The Official Bryston SP3 Thread. - Page 60 - AVS | Home Theater Discussions And Reviews
 11Likes
post #1771 of 1798 Old 03-02-2015, 06:31 AM
Kal Rubinson's Avatar
Quoted: 205 Post(s)
Liked: 201
Originally Posted by mv038856 View Post
I exclusively use Velodyne Digital Drive subwoofers and they have a sophisticated equalization system integrated and come with a calibrated mic that has been optimized for low frequencies. Depending on the version of the sub (w/ or w/o plus), the test sweep tone comes from the sub itself or from a CD. On a TV screen connected to the sub or with the Plus series on a connected PC, you can see the current frequency response and make your adjustments. You immediately see the effect of your adjustments. You can not only move the bands (parametric) but you can also adjust the slope of each filter. This way you can make adjustments for smaller or wider areas.
The Digital Drive series also offers Auto-EQ, but this feature never really convinced me. And since it is so easy and convenient to do it manually, there really is no need for the Auto-EQ, IMHO.
Velodyne also offers the parametric EQ in a separate product, which is the SMS-1. I think it is in the same product category as the device that Kal mentioned.
Cheers!
Markus
Yes, they are in the same category, nominally, but I have had consistently better results from the AM Dual-Core than from the SMS-1. I agree with you about using the Velodynes in the Auto-EQ mode because it uses only the fixed default frequencies and does not take advantage of the ability to vary frequency which the manual mode permits. OTOH, the AM Dual-Core works very well in auto mode and has more controllable variables.
jffein likes this.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #1772 of 1798 Old 03-02-2015, 07:26 AM - Thread Starter
gbaby's Avatar
Quoted: 156 Post(s)
Liked: 44
Originally Posted by jdlynch View Post
What do you SP3 owners currently use to EQ your sub(s)? I don't really want to go through the learning curve of learning how to measure my room and apply filters, so, I am hoping to stay with an automatic system.
David
I do not use EQ with the Bryston SP3. I connected the Velodyhe SMS-1, but aside from the fact I may not have been using it correctly, I thought it compromised the sound in a way that I cannot articulate. Perhaps my room is sonically perfect which I sincerely doubt. But, I like the SP3 without room correction.
gbaby is online now
post #1773 of 1798 Old 03-02-2015, 01:22 PM
Nicoff's Avatar
Quoted: 48 Post(s)
I wish the SP3 had room correction. The argument against it having room correction sounds hollow to me. Let the owner engage room correction if he/she wants to, but let owners have a choice. I am sure that most folks do NOT have a perfect room.
Nicoff is offline
post #1774 of 1798 Old 03-02-2015, 06:53 PM
jdlynch's Avatar
Quoted: 33 Post(s)
Liked: 25
Thanks to all that responded regarding my question on an EQ for my subwoofer. What really has my interest at this point is using Dirac along with my laptop. I have read reviews which claim it is superior to what Audyssey does.
I guess I need to invest some time and educate myself on how to set-up a Dirac system and how to use it to EQ my sub.
Thanks again,
David
David Lynch Current Equipment: Marantz AV8801, Proceed HPA3, Parasound HCA-1206, Aerial Acoustics LR5's (LCR), Aerial Acoustics LR3's (sides), RBH in-walls (rears), Seaton Submersive, Marantz VP15s1, 106" Carada BW screen, Oppo BDP-103.
jdlynch is offline
post #1775 of 1798 Old 03-03-2015, 11:40 AM
jffein's Avatar
Originally Posted by gbaby View Post
Excuse my language, but you've got some good s__t.
Thanks. I happen to agree.
One of the reasons why I use a sub is because it is the Aerial SW-12 and is a perfect match for the 10Ts. As I pointed out before, I cross them over at a fairly high point only because they add a little bit more feel and don't degrade the sound, they blend with it. It took a long time to afford the SW-12 and I did without for many years and don't feel like I missed out on a lot without it. The 10Ts are quite strong and believable even at low frequencies. Tuning is always an ongoing process, but when you feel comfortable with it, you can toggle between full range mains and sub and it does add noticeably to the dynamics. I talked to Michael Kelly, the owner of Aerial Acoustics at length before I bought it and he is the one who originally told me to expect a bit more in the way of dynamics. I was directed to him by a dealer who claimed that Michael had an over stock of a particular finish SW-12 and would sell one to me cheap, otherwise I would never own one. I am glad to have it, it does make a difference. I find that I miss the addition of a dedicated LFE output moreso than EQ. I also have a less accurate but strong sub that I always used for LFE only. I would love to be able to configure it that way again. As it stands, I shut it off for music and power it for movies.
jffein is offline
post #1776 of 1798 Old 03-03-2015, 02:14 PM - Thread Starter
gbaby's Avatar
Quoted: 156 Post(s)
Liked: 44
Originally Posted by jffein View Post
... As it stands, I shut it off for music and power it for movies.
It took me a LONG time to get to this point, but now that I'm here, I can testify it works. So for anyone who has full range speakers, try playing music with the sub off and the fronts set to full range. You'd be surprised at how much better music sounds, and you will finally be able to fully enjoy your main speakers.
gbaby is online now
post #1777 of 1798 Old 03-09-2015, 06:14 AM - Thread Starter
gbaby's Avatar
Quoted: 156 Post(s)
Liked: 44
This weekend I was able to connect all ethernet sources, including the SP3, to my router via Cisco bridge. Now with 50mps internet service, I can control both my SP3, and BDP2 using my iPad. It is very convenient and its extremely fast. I'm a little late to this party, but I now understand how important it is to have adequate internet megabites. it makes all the difference in the world,
gbaby is online now
post #1778 of 1798 Old 03-09-2015, 06:19 AM
dminches's Avatar
Quoted: 57 Post(s)
Liked: 24
It is very convenient to be able to control the various units with an ipad. Bryston needs to work on the interface now. It is still a bit low tech.
David M.
dminches is offline
post #1779 of 1798 Old 03-09-2015, 06:36 AM - Thread Starter
gbaby's Avatar
Quoted: 156 Post(s)
Liked: 44
I thought so too prior to finding "SP3 Max." Try it as it mimics the face of the SP3.
gbaby is online now
post #1780 of 1798 Old 03-09-2015, 06:57 AM
dminches's Avatar
Quoted: 57 Post(s)
Liked: 24
What is SP3 max? I just type in the SP3's IP address and it emulates the front of the SP3. That, to me, is very low tech.
David M.
dminches is offline
post #1781 of 1798 Old 03-09-2015, 08:07 AM - Thread Starter
gbaby's Avatar
Quoted: 156 Post(s)
Liked: 44
There were tabs on the SP3 interface, and one read SP3 max, I believe. I clicked on it and it showed the front of the SP3 with blue lights and all its functions. I may have the name wrong, but I will check it and let you know.
gbaby is online now
post #1782 of 1798 Old 03-09-2015, 11:12 AM - Thread Starter
gbaby's Avatar
Quoted: 156 Post(s)
Liked: 44
David, I went home for lunch to make sure I gave you the correct info, and its just like I stated above. Check it out for yourself.
gbaby is online now
post #1783 of 1798 Old 03-10-2015, 05:51 AM - Thread Starter
gbaby's Avatar
Quoted: 156 Post(s)
Liked: 44
David, were you able to find SP3 max, yet?
gbaby is online now
post #1784 of 1798 Old 03-10-2015, 05:52 AM
dminches's Avatar
Quoted: 57 Post(s)
Liked: 24
Yes. I see that it is a prettier version of the basic screen. I will try it out tonight. Thanks for pointing that out.
David M.
dminches is offline
post #1785 of 1798 Old 03-12-2015, 02:19 PM - Thread Starter
gbaby's Avatar
Quoted: 156 Post(s)
Liked: 44
David, have you tried it yet?
gbaby is online now
post #1786 of 1798 Old 03-12-2015, 08:34 PM
dminches's Avatar
Quoted: 57 Post(s)
Liked: 24
I have and it works. Just hoping for a bit of a tech upgrade. But it is fine for now.
David M.
dminches is offline
post #1787 of 1798 Old 03-13-2015, 08:59 AM - Thread Starter
gbaby's Avatar
Quoted: 156 Post(s)
Liked: 44
gbaby is online now
post #1788 of 1798 Old 03-13-2015, 12:26 PM - Thread Starter
gbaby's Avatar
Quoted: 156 Post(s)
Liked: 44
Subwoofer With Music
Recently, I received the repaired amp for my sub from Velodyne. The sub is the Velodyne HGS-18. I was without the sub for about two weeks as it got held up in Memphis, Tennessee due to the snow. At any rate, during this two weeks period, I listened to both music and movie without the sub by making my main speakers large. I have come the the realization that for music, I need to always listen to it with the mains set to large and without the sub whether I listen in 2 channels or 7.1 channels. The bass frequencies simply sound tighter and more defined and articulated without the sub, and the speakers themselves, image better. Movies sounded better too, but I could tell that on some movies, the sub sonic bass frequencies were absent. So, for movies, I have decided that I am a victim of room modes or room nodes, whichever is the correct term for standing waves and resonances. My walls are white, and my question is, does anyone know where I can get some white bass traps for a reasonable price? I looked on Amazon, but those bass traps looked like the ones you see in radio stations which would kill my decor.
gbaby is online now
post #1789 of 1798 Old 03-21-2015, 04:55 PM
Liked: 0
It took awhile, but my system is finally up and running.
highnelly is offline
post #1790 of 1798 Old 03-21-2015, 06:36 PM - Thread Starter
gbaby's Avatar
Quoted: 156 Post(s)
Liked: 44
It looks good to me. How is your sound?
gbaby is online now
post #1791 of 1798 Old 03-22-2015, 06:10 AM
tikitom's Avatar
Hi Everybody ,Bryston has a new firmware update for the SP3. It is 2015.03b I do not know what features it added.
tikitom is offline
post #1792 of 1798 Old 03-23-2015, 06:46 AM - Thread Starter
gbaby's Avatar
Quoted: 156 Post(s)
Liked: 44
I was waiting for you to make the announcement. Welcome back Tom after your long vacation.
gbaby is online now
post #1793 of 1798 Old 03-23-2015, 12:19 PM
tikitom's Avatar
Thank you for the kind words Gbaby!
tikitom is offline
post #1794 of 1798 Old 03-29-2015, 07:23 AM
Liked: 0
sp34k audio problem
hi,i have now this pre pro decoder,i'm from italy,it's all wonderful,my set up had now a beautiful upgrade,amp chord spm3005 ,avalon radian and symbol center for the front,i have a question sometimes in random mode the PRE /PRO loses ONLY the audio of my sky decoder,which is connected with a good coaxial cable to the spdf 1 ,this is the first time that i have this problem,cause with my other two processors the sony 9000es and the chord dsp 8000 it never happened,i try to change the cable and the decoder of sky but the problem was not resolved,can anyone help me ? is there in some hidden menu' some adjustement to prevent malfuction???and another question after a half an hour the processor become very hot is it normal??
than you all...alessandro
alessandrofrignani is online now
post #1795 of 1798 Old Yesterday, 02:08 PM
Jurgen's Avatar
To answer your question about the heat:
The SP3 is supposed to get quite warm. It has no vent and the heat leaves the SP3 via its body.
Jurgen is offline
post #1796 of 1798 Old Yesterday, 04:01 PM
Liked: 0
OK very well,thanks very much............
post #1797 of 1798 Old Yesterday, 10:00 PM
Jurgen's Avatar
@ your first question
Which version of the firmware are you using?
Probably it helps to update.
Jurgen is offline
post #1798 of 1798 Unread Today, 04:50 PM
Liked: 0
hi jurgen,the version of the firmware of my sp34k is 2014.09A,having received the processor on march 6 2015,i thought and they told me infact that it could be the last uptade,i'm waiting to be contacted by the italian distributor from two weeks...anyway thanks for your support.....i read in a previous post that there's a recent firmware....i hope to resolve in some way this problem...cheers...alessandro
Arcam
