume changes, rather Audyssey is either enabled or disabled (eg. disabled when you select PURE or PURE DIRECT). Multi CH Stereo is louder because it passes the same 2CH stereo signal to all pairs of speakers and should still be available with Audyssey enabled.
Old 04-17-2015, 12:45 PM
Liked: 0
Ok well then ill adjust levels to towers then, since it doesn't interefere with audeyssy. They are barely audible now, as to before they produced a lot of sound., the bose at the other end of the room are louder than them now...... Im getting there...lol....thanks.
newbiejm is offline
Old 04-17-2015, 02:39 PM
jdsmoothie's Avatar
Liked: 5508
You may want to run Audyssey again (a few more times in fact adjusting mic height up/down a few inches from head height each time) ensuring you are using a mic boom stand or camera tripod to support the mic and focusing the last 7 mic positions within no more than 1-2' from the mic ##1 position.
Old 04-17-2015, 03:07 PM
Liked: 0
thank you!!!
newbiejm is offline
Old 04-18-2015, 07:47 AM
Liked: 0
considering the deftech towers are self amp'd and are preamped into my adcom 545. would I still run them small though?
newbiejm is offline
Old 04-18-2015, 09:01 AM
jdsmoothie's Avatar
Liked: 5508
Yup. Your dedicated sub is likely more capable than the subs in the towers.
Old 04-18-2015, 10:44 AM
Liked: 0
what is the downside or negative to running them large?
newbiejm is offline
Old 04-18-2015, 01:14 PM
jdsmoothie's Avatar
Liked: 5508
None if you prefer it that way.
Old 04-19-2015, 02:11 PM
JoeNDT's Avatar
Quoted: 49 Post(s)
Liked: 44
If I hook up an external amp from the pre out of the SR7007 said like an Emotiva XPA-5 and a subwoofer from theSR7007 output, can I still use Audyssey for room correction?
Thanks!!!
JoeNDT is offline
Old 04-19-2015, 03:36 PM
jdsmoothie's Avatar
Liked: 5508
Yes indeed. Doesn't matter if you use the internal amps or external amps.
Old 04-20-2015, 12:11 PM
Liked: 0
smoothie can I still set the levels under manual mode....on my towers that are pre amped? they show up in the speaker level screen, but I didn't know since they are being powered from the external adcom or how that effects them.
also I added a sent of def tech studio 350 to the front outputs of the Marantz....but they will not play in the multi stereo mode on the remote. only in the dmx z mode..... since im pre amping the front towers to the adcom....could I use the front output on the Marantz for the 350's to solve that issue? sorry but this avr has a lot of options....its kinda much for a newbie.
newbiejm is offline
Old 04-20-2015, 01:44 PM
jdsmoothie's Avatar
Liked: 5508
Yup. The Adcom amp would be set to roughly 80% of max (if adjustable) and any volume changes would be made via the Manual Setup on the AVR not the Adcom amp. If you connect another set of speakers to the FL/FR speaker posts ... the same volume level change would apply to both sets of speakers.
Old 04-20-2015, 02:04 PM
Liked: 0
adcom has no adjustments.................
but then would the new added speakers 350.... work on multi channel stereo setting?......,like I mentioned, they currently are hooked to front height on the Marantz and I also tried front wide......but will not play unless on certain settings on the music button options on the remote/avr. The setting that gives me personally the best volume or room filling sound for listening to music is multi channel stereo selection. but sucks the new def tech 350 wont come on.???
newbiejm is offline
Old 04-20-2015, 02:05 PM
Liked: 0
when talking to def tech...they recommened not using audussy with there 8020st since there a bi polar speaker.......I have no idea what that means.......said the speaker is too confused reacting to the aud signals.
newbiejm is offline
Marantz Sr7007 Home Theater Av Receiver
