The Official Bryston SP3 Thread. - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 48Likes
post #631 of 2150 Old 06-14-2013, 08:17 AM
CruelInventions's Avatar
Quoted: 459 Post(s)
Liked: 593
So basically what you guys are saying is, by doing nothing, gbaby is still EQ'ing his room. Unconscious EQ, really.
CruelInventions is offline
post #632 of 2150 Old 06-14-2013, 12:51 PM - Thread Starter
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
Originally Posted by Kal Rubinson View Post
Right.  That's my weekend room and, unfortunately, it is 15.5' x 16 x 8.  (My main room is much, much better.)  Literally, a half cube and I am stuck with it. ...
Nobody is saying you have to agree.
When I saw that photo of the room, I almost felt sorry for you. smile.gif I do not disagree that you need EQ. I'm just happy I don't perceive a sonic deficiency in my current set up with the SP3.
By the way my icons aren't working again or I would have given you a "wink" at the end of the last sentence in this reply.
gbaby is offline
post #633 of 2150 Old 06-14-2013, 01:00 PM
audiofan1's Avatar
Quoted: 1650 Post(s)
Liked: 1666
Wow Man! not fond of kind words? There's an old saying "If you ain't got nothing nice to say , don't say nothing at all" wink.gif
audiofan1 is online now
post #634 of 2150 Old 06-14-2013, 01:14 PM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
That's OK.  I was going to respond by enquiring whether his perceptions had been calilbrated! tongue.gif
It's all in good fun.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #635 of 2150 Old 06-14-2013, 01:32 PM
audiofan1's Avatar
Liked: 1666
post #636 of 2150 Old 06-16-2013, 12:49 PM
dminches's Avatar
Quoted: 141 Post(s)
Liked: 56
HDMI Issue with Star Trek
I went to watch the first "new" star trek blu-ray and I couldn't get sound via HDMI. I just wouldn't recognize the signal. I was able to use the 7.1 bypass but I don't know why the HDMI didn't work. I have an Oppo BDP-95 with the primary HDMI going to my projector and the secondary going to the SP3. It has worked fine with other movies. Is this an issue that occurs with certain movies or could there be another issue?
David M.
dminches is offline
post #637 of 2150 Old 06-16-2013, 01:06 PM
Roger Dressler's Avatar
Quoted: 1522 Post(s)
Liked: 710
Not just gbaby. We are all subject to the tyranny of room acoustics.
And if we branch out to more than 2 speakers, the inherently symmetrical matching we can achieve in a 2-speaker setup is much more difficult to achieve. In a surround system it is less common to use identical speakers, and even if you did, it is impossible to position them identically relative to the walls, ceiling, floor, and seats. In addition, a well treated room is not tuned to respond the same in the front L/R pair as the Ls/L pair or the Rs/Ls pair. Absorption, diffusion and reflections are not allocated uniformly around the entire room.
Based on these realities, no matter how good a surround system sounds without EQ, and it may be superb indeed, the right EQ always improves the result. Always.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #638 of 2150 Old 06-16-2013, 01:10 PM
audiofan1's Avatar
Liked: 1666
And if we branch out to more than 2 speakers, the inherently symmetrical matching we can achieve in a 2-speaker setup is much more difficult to achieve. In a surround system it is less common to use identical speakers, and even if you did, it is impossible to position them identically relative to the walls and seats. In addition, a well treated room is not tuned to respond the same in the front L/R pair as the L/Ls pair or the Ls/Rs pair. Absorption, diffusion and reflections are not allocated uniformly around the entire room.
Based on these these realities, no matter how good a surround system sounds without EQ, and it may be superb indeed, the right EQ always improves the result. Always.
post #639 of 2150 Old 06-18-2013, 01:08 PM - Thread Starter
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
In the spirit of discussion. Let's say you want to use a subwoofer to enhance your system. It's a good unit that measured flat in an outdoor test. Drop it in the room, and all of a sudden there's a strong peak at 50 Hz coloring the bass. That's an equalizer in the signal path -- the path being the room containing the woofer cone and the ears. A mechanical, acoustic equalizer.
Furthermore, room treatments and placement options cannot kill it. Turns out this resonance is easily tamed with a single band of PEQ working in mirror opposition. Many subwoofers included such a feature for just such an occasion. I submit the signal path is purer, less EQ'd, with the resonance removed than it was before.
I have to respectfully disagree with you when you say that taming a resonance with EQ makes for a purer signal path. I have owned numerous 10 and 12 band analog equalizers which I used primarily to ever so slightly boost that last octave of bass for disco music. (Don't laugh.smile.gif) In any event, while I acheived my expectation, I always felt that the over all sound was compromised by a slight decrease in imaging and all instruments having less impact or authority. When I switched out the equalizer, I have slightly less bass, but the imaging re-appeared and the instruments had a stronger, purer sound to them. Even with tone controls, when I switched out the bass and treble tone controls, I felt the sound was purer. Currently, one of my system has a Numark mixer connected to the amp (Carver 705x), and I switched the Equalizer in to increase the bass slightly for speakers that are -3db @ 42Hz. I got the desired results, but again I felt the overall sound had been compromised, and it bought on listener's fatique. I also notice that most high end pre-amps from Acoustic Research to Pass Labs do not concern themselves with EQ on their products. Its probably for the same reasons James Tanner and Bryston did not consider it in the SP3.
gbaby is offline
post #640 of 2150 Old 06-18-2013, 02:47 PM
audiofan1's Avatar
Liked: 1666
You do realize your arguments on signal purity and a self admitted taste for Mp3's on a 10K pre/pro biggrin.gif not matter how good it makes them sound negates your points on signal purity tongue.gif
post #641 of 2150 Old 06-18-2013, 03:24 PM - Thread Starter
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
You are absolutely right about your MP3 analogy. But, the fact that I can even tolerate MP3 is a testament to how good the SP3 sounds, but, if I had to bet on it I'd say its probably due to the signal coming from the clouds or streaming. Incidentally, i was a disc jockey in college and I introduced Durham, NC to disco. I'm talking the likes of Chic, AWB, Evelyn Champaine King and the like. At 58, I can appreciate those good times (no pun intended smile.gif). Additonally, I sold high end stereo, too, at Vickers Audio. It was the best job I ever had as far as enjoyment.
gbaby is offline
post #642 of 2150 Old 06-18-2013, 03:41 PM
Liked: 710
I take no issue at all with your findings. Who knows what sorts of things go on inside an analog GEQ?
But I am not talking about GEQs or tone controls or using a GEQ as a tone control. I'm talking about a single band of well implemented PEQ, precisely tuned to counteract a bass resonance. Since you have not described ever doing this, how can you argue its merits?
Let's stick to facts and not conjecture. I have plenty of my own ideas why there's no tone controls on such units, and it has nothing to do with sound quality.
post #643 of 2150 Old 06-18-2013, 05:55 PM
SoThere's Avatar
Quoted: 31 Post(s)
Gents, it seems to me that nothing is to be gained by this debate. The participants have their views and are unlikely to be persuaded otherwise. It seems to me that the main point is, if people are happy with their systems, we should be pleased for them. smile.gif
And speaking of the SP3, it seems to me that the major flaw is . . . the manual. It badly needs updating and completion, as some pages of this 2011 document are clearly drafts and some operations, such as selecting surround modes with analog inputs, remain unaddressed.
Your thoughts?
RJ
Eschew obfuscation.
SoThere is offline
post #644 of 2150 Old 06-18-2013, 07:00 PM - Thread Starter
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
Your thoughts?
RJ
RJ, you are right, but I still like entertaining the participants views as I learn a little something along the way. I personally have provoked some of debate, but at least everyone has been civil.
That the manual is flawed is an understatement. It's horrendous! But, since downloading the undated manual, I can live with it. Plus, the SP3 sounds so good I have reasoned that the engineers spent all their efforts in its design while neglecting focusing on making the manual logical. Once you get the hang of it and understand its operation, the SP3 is quite simple to use. Have all your problems, beside the manual:), been resolved? If not, what problems are you experiencing?
Robert
gbaby is offline
post #645 of 2150 Old 06-18-2013, 07:26 PM
dminches's Avatar
Quoted: 141 Post(s)
Liked: 56
So, getting back to the SP3, I finally got the HDMI audio to work. However, it required me to unplug the unit and let it sit for 5 minutes before restarting. Have others ever had this issue?
David M.
dminches is offline
post #646 of 2150 Old 06-19-2013, 07:43 AM - Thread Starter
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
I have not had this problem. Is your HDMI working consistently?
gbaby is offline
post #647 of 2150 Old 06-19-2013, 07:49 AM - Thread Starter
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
I have not had this problem. Is your HDMI working consistently now?
gbaby is offline
post #648 of 2150 Old 06-19-2013, 02:02 PM
rv1600's Avatar
Hi , im new on this forum and I buy a Bryston SP-3 2 month a go , I have a question is it posible to adjust the subwoofer crossover from the sp-3?
rv1600 is offline
post #649 of 2150 Old 06-19-2013, 06:20 PM
dminches's Avatar
Quoted: 141 Post(s)
Liked: 56
I haven't used the SP3 with HDMI audio since the weekend. I will see how it works this weekend.
David M.
dminches is offline
post #650 of 2150 Old 06-19-2013, 06:22 PM
SoThere's Avatar
Quoted: 31 Post(s)
Welcome, RV1600:
You may indeed adjust the sub crossover. See pages 34-35 of the manual. Bryston posts an online manual on their website:
http://bryston.com/pages/technical.html
Cheerio,
RJ
Eschew obfuscation.
SoThere is offline
post #651 of 2150 Old 06-20-2013, 08:21 AM - Thread Starter
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
gbaby is offline
post #652 of 2150 Old 06-25-2013, 03:13 PM - Thread Starter
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
While I enjoy mp3 through my Bryston SP3, I am now interested in raising the bar somewhat out of curiosity. I am playing my mp3s throught an Ipad 3. Can someone tell me the best way of downloading hi rez audio from HD tracks? By this I mean what program would you use to play it back. Yes, I'm late to the party, but better late than never. Thanks.redface.gif
gbaby is offline
post #653 of 2150 Old 06-25-2013, 08:23 PM
Purpleloft's Avatar
Hello,
Greetings to you all !!!
I am new here, found this designated SP3 forum by chance and i hope i can get some help from you guys. I recently upgraded my Home Theater with a Bryston SP3 (I previously had the DENON AVC-A1HDA). It was the last step in my Bryston Home Theater configuration. I run 2 28BSST's for my front speakers (B&W 801D) a 4BSST for my front speaker (B&W HTM2 Diamond) and a 9BSST to run my 4 surround speakers (B@W SCMS) and i have a Velodyne Digital Drive PLUS 18 Inch Subwoofer. I use a Panasonic PT-AE4000 projector and Van Den Hul cables for the front and Center and Supra for the surrounds .The systems rocks, but as i tried to calibrate the 7.1 setup i found the pink noise emitted from the SP3 bypasses the surround back speakers although they are activated in the speaker menu. Am i doing something wrong (i use balanced inputs on the whole configuration), has anybody had the same experience ? I would love to get your input as the provided manual is rather incomplete in that regard,...
PS : I had similar issues with the HDMI and sound inputs not being recognized...the problem all went away by clicking back and forth between the digital and the HDMI button. I mainly had the issue when switching between an analogue source and a digital one...
P
(Accidently started a new thread, sorry for that....i meant to be in th SP3 thread,...)
Purpleloft is offline
post #654 of 2150 Old 06-25-2013, 09:07 PM
Purpleloft's Avatar
Hi,
I also use my iPad to stream some of my music. I usually convert FLAC files into AAC's using VBR and a maximum quality rate of 1.00 (estimated bit rate of 425Kbps). I found this to be the best way to still have a very acceptable quality combined with the ease of use of the iPad. I know it is a compromise but it is amazing what the SP3 can do with these AAC files.
Hope this helps,...
P
post #655 of 2150 Old 06-26-2013, 01:02 PM
SoThere's Avatar
Quoted: 31 Post(s)
Congratulations, Purpleloft:
Best wishes for many happy hours of listening to your SP3. I'm sure that more than a few of us would be interested in your assessment of the audible differences between the SP3 and the Denon.
You're absolutely right: the SP3 manual is extremely disappointing and not in keeping with the quality of the product. I'm using the SP3 in a 7.2 system (also in a balanced configuration; equipment listed below) but have not experienced the test tone issue you mention. Stan Bleszynski, SP3 software designer, should be able to resolve your problem: sb@bryston.com; stanbleszynski@gmail.com; 1 (800) 632-8217. Stan is a great guy, very helpful and quite a thinker. I found that for speaker setup, my tape measure, Radio Shack analog sound level meter, and Genelec speaker angle iPhone app were very helpful.
BTW, as you'll see above, in my post #498 of 4.16.2013 (and those preceding and following), the SP3 does not do 5.1 pass-through when speaker configuration is 7.1 (or 7.2). Ideally, the rear speakers should not receive signal, directing sound to FL - C - FR - SL - SR and sub(s). As Stan notes in his reply, this was in the original software but was dropped. He states that it will be in a firmware update. If you're interested in reinstating this basic option, you may wish to email Stan to let him know if it's important to you.
Cheerio,
RJ
________________________
The means — Bryston SP3 | Bryston 6B-SST(C) - L/C/R; 4B-SST(C) - surrounds; 4B-SST(C) - rears | Bryston BDP-2 Digital Player; BDA-2 D/A Converter; Oppo BDP-105 | Paradigm Reference Signature S8 fronts; C5 center; ADP surrounds; S4 rears; two Velodyne DD15 subs | APC S20 | Pioneer Elite PRO-1130
Eschew obfuscation.
SoThere is offline
post #656 of 2150 Old 06-26-2013, 03:17 PM - Thread Starter
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
Originally Posted by Purpleloft View Post
Hello,
P
Congradulations Purpleloft. From the equipment you have and your handlle, its seems you may be Prince. biggrin.gif At any rate, now I'm jealous of both you and RJ for the caliber of equipment you own that I can't afford. smile.gif
gbaby is offline
post #657 of 2150 Old 06-26-2013, 03:45 PM - Thread Starter
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
To Purpleloft, make sure your rear speakers are set to small.
Also, I am using Cappricio app and I am trying to download Flac files with it from HD Tracks. I will look into VBR assuming its an Ipad App. I figured that I am not getting all the sound the SP3 is capable of playing listening to mp3 @ 256kps. redface.gif But it does sound good especially converted from 2.0 to 7.1 Prologic IIx music. So I can just imagine the sound with formats at a higher bit rate and frequency.
gbaby is offline
post #658 of 2150 Old 06-26-2013, 04:03 PM
SoThere's Avatar
Quoted: 31 Post(s)
Let the EQ wars resume (please, no, gents) . . . or . . . my preferences, your preferences:
You might find Scott Wilkinson's Home Theater Geeks interview with Paul Hales of Professional Home Cinema quite interesting. Mr. Hales makes very good points on the problems with auto- (and even manual) room EQ systems, noting many of the points presented by Bryston's James Tanner and others in the audio field and on this forum, notably gbaby. From my view, this is not a right v. wrong matter but an interesting and provocative argument, one in which we should respect others' choices. The podcast is available on video and MP3 (also from the iTunes Store).
http://twit.tv/show/home-theater-geeks/164
Best fishes,
RJ
gbaby likes this.
Eschew obfuscation.
SoThere is offline
post #659 of 2150 Old 06-26-2013, 04:56 PM
wse
wse's Avatar
Quoted: 1976 Post(s)
Liked: 739
As usual very eloquent Roger! Yes but one has to have the right tools and the best calibration for EQ to be worth it! I wish there was a company out here who could do that
wse is online now
post #660 of 2150 Old 06-26-2013, 06:05 PM - Thread Starter
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
Best fishes,
RJ
Thank you for your very important post. There is some magic in the sound of the SP3 and the empirical facts shown in the video demonstrate why the Bryston SP3 is the processor to beat.
gbaby is offline
Arcam , bryston sp3
