The Official Bryston SP3 Thread. - Page 48 - AVS Forum | Home Theater Discussions And Reviews
 48Likes
post #1411 of 2144 Old 07-24-2014, 09:52 AM - Thread Starter
gbaby's Avatar
Quoted: 557 Post(s)
Liked: 184
Originally Posted by rhale64L7 View Post
No that and my new amp should be here by next weekend. I am overly excited.
This time around I got the newer version with dsd and double dsd on it. I cant wait.
I also paid for the 4k upgrade that is coming out in advance. It has all the latest specs hdmi 2.0 hdcp 2.2. I hope I dont regret that one. But I got a great once in a lifetime deal by buying all this as a package.
Good things come to those who wait.
gbaby is offline
post #1412 of 2144 Old 07-24-2014, 09:57 AM
rhale64L7's Avatar
Quoted: 808 Post(s)
Liked: 314
Thank you. Now just have to repair the damage done by my water line leak from my fridge. Just the ceiling and bottom 1 foot of an 5 ft section of drywall. Hard part will be getting the insulation back up through the wall. Ceiling I was going to change anyhow. Just have to do it sooner now. Lol
JVC RS4810 projector Stewart Cima 115" 2.35 screen, ATI 523 and 528 amps
7 mirror imaged 2 way DIY monitors. All matched to within 1db. All parts matched, 1 SVS SB16 ultra subwoofer
Emotiva XMC-1 processor Marantz UD5007 Bluray player
Furman sequencer ran off of a double 50amp breaker,Furman power conditioner
All in a dedicated 15x22x8 foot dedicated home theater.
rhale64L7 is offline
post #1413 of 2144 Old 07-24-2014, 09:16 PM - Thread Starter
gbaby's Avatar
Quoted: 557 Post(s)
Liked: 184
Originally Posted by gbaby View Post
I write this post to corroborate information I shared previously regarding the need for an SACD player to be able to play back SACD at a sampling rate of 176/24 vs. 88/24 on the Bryston SP3.. A review of the Rolling Stones SACD, Let It Bleed, was done listening to both the 88/24 and 176/24 with the 88/24 sampling rate sounding very digital compared to the 176/24 sampling rate. You can read the review below.
http://www.theabsolutesound.com/arti...-let-it-bleed/
I must add to my own post that a glaring omission from either a processor like the SP3 or the Foundation as well as high end
SACD players is the ability to change from PCM 88.2 and 176 sampling rate. The reason this is needed is that if you have a 2 channel SACD, you cannot play it in 5.1 or 7.1 surround should you opt to do so which I always do because 176.4 in native 2 channel cannot be changed to 5 or 7.1. Only the old PS3 can change the sampling rate. A processor or SACD player should also have this capability.
gbaby is offline
post #1414 of 2144 Old 07-24-2014, 10:39 PM
CruelInventions's Avatar
Quoted: 432 Post(s)
Liked: 579
Could be an interesting experiment for you.
CruelInventions is offline
post #1415 of 2144 Old 07-25-2014, 05:27 PM - Thread Starter
gbaby's Avatar
Quoted: 557 Post(s)
Liked: 184
Originally Posted by CruelInventions View Post
Thanks for the link, but I have already done my own experiment. I have two of the same SACDs and put one in the PS3 using 88.2/24 sampling rate and the other in a Sony with a 176/24 sampling rate. I could easily detect that the 176/24 was superior in that the mid to high frequencies sounded smoother with no digital hint at all. The sound is more relaxed and borders analog to the point that I do not think that I can afford a phono pre-amp, turntable and cartride to sound as good as the 176/24 sampling rate.
gbaby is offline
post #1416 of 2144 Old 07-25-2014, 05:35 PM
rhale64L7's Avatar
Quoted: 808 Post(s)
Liked: 314
Thats my take on the hirez files also. Before them I needed analog. I couldn't stand the digital harshness. I was devastated to learn that sacd and dvd audio discs weren't going to make it. But with these new hirez files I no longer need analog.
post #1417 of 2144 Old 07-25-2014, 05:46 PM
dminches's Avatar
Quoted: 139 Post(s)
Liked: 56
That was more likely a comparison of the 2 SACD players and not the different resoluions.
What SACD did you listen to?
Did you analyze the SACD to see if there was even any information to warrant 176?
David M.
dminches is offline
post #1418 of 2144 Old 07-26-2014, 11:13 AM - Thread Starter
gbaby's Avatar
Quoted: 557 Post(s)
Liked: 184
Hello David! I do not think the two different SACD players were at play as opposed to different resolutions in that I am using HDMI on both which means I am using the D/A converter on the processor. However, the only reason I used the PS3 is that it is the only means I have to to pick 88.2 sampling rate. However, even with this, I could hear a difference on the PS3 when I selected out of curiosity 176.4 sampling rate on the PS3 and again I went back to 88.2 on it. I used seperate players just to make sure I could switch back and forth quicker. The sonic difference was obvious to me without having to strain to hear the difference. The SACDs I used were "The Bridge" by Hiroshima, and "Night Sessions" by Chris Botti. I remember that you had the Oppo SACD player, a fine unit, but you will never be able to appreciate 176.4 on it as it is incapable of playing it by design. I think you are depriving yourself of the sonic advantage of176.4, which can be heard on your resolving system, by not getting an inexpensive Sony blu-ray SACD player that can playback 176.4. I have no stock in Sony.
gbaby is offline
post #1419 of 2144 Old 07-26-2014, 11:21 AM
BigHat's Avatar
Quoted: 26 Post(s)
Liked: 29
Big Hat, I am still enjoying the SP3, but, I enjoy the music playing through it better. And, no, I have not heard anything regarding the USB card upgrade, but to be honest, I'm mostly unconcerned. The reason is that should I decide to use USB, I will get an outboard unit with a D/A converter designed for DSD. For some reason, and I may be wrong, I don't think you can have it both ways, i.e., a great PCM D/A converter and a great DSD D/A converter.
Well i guess it does depend on your approach, but the updated card is VERY important to me. I use a MacBook Pro running Amarra software into a Ayre USB DAC and then into the SP3 as analog stereo. I can only use the installed USB card for non-high res music, so I lose all multichannel and processing opportunities for a good deal of my music collection until Bryston gets off its ass and does what they said they were on the cusp of doing over a year ago.
BigHat is offline
post #1420 of 2144 Old 07-26-2014, 11:41 AM - Thread Starter
gbaby's Avatar
Quoted: 557 Post(s)
Liked: 184
I think I remember reading that Bryston went back to the drawing board on its USB port in order to accomodate DSD. In any case, it will only playback 2 channel so multichannel DSD is out the question. I'm just glad that I had purchased my hundreds of SACDs years ago even though I did not have the capability to hear them played by right unit the SP3. I have not had the need so far to use hi res downloads.
gbaby is offline
post #1421 of 2144 Old 07-26-2014, 11:46 AM
BigHat's Avatar
Quoted: 26 Post(s)
Liked: 29
Taking 2 ch and manipulating it into 5.1 with DSD is what I want. Being able to do the same thing I do now with Red Book CDs with 96/24 files from HD Tracks, etc is the aim and the USB card should do that, IF they ever update the card.
BigHat is offline
post #1422 of 2144 Old 07-26-2014, 12:20 PM
SoThere's Avatar
Quoted: 31 Post(s)
Halloo, gents:
I agree that the long-overdue card would be very useful. I use Bryston's BDP2 digital player and BDA2 DAC through the Balanced 2 input of the SP3, and the sound is fantastic in two-channel. Multi-channel would be a marvelous enhancement and, as Kal has pointed out in his writings, multi-channel hi-res files are becoming more widely available.
Otherwise, nothing to add to your discussions, which I follow regularly. I've been enjoying the SP3 greatly, most recently with the music noted below.
Cheerio,
RJ
__________________
Toasty Napa Valley
192/24 downloads
Fischer: Stravinsky - Rite of Spring/Firebird Suite
Van Morrison: Astral Weeks
Stevie Wonder: Songs in the Key of Life
Van Morrison: Moondance
96/24 downloads
Band on the Run (uncompressed)
Nickel Creek: A Dotted Line
Paul Simon: So Beautiful or So What
Santana III
Diana Krall: All for You
Mehta: Wagner - Ring cycle (Valencia) [DTS HD-MA 7.1]
Jordan: Wagner - Tannhaüser [DTS HD-MA 7.1]
Jurowski: Wagner - Meistersinger [DTS-HD MA 5.1]
Name:	Morrison Astral Weeks.jpg
ID:	181082   Click image for larger version
Name:	Morrison Moondance.jpg
ID:	181090   Click image for larger version
Name:	Wonder Songs in the Key of Life.jpg
ID:	181098   Click image for larger version
Name:	Simon So Beautiful or So What.jpg
ID:	181106   Click image for larger version
Name:	Nickel Creek Dotted Line.jpg
ID:	181122   Click image for larger version
Name:	Jordan Tannhauser.jpg
ID:	181130   Click image for larger version
Name:	Jurowski Meistersinger.jpg
ID:	181138   Click image for larger version
Name:	Fischer Stravinsky Rite of Spring.jpg
ID:	181146   Click image for larger version
Name:	Band on the Run (Uncompressed).jpg
Name:	Krall All for You.jpg
ID:	181162   Click image for larger version
Eschew obfuscation.
SoThere is offline
post #1423 of 2144 Old 07-27-2014, 05:10 PM - Thread Starter
gbaby's Avatar
Quoted: 557 Post(s)
Liked: 184
I'm not quite understanding your post. Are you saying you are taking 2 channel 96/24 files from downloads and converting them to 5.1 or are you getting 2 channel 96/24 files on CD and converting it to 5.1?
gbaby is offline
post #1424 of 2144 Old 07-27-2014, 05:13 PM - Thread Starter
gbaby's Avatar
Quoted: 557 Post(s)
Liked: 184
Originally Posted by SoThere View Post
Halloo, gents:
Cheerio,
RJ
__________________
Toasty Napa Valley
192/24 downloads
96/24 downloads
Santana III
The USB upgrade won't help you at all. You already own it.
gbaby is offline
post #1425 of 2144 Old 07-28-2014, 02:04 AM
Roger Dressler's Avatar
Quoted: 1514 Post(s)
Liked: 706
There is no update that will enable 5.1 processing of a 2-ch DSD source. It has to be converted to PCM first, so you may as well do that before handing it over to the SP-3. Amarra can do it for you.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #1426 of 2144 Old 07-28-2014, 04:31 AM
BigHat's Avatar
Quoted: 26 Post(s)
Liked: 29
I'm sure I'm responsible for the misperception. Sorry. There is no question, however, that you can take a 44/16 digital feed directly from a Mac laptop, input it to the SP3 via the USB and avail yourself of the custom SP3 Surround Modes. Yes, it's a set of simulated surround sound signals (Club, Neo 6, etc) from the original left and right 2 channel data, but you can do it. I thought it would be assumed with this crowd I was referring to matrix surround and not true 5.1. That said, it sounds pretty good. Gbaby, haven't you commented on this before and that you liked it?
My point is that the upgraded USB card is supposed to allow me to do the same with 96/24 and above music. Now I'm not saying that that is the best overall solution, but right now I have to use a USB outboard DAC (Arye) send analog 2ch into the SP3 if I want a single input that allows ALL the music on my MAC (norm and high res) available. That's the point of the upgraded card isn't it, to accept the high res input? What else would be the point?
BigHat is offline
post #1427 of 2144 Old 07-28-2014, 01:18 PM - Thread Starter
gbaby's Avatar
Quoted: 557 Post(s)
Liked: 184
.... That's the point of the upgraded card isn't it, to accept the high res input? What else would be the point?
I guess that would be the point of the upgraded USB card, high res input. Currently, I am not using USB, outboard or otherwise, for high res due to an ownership of an overwhelming amount of SACDs. I cannot justify ordering the same music on download high res sites. In fact, every high res download I've seen of music is already owned by me in SACD so does it make sense to buy it again? And you are right, at least you could convert the 2 channel USB signal to 5.1 or 7.1 DPLIIx music which to me sounds better than regular 2 channel on the SP3.
gbaby is offline
post #1428 of 2144 Old 07-28-2014, 02:44 PM
BigHat's Avatar
Quoted: 26 Post(s)
Liked: 29
Well, you're the guy that got me to try it and I agree with you so much I want to make it my default 2 ch approach. With the new card I will be able to...someday.
gbaby likes this.
BigHat is offline
post #1429 of 2144 Old 07-28-2014, 03:01 PM - Thread Starter
gbaby's Avatar
Quoted: 557 Post(s)
Liked: 184
WOW! This is the first time that you revealed you tried 2 channel to 5.1 or 7.1 DPLIIx music. I'm so hooked, that when I try to listen to 2 channel, it seems the sound stage collapes. Thanks.
gbaby is offline
post #1430 of 2144 Old 07-30-2014, 01:57 PM
BigHat's Avatar
Quoted: 26 Post(s)
Liked: 29
Yep,
I tried it and liked it a LOT! Much better simulated surround than my Lexicon MC-12 HD. Of course, it didn't take too long to launch a high-res song only to discover the USB card couldn't handle it.
BigHat is offline
post #1431 of 2144 Old 07-31-2014, 04:20 PM - Thread Starter
gbaby's Avatar
Quoted: 557 Post(s)
Liked: 184
Yep,
This is good to know, and Im glad you tried it and liked it. Now if I could only get dminiches to try it. There is something about DPLIIx music that brings out nuances in music that buried in regular 2 channel only music. As I've posted before, everyone who has heard 7.1 music and later heard the 2 channel version, demand that I put it back to 7.1. And, while I hate to admit it, Apple TV encoded with aiff sounds spectacular also in additon to being convenient as hell. Do you have Apple TV? Have you ever encoded music on it in aiff and played it back on the SP3? If you don't have Apple TV, you are missing out on a truly convenient method of playing back 2 channel music that can be encoded in minutes and played back throughout the house or wherever you have an Apple TV connected. It connects either by HDMI or optical.
Finally, what are you using for hi res playback?
gbaby is offline
post #1432 of 2144 Old 08-01-2014, 12:13 AM
Liked: 706
And, while I hate to admit it, Apple TV encoded with aiff sounds spectacular also in addition to being convenient as hell.
Why shouldn't it sound good. It's just a full bitrate WAV file with some Apple metadata like cover art. The only possible issue is that the newer generation AppleTV units sample rate convert the 44.1 kHz source to 48 kHz, whereas the original Gen1 ATV (with internal HDD) keeps them at 44.1 kHz. I even play DTS 5.1 tracks from their old CDs through it.
post #1433 of 2144 Old 08-01-2014, 05:21 AM
jima4a's Avatar
Quoted: 274 Post(s)
Liked: 146
I have a Gen 1 and while close to CD it is not quite there, whether ALAC or WAV. Someone did say the issue might be settings in ITunes or my laptop rather than the Apple TV.
PS. I felt there may be a difference so I spent part of an afternoon quite some time back trying to determine by ABing and finally found the difference in a Rusted Root song that I could clearly identify. Most of the time I could not differentiate.
jima4a is offline
post #1434 of 2144 Old 08-01-2014, 08:31 AM - Thread Starter
gbaby's Avatar
Quoted: 557 Post(s)
Liked: 184
I'm sure the conversion from 44.1kHz to 48kHz degrades the sound slightly, but fortunately for me, its not noticable. I like the idea of being able to quicky encode a song on Apple TV and play it back on every Apple TV in my house. Plus its Dolby ProLogic IIx music friendly. We owe you guys at Dolby a lot.
gbaby is offline
post #1435 of 2144 Old 08-01-2014, 09:09 AM - Thread Starter
gbaby's Avatar
Quoted: 557 Post(s)
Liked: 184
I guess you can call the Apple TV sound hi res mp3.
gbaby is offline
post #1436 of 2144 Old 08-01-2014, 11:33 AM
Liked: 706
The PCM data is bit perfect, so we can eliminate that.
iTunes has no bearing as its fingerprints from level normalization are not in effect when playing from ATV, only when iTunes is running (and then only if the options are activated). So we can eliminate that.
How do you quantify "not quite there"? Were your A/B tests blind? Double blind? I suspect not, so we cannot eliminate that.
Did the comparison use HDMI for both players? S/PDIF for both?
I find no difference, so it's been a real pleasure having instant access to my CD collection. It also affords me the opportunity to do some creative tweaking of songs that need some EQ tweaks, gain correction, even peak de-clipping on occasion.
post #1437 of 2144 Old 08-01-2014, 11:37 AM
Liked: 706
I will pass along your kind regards to Jim Fosgate when I see him next month. He is very gratified that people like his work.
post #1438 of 2144 Old 08-01-2014, 02:38 PM - Thread Starter
gbaby's Avatar
Quoted: 557 Post(s)
Liked: 184
Thanks a lot as I am sincere.
gbaby is offline
post #1439 of 2144 Old 08-02-2014, 09:42 PM
jima4a's Avatar
Quoted: 274 Post(s)
Liked: 146
Roger,
I tried to find the post where settings were suggested but no luck. Sometime in 2011 or 2012 so not likely at this point.
I used ITunes with ALAC to the Apple TV and a Denon DBP2010 for the CD, both the Apple TV and Denon were via HDMI. I was just not sure the quality was the same so one afternoon I set out to AB to determine - not blind. I think I went through quite a number of CDs not being able to tell any difference but when I got to a certain point in a Rusted Root track, the CD just had more depth. Granted in hind site, this difference could be ALAC vs WAV so perhaps I need to rip that CD into ITunes as WAV and redo it.
jima4a is offline
post #1440 of 2144 Old 08-02-2014, 11:39 PM
Liked: 706
Thanks for the reply.
ALAC means lossless. Whether it is or not, I cannot say. Assuming it is, then it will not affect the sound. But as it's only 2:1 compression, not too much point using it. And for me it would block access to editing the files.
Anyway, sounds like ATV is not impairing your enjoyment too severely.
Arcam , bryston sp3
