Start with One UPA-200, Get Second If Needed? - AVS Forum | Home Theater Discussions And Reviews
Old 07-21-2012, 10:48 PM - Thread Starter
knappster007's Avatar
Quoted: 14 Post(s)
I just got a Yamaha RX-A820 AV receiver (100w/ch into 2 channels). So far, very happy with the functionality, but driving my Paradigm Studio 100v4 mains it seems a little under powered. As I have been researching my options this site lead me to Emotiva as good, competitively priced amps. Cost is an issue so instead of buying the XPA-3 (200w/ch) at $629 I started thinking about the UPA-200 (125w/ch) at $314.
If a single UPA-200 wasn't enough for both speakers, I could add a second UPA-200 and then bi-amp the Studio 100s. I understand that this is passive bi-amping, but that would provide each speaker with 250 total w/ch (with some power probably wasted and not needed on the midrange/tweeter).
My center channel is powered so no amplification is needed. The third channel of the XPA-3 would be unused but left for when my Active CC center speaker dies and gets replaced.
Two questions:
1) Would a single UPA-200 be enough to sufficiently power the Paradigm Studio 100's with movies (60%) and music (40%) (living room is around 15'x18')?
2) Would the option of adding a second UPA-200 later using bi-amping be a decent way to try a single first but be able to incrementally add power if needed?
Eletronics: Yamaha 3050 RX A-3050 | Emotiva XPA-5 | Parasound Halo Integrated (2 channel integrated amp) | Auralic Aries Mini (music server)
Speakers: Paradigm Signature S6 v3 (mains) | Paradigm Signature C3 v3 (center) | Paradigm Signature S2 v3 (surrounds) | Paradigm CI Pro 65-R (Atmos ceiling)
Room Treatments: Acoustimac wall and bass traps
knappster007 is offline
Old 07-22-2012, 12:31 AM
runnin''s Avatar
Liked: 45
An 80 watt per channel amp is not going to make those Paradigms sound any better than your Yamaha.
runnin' is offline
Old 07-22-2012, 04:27 AM - Thread Starter
Quoted: 14 Post(s)
The UPA-200 is 125w/ch, not 80. The Emotiva at 125w/ch (all channels driven) delivers more than the 6 channels being driven Yamaha (whose power is rated with only 2 channels driven). http://shop.emotiva.com/collections/amplifiers/products/upa200
Comments from someone using the UPA-200 with Paradigm Studio 100's (or comparable speakers) would be welcome. If one UPA-200 can do the job, then great. I'm just considering the possibility of first buying one, and if that doesn't cut it, adding a second and bi-amping as an upgrade path that smooths cash flow.
Old 07-22-2012, 06:04 AM
jdsmoothie's Avatar
Quoted: 12103 Post(s)
Liked: 5508
1. If the Yamaha volume is currently maxed out and you're hearing distortion, then adding the UPA-200 would help.
2. Adding a 2nd amp does not 2x the power, rather simply would provide 125W to each set of speaker posts.
jdsmoothie is offline
Old 07-22-2012, 10:13 AM
runnin''s Avatar
Liked: 45
Pardon me, I got my amps mixed up!
runnin' is offline
