The Official Bryston SP3 Thread. - Page 74 - AVS Forum | Home Theater Discussions And Reviews
 56Likes
post #2191 of 2218 Old 08-07-2017, 08:56 AM
WillyPi's Avatar
Quoted: 20 Post(s)
Liked: 3
Best way to connect Oppo UDP-205
This is a question for those who are lucky enough to have a Bryston SP3 and an Oppo UDP-205.
What will give the best sound quality for two-channel music on CD: a digital connection between the two, so the DAC of the SP3 is used, or a balanced analog connection so the DAC in the UDP-205 is used?
WillyPi
WillyPi is offline
post #2192 of 2218 Old 08-07-2017, 10:10 AM
dbphd's Avatar
Quoted: 513 Post(s)
Liked: 187
I own both, but not in the same setup. The Bryston SP3 gets HDMI and balanced analog from an Oppo 105D, but I prefer HDMI and thus the SP3 DAC. The sound is superb. The 205 sends balanced analog to an Ayre preamp. The sound is superb, better than analog from the 105D. You can have both HDMI and analog from the 205 to the SP3, so you can switch between them from the SP3 remote. I'd try them both. You might find that you prefer analog from the 205 for stereo and HDMi from the 205 for surround. Oppo has really done some magic with analog audio from the 205. Balanced analog stereo from the 205 is very close to that from my Ayre C-5xeMP.
The reasons I don't have a 205 in both setups is that it doesn't offer streaming services like Netflix, my projector isn't 4K, I can use an Esoteric SA-60 for stereo and surround music, and it isn't available in silver. But I do have an extra slot available in my equipment cabinet . . .
db
dbphd is offline
post #2193 of 2218 Old 08-08-2017, 06:16 AM
WillyPi's Avatar
Quoted: 20 Post(s)
Liked: 3
Thank you very much for the answer.
Originally Posted by dbphd View Post
... You might find that you prefer analog from the 205 for stereo and HDMi from the 205 for surround. Oppo has really done some magic with analog audio from the 205 ...
db
This is what I am hoping for! At the moment, I have a CD player and an integrated amplifier (from Moon) for two channel music and a Blu-ray player and an AV amplifier (from Primare) for movies and multi channel music. That looks like a good solution, but there are two disadvantages: it is a bit complicated for my wife and the sound quality of multi channel is on a much lower level. So hopefully I can get excellent results for both two channel and multi channel with a first class processor like the Bryston SP3. I will have to sell my electronic gear to finance the Oppo UDP-205, Bryston SP3 and a multi channel power amplifier but I don’t want to lose too much of the quality of two channel music.
Kind regards,
WillyPi
WillyPi is offline
post #2194 of 2218 Old 08-08-2017, 09:34 AM
dbphd's Avatar
Quoted: 513 Post(s)
Liked: 187
At the moment, I have a CD player and an integrated amplifier (from Moon) for two channel music and a Blu-ray player and an AV amplifier (from Primare) for movies and multi channel music. That looks like a good solution, but there are two disadvantages: it is a bit complicated for my wife and the sound quality of multi channel is on a much lower level. So hopefully I can get excellent results for both two channel and multi channel with a first class processor like the Bryston SP3. I will have to sell my electronic gear to finance the Oppo UDP-205, Bryston SP3 and a multi channel power amplifier but I don’t want to lose too much of the quality of two channel music.i
I'm pretty sure you wont lose any quality due the Oppo UDP-205 and Bryston SP3, it will depend on the amps. You might want to consider separate amps for stereo and surround. The SP3 provides triggers for turning amps on and off, so your wife need deal only with the fully labeled SP3 remote.
db
dbphd is offline
post #2195 of 2218 Old 08-08-2017, 02:30 PM
WillyPi's Avatar
Quoted: 20 Post(s)
Liked: 3
Thank you again for your reply.
I have heard the Bryston a few times and I have no doubts about the SP3, but I can't imagine that for CDs the Oppo has a comparable sound quality as my CD player, which has a price level that is much higher. If I decide to keep my CD player, then I have less budget for the power amplifier, so no more Bryston, but an Anthem or a Primare probably.
Kind regards,
WillyPi
WillyPi is offline
post #2196 of 2218 Old 08-08-2017, 08:10 PM
dbphd's Avatar
Quoted: 513 Post(s)
Liked: 187
[QUOTE=WillyPi;54603296I can't imagine that for CDs the Oppo has a comparable sound quality as my CD player, which has a price level that is much higher.i[/QUOTE]
You should try the 205 rather than prematurely changing your plans. You can return it if it doesn't meet the sound quality you're looking for, but you might be surprised. Oppo has volume of sales to subsidize R&D and parts purchasing, whereas high price can reflect a niche market.
db
dbphd is offline
post #2197 of 2218 Old 08-09-2017, 08:00 AM
arftech's Avatar
Quoted: 194 Post(s)
Liked: 142
WillyPi
Use them balanced analog connections!
AVfile and WillyPi like this.
Oppo UDP-203, Anthem AVM50V 3D Pre-Pro, Krell KAV-500 3 Channel Amp, Adcom GFA-535 2 Channel Amp, Cary Audio 306/200 CD Player, Emotiva Stealth DC-1 DAC, Sony PHA-3 Headphone DAC/Amp, Hifiman HE-500 Headphones, Sony MDR-Z7 Headphones, Westone W50 in ear monitors, Apple PowerBeats 3, MacBook Pro-Tidal HiFi/Roon, Apple iPad Pro/Roon, Sony XBR65X930C, Sonus faber Luito Towers, Sonus faber Luito Monitors, Sonus faber Smart Center Channel, REL T2 sub, Sony SWF-BR100W Wireless Subwoofer for 930C
arftech is offline
post #2198 of 2218 Old 08-20-2017, 10:48 AM
Liked: 1
Has anyone seen this before.?
When I powered on my the SP3 this morning nothing happened and the display had a message: POWER SUPPLY OR FUSE FAILED! Does this sound like a blown fuse? If so, is replacing the fuses something I can do.
highnelly is offline
post #2199 of 2218 Old 08-21-2017, 06:11 PM
Nicoff's Avatar
Quoted: 57 Post(s)
It "sounds" broken to me. But Bryston has an excellent reputation for standing behind their products.
Nicoff is offline
post #2200 of 2218 Old 09-07-2017, 02:21 AM
WillyPi's Avatar
Quoted: 20 Post(s)
Liked: 3
WillyPi
Talking about Oppo, what would be the best connection between the UDP-203 and the SP3 for two-channel music: digital (via S/PDIF) or analogue (via RCA)?
WillyPi
WillyPi is offline
post #2201 of 2218 Old 09-07-2017, 01:04 PM
dbphd's Avatar
Quoted: 513 Post(s)
Liked: 187
Talking about Oppo, what would be the best connection between the UDP-203 and the SP3 for two-channel music: digital (via S/PDIF) or analogue (via RCA)?i
Definitely digital, with a high-quality Toslink cable, assuming the 203 has optical output, otherwise coax.
db
dbphd is offline
post #2202 of 2218 Old 09-08-2017, 12:20 AM
WillyPi's Avatar
Quoted: 20 Post(s)
Liked: 3
db
Thank you very much for your reply. So you have also experience with the Oppo BDP-203? My conclusion, based on your expertise, is that for two-channel music the Oppo BDP-205 has the best DAC, followed by the Bryston SP3 and the Oppo UDP-203 closes the row.
Kind regards,
WillyPi
WillyPi is offline
post #2203 of 2218 Old 09-08-2017, 02:59 AM
dbphd's Avatar
Quoted: 513 Post(s)
Liked: 187
I have an Oppo 105, 105D, 205, and Bryston SP3, but the 205 and SP3 are in different setups, so I've been unable to compare the two.
Whereas the 105 played nicely with DirecTV HDMI, the connection to the 205 has frequent audio drop outs and loss of audio when pausing, fast forwarding, or changing program. Reselecting HDMI input fixes the problem, but it gets annoying. I plan to reinstall the 105 and use its optical output to access the D/A processing of an Ayre QX-5 Twenty, which is likely a bit superior to the excellent DAC of the 205. And exchanging the 105 for the 205 will also restore the Berlin Philharmonic, Netflix, and Tidal services that are important to me. I'll use the 205 for 4K videos. It's connected via balanced analog to an Ayre KX-5 Twenty.
db
dbphd is offline
post #2204 of 2218 Old 09-09-2017, 10:06 AM
WillyPi's Avatar
Quoted: 20 Post(s)
Liked: 3
db
Thanks again for your reply; really appreciated. My current blu-ray player is the Primare BD32, which is also Oppo based, but with better analogue stages than the Oppo BDP-105(D). It is functioning flawlessly so after all I have learned about problems with the Oppo UDP-20X series I think I will keep my Primare. I originally intended to trade it in for a new Oppo but I have changed my mind.
Of course I have to listen for myself what the best connection will be between the Primare BD32 and the Bryston SP3 for 2-channel music, but it is a bit of a hassle to reach the electronic gear that is in my lowboard. Changing cabling afterwards is just a nightmare. It is for this reason that I am asking advice in this thread.
Kind regards,
WillyPi
WillyPi is offline
post #2205 of 2218 Old 09-09-2017, 12:41 PM
Mr.SoftDome's Avatar
Quoted: 498 Post(s)
Liked: 399
Is this unit going to get a 4K/Atmos upgrade? SP4?
Not understanding if the last page posts are fact or speculation.
Rick
Mr.SoftDome is offline
post #2206 of 2218 Old 09-09-2017, 02:58 PM
jima4a's Avatar
Quoted: 298 Post(s)
Liked: 155
Rick
Not sure about what level of 4K (HDMI version and number) but pretty sure no ATMOS. There are 4K upgrade options. I continually kick myself for not taking a deal I once had.
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is offline
post #2207 of 2218 Old 09-10-2017, 09:09 AM - Thread Starter
gbaby's Avatar
Quoted: 658 Post(s)
Liked: 265
Originally Posted by jima4a View Post
... I continually kick myself for not taking a deal I once had.
What deal is that?
gbaby is offline
post #2208 of 2218 Old 09-10-2017, 06:44 PM
jima4a's Avatar
Quoted: 298 Post(s)
Liked: 155
What deal is that?
Offer on a demo SP3, snooze and I lost.
jima4a is offline
post #2209 of 2218 Old 09-12-2017, 06:16 PM
Nicoff's Avatar
Quoted: 57 Post(s)
I read elsewhere that it is HDMI version 2.0 which cannot do HDR video.
Bottom line: No Atmos and no HDR.
Nicoff is offline
post #2210 of 2218 Old 09-18-2017, 12:01 PM
dla26's Avatar
Quoted: 118 Post(s)
Liked: 47
Since when can't HDMI 2.0 do HDR video?
I believe the issue is that HDCP 2.2 is currently only supported on one input. I've heard that Bryston is working on a solution to get HDCP 2.2 on all of the HDMI inputs.
dla26 is online now
post #2211 of 2218 Old 09-18-2017, 12:24 PM
Quoted: 498 Post(s)
Liked: 399
This is confirmed via another site. 2.0 cannot pass HDR. 2.0a or 2.0b can. Bryston has confirmed HDR so it will be a minimum of 2.0a. They have also confirmed 6 of 7 HDMI slots will be 2.2 compliant.
Rick
post #2212 of 2218 Old 09-20-2017, 03:06 AM
WillyPi's Avatar
Quoted: 20 Post(s)
Liked: 3
In another forum, I read that there are incompatibilities with Oppo (based) Blu ray players and some AV processors: a split second is shaved off from the beginning of the first track of a CD or DVD / Blu ray, sometimes even from every track. The delay is small but noticeable when the Oppo is connected with an analogue or digital S/PDIF cable and gets worse when connected with a HDMI cable.
Does those problems also occur with an Oppo Blu ray player and a Bryston SP-3?
Willy
WillyPi is offline
post #2213 of 2218 Old 09-23-2017, 12:10 PM
dminches's Avatar
Quoted: 151 Post(s)
Liked: 61
There are also incompatibilities with the SP-3 and Rokus. The SP-3 doesn't always lock onto the audio signal when a new program is started. I am forced to power down and on the SP-3 to get it to work. Very frustrating.
David M.
dminches is offline
post #2214 of 2218 Old 09-29-2017, 11:35 AM
Nicoff's Avatar
Quoted: 57 Post(s)
I have experienced this problem from time to time. Frustrating indeed. Instead of powering down, Have you tried pushing a different input button on the SP3 and then switching back to the Roku input? Switching inputs forth and back seems to do the trick for me most of the time (and it is faster).
Nicoff is offline
post #2215 of 2218 Old 09-29-2017, 12:34 PM
dminches's Avatar
Quoted: 151 Post(s)
Liked: 61
I thought I tried that and it didn't always work. Maybe I need to switch to an active input so it locks onto that signal and then relocks when I go back to the Roku.
I will try that the next time.
David M.
dminches is offline
post #2216 of 2218 Old 09-29-2017, 12:49 PM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 42
I've had to send my SP3 back to Bryston. The audio quit after trying to use headphones. I think it was the wrong type of plug. At any rate, the "Main" light lit up blue and red, and MIke Pickett at Bryston said that means it still thinks the headphones are plugged in.
A bigger problem is that I get constant spontaneous signal dropouts, caused by static electricity, light switches being switched, even in another room, etc. The video always returns, but sometimes the audio is replaced by a loud rapic ticking or drumming sound, or screeching loud static. Happens with the Dish receiver, Roku, not so much with my Oppo 103.
It's not just the Bryston causing it, because it happened the other night after I had shipped it off, but the audio came back OK---which it sometimes does with the Bryston, too.
My whole AV system is plugged int two dedicated twenty amp circuits, so I really don't know for sure what is causing it.
______________________
__________
Dave
moonhawk is offline
post #2217 of 2218 Old 09-30-2017, 05:17 AM
dminches's Avatar
Quoted: 151 Post(s)
Liked: 61
I tried doing this last night and now I remember why I started powering the unit off and on. When I just switch inputs and return to the Roku input the video is now all green. I can't get rid of it unless I cycle the power on the SP-3.
Have you ever experienced this?
David M.
dminches is offline
post #2218 of 2218 Old 10-01-2017, 11:29 AM
dbphd's Avatar
Quoted: 513 Post(s)
Liked: 187
This is likely a question for Bryston, but someone here might have tried what I want to do. I've been taking 5.1 unbalanced analog from an Esoteric SA-60 to the SP3, but the SA-60 seems to have the ability to output balanced from LR with unbalanced surround. Is there a way for the SP3 to accommodate such output?
When I tried the balanced input from the SA-60 to the SP3, the level was at least 10 dB lower. I suspect it's a menu setting problem. Finally, I was surprised the Take Five track sounded so loose with poorly controlled bass when played on an Oppo 105D with HDMI output to the SP3. I played it immediately after using the SA-60, and the sound was excellent, tight and detailed. I was surprised because Blu-rays, e.g., Legends of Jazz, sound excellent when played using the 105D.
db
dbphd is offline
Arcam , bryston sp3
