The Official Bryston SP3 Thread. - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 48Likes
Old 05-01-2014, 09:14 AM - Thread Starter
gbaby's Avatar
Quoted: 567 Post(s)
Liked: 194
Originally Posted by Roger Dressler View Post
Is there any particular reason you do not wish to reply to my question on how it informs the output sample rate? Or are you just assuming that whatever sample rate comes in is maintained to the DACs?
Roger, was your question answered?
gbaby is offline
Old 05-01-2014, 09:20 AM
Kal Rubinson's Avatar
Quoted: 690 Post(s)
Liked: 471
Originally Posted by gbaby View Post
Kal, I was shocked when you revealed that the Marantz AV-8801 has multi-channel DSD. How are they doing this? Do you think that the DSD signal is converted to PCM at some stage for bass management, delays, and distances, and the reconverted back to DSD in some output stage? The reason I ask is that DSD in multi-channel flys in the face of everything I have read about sound manipulation with DSD. I don't understand how it was accomplished.
First, there are many prepros that will do mch DSD.  However, any DSP (e.g., EQ, bass management, delays, etc.) require conversion to PCM and there's no reason to convert back before the D/A.  "Direct" may be the only way to avoid conversion.
Second, What do you mean by sound manipulation?  There is no necessity for any "manipulation" of discrete multichannel sources, DSD or PCM, other than D/A.  The exceptions are noted above.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
Old 05-01-2014, 12:32 PM
Roger Dressler's Avatar
Quoted: 1530 Post(s)
Liked: 717
Roger, now I get it. I thought I answered this in post 1237. But to be more explicit, the SP3 displays PCM input 176k 5.1 and output pass thru 5.1.
Thanks. I think you have confirmed it does not actually assert the sample rate remains at 176 kHz through to the DACs. So yes, I have my answer.
I wonder, has anyone ever made a frequency response plot of a digital sweep at ≥88.2 kHz on the SP3 to see of the audio bandwidth exceeds 22 kHz? Could also more easily be done from an analog input as long as it is in not in analog bypass mode. Just takes a few minutes.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
Old 05-01-2014, 03:06 PM
tikitom's Avatar
Originally Posted by cwt View Post
Here's a good read from James Tanner himself quoting another tikitom - makes a lot of sense to me smile.gif with an excerpt or 2
http://www.audiocircle.com/index.php?PHPSESSID=uh24a475ovbj28v8njnsc2r0e0&topic=118056.msg1280494#msg1280494
Intermodulation distortion is nasty stuff ;especially if you have ribbon tweeters that go to 40khz or so like my mains cool.gif
I will have to do some more testing this weekend but SP3 sounds wonderful no matter how it is played. I am far from being a true audiofile but I love good sound and I am trying to learn more in the audio world.
tikitom is offline
Old 05-02-2014, 05:09 AM - Thread Starter
gbaby's Avatar
Quoted: 567 Post(s)
Liked: 194
gbaby is offline
Old 05-02-2014, 05:13 AM - Thread Starter
gbaby's Avatar
Quoted: 567 Post(s)
Liked: 194
I think it does because you can set the SP3 to 176.4 pass thru.
gbaby is offline
Old 05-02-2014, 07:59 AM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
I think Roger's point was that it doesn't say so. Whether or not it does remains to be seen. Why don't you ask James Tanner? smile.gif
______________________
__________
Dave
moonhawk is offline
Old 05-02-2014, 12:29 PM
Liked: 717
I used the Bryston online inquiry form yesterday and received the following reply a few minutes ago:
This section of the SP3 manual on p14 is inaccurate and should read as follows:
High Frequency Cutoff (-3dB):
40-200Hz (variable cutoff point; default 80Hz) (SubWoofer in Analog, Digital or HDMI)
>=22kHz (all speakers, except SubWoofer, in Analog(*), Digital(**) or HDMI(**))
180 kHz (all speaker channels in BYPASS)
Footnotes:
*) Analog cutoff frequency is equal to user parameter "A/D SAMP RATE" divided by 2, that is either 24kHz, 48kHz or 96kHz.
**) Digital and HDMI cutoff frequency is the lowest of the following two values:
(1) User parameter "D/A SAMP RATE" divided by 2, that is either 24kHz, 48kHz or 96kHz.
(2) Sample rate of an input stream, divided by 2.
So that clears things up for me nicely. And great "customer" service -- a complete reply in 24 hours!
Old 05-02-2014, 12:51 PM
cwt
cwt's Avatar
Liked: 32
That's what's important tikitom ;it only has to please yourself smile.gif Someone said once that the mastering of sacds and dvd-a's gets more love because there more of a pet project for the engineers . Whether true I like the sentiment wink.gif
cwt is offline
Old 05-02-2014, 04:44 PM
tikitom's Avatar
I like that also.
tikitom is offline
Old 05-02-2014, 04:54 PM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
__________
Dave
moonhawk is offline
Old 05-07-2014, 01:57 PM - Thread Starter
gbaby's Avatar
Quoted: 567 Post(s)
Liked: 194
Tom, I remember your mentioning to me that you could not find a lot of mulit-channel SACDs for the music you enjoy. However, I would recommend that you go to Amazon and buy both SACDs by the group, Pieces of a Dream. Both SACDs can be had together for roughly $20.00, and it is in short supply. These discs tend to increase in price tremendously on the used maket so now is the time to purchase them. I would also purchase Elton John's 30th anniversary SACD, "Yellow Brick Road." It has a stellar recording and is in multi-channel, too.
gbaby is offline
Old 05-07-2014, 04:18 PM
tikitom's Avatar
Thank you for the information Robert I will have to check it out. By the way I ordered some new hdmi cables I found a gentleman that hand makes them out of Mesa Arizaona the ones I ordered are 22 guage platinum coated 99.999% pure silver solid conductor.I know and read and been told that a $5.00 hdmi is no better than a $10,000.00 hdmi cable it's snake oil.I read some reviews about this gentleman's cables and people swear they are the best in the world and made a major improvement in sound and picture and a hell of allot cheaper price than Audioquest Diamonds and Wireworlds Platinum.The best part is if they don't make a difference he will refund 100% of my money back within 60 days of home trial use.I will let you know my impression on them when I get them.
tikitom is offline
Old 05-08-2014, 05:23 AM - Thread Starter
gbaby's Avatar
Quoted: 567 Post(s)
Liked: 194
How much are you paying and for what length?
gbaby is offline
Old 05-08-2014, 04:15 PM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
Also, do you have a link to the guy's website?
__________
Dave
moonhawk is offline
Old 05-08-2014, 04:51 PM
tikitom's Avatar
Hi moonhawk,
The gentlemans name is Walter Wegrzyn located in Mesa Arizona he has been making cables for 12 years. I spoke to Walter a few times and asked questions before placing an order with him he is a very nice gentleman to talk to and very aknowlegd in audio. I just got off the phone with him again a few minutes ago and asked him about his webpage he said he hasn't had time to update his webpage and he is working on it.He also cutom hand makes speaker wires,power cords and other types of cabels. I am going to give his cables a try and if they don't perform I will send them back witin 60 days he gives for in home use.Here is his phone number if you want to give him a call ask for Walter. (480) 464-5547 here is a link to his website. http://www.wallywire.com/VideoCables.html
tikitom is offline
Old 05-08-2014, 05:16 PM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
^ thanks!!
__________
Dave
moonhawk is offline
Old 05-08-2014, 05:19 PM
tikitom's Avatar
^ thanks!!
Your welcome!
tikitom is offline
Old 05-08-2014, 05:44 PM
tikitom's Avatar
I lost more money in Las Vegas in less than an hour than I am paying for these cabels! eek.gif
tikitom is offline
Old 05-09-2014, 05:13 PM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
Kal, do you own a Bryston 9BSST2 and a Parasound Halo A31 in different systems? Seems I've read that somewhere in your posts or reviews.
Curious because I'm thinking of switching out my Halo A51 to the Bryston. I have zero complaints with the sonic qualities of the Halo, but the Bryston would match three other Bryston components, and would be slightly more compact, allowing me to do some rearranging I'd like to so. Also heat and power consumption concerns, as discussed here recently come into play, though not so much.
Just hoping you would be so kind as to give me some comparison. Hoping to hear I wouldn't be giving up much in the way of sound quality. My speakers are efficient, so I don't think power rating would be a concern, though if I go to a 7 channel system, I would add either a Bryston stereo amp or a pair of monoblocks.
I realize different systems means apples to oranges, but any general thoughts would be greatly appreciated. smile.gif
__________
Dave
moonhawk is offline
Old 05-10-2014, 09:58 AM
Quoted: 690 Post(s)
Liked: 471
Yes.  I have both but in vastly different systems in significantly different rooms and that is why I am not really able to make a useful comparison.  Also, my Bryston is not the latest version.
Kal Rubinson
Old 05-10-2014, 05:06 PM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
__________
Dave
moonhawk is offline
Old 05-10-2014, 08:18 PM - Thread Starter
gbaby's Avatar
Quoted: 567 Post(s)
Liked: 194
gbaby is offline
Old 05-10-2014, 10:25 PM - Thread Starter
gbaby's Avatar
Quoted: 567 Post(s)
Liked: 194
I have been fortunate in having amassed a huge collection of SACDs long before I could properly listen to them. One that I have heard for the first time tonight proved especially good. It was Mr. E by Pete Escovedo. It had a smooth easy sounding multi-channel sound that was clean and dynamic through the SP3. Out of print, I saw new and used ones on Amazon for 10 bucks. This will be a collector that can be had now for a bargain price.eek.gifwink.gif
gbaby is offline
Old 05-11-2014, 08:42 AM
tikitom's Avatar
This gentleman is confident in the cables he makes I spoke to him numerous times and he gives a 60 day return policy if I am not satisfied. If the cables make a 10% inprovement I will be happy because I spent a hell of allot more in the past to get a 10% improvment.
tikitom is offline
Old 05-12-2014, 09:50 AM - Thread Starter
gbaby's Avatar
Quoted: 567 Post(s)
Liked: 194
Let us know when they come in and your opinion of them on video and sound.
gbaby is offline
Old 05-12-2014, 05:25 PM
tikitom's Avatar
I will do that he is going to ship them out tomorow they are going to need a little time to break in.The reviews I read people that have his hdmi and other types of cables claim that they are the best in the world and at a fraction of the cost of other top end cables they have tried.He added the platinum coated 99.999% silver cable option about six months ago. He also makes custom XLR cables, 8 gauge speaker cables and down to 6 gauge power cords and any other kind of cables and wires that you need. he will make them in the highest grade copper or 99.999% silver or the platinum series what ever fits your needs and buget.I spoke to Walter numerous times already and he is a pleasure to work with and a very nice gentleman.by the way Robert I propably will be gettin the 8 guage pure silver or the platinum speaker cables and XLR cables from him in the future he already said that he would send me a set to try out to see if I like them. This guy is top notch and knows his stuff when it comes to cables.
tikitom is offline
Old 05-12-2014, 06:41 PM - Thread Starter
gbaby's Avatar
Quoted: 567 Post(s)
Liked: 194
Well you already know how I feel about digital cables. rolleyes.gif Now analog cables is a different story. All my analog cables are silver which I am told is the best conduit with the least resistance so go for it. cool.gif Don't spend all your money. smile.gif Buy that Pete Escovedo SACD while it's still available from Amazon, cheap. wink.gif It's that Ricky Recardo music, but it sounds damn good to me.biggrin.gif
gbaby is offline
Old 05-13-2014, 03:17 PM - Thread Starter
gbaby's Avatar
Quoted: 567 Post(s)
Liked: 194
For those who sometimes enjoy playing Apple TV through their SP3 for music, things are about to improve for us. My understanding is that in the ios 8 release, Apple will be allowing the play back of hi res music at 24 bits. This is good news to me.
gbaby is offline
Old 05-16-2014, 05:56 AM - Thread Starter
gbaby's Avatar
Quoted: 567 Post(s)
Liked: 194
Tom did you get theses cables yet?
gbaby is offline
Arcam , bryston sp3
