Dead AVR254 - Please recommend a replacement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-21-2012, 11:39 PM - Thread Starter
dplant's Avatar
Well, after about three years of problem after problem it looks like my Harmon Kardon is done. Can you guys recommend a replacement that would run around $350.00 or so? I was thinking maybe an Onkyo, Denon or Yamaha and was hoping to get something with comparable features but without all the problems!
Thanx for any help
dplant is offline
post #2 of 6 Old 07-22-2012, 06:22 AM
Tweaked05's Avatar
Quoted: 41 Post(s)
Liked: 26
Tweaked05 is offline
post #3 of 6 Old 07-22-2012, 09:34 AM
jdsmoothie's Avatar
Quoted: 12100 Post(s)
Liked: 5507
You should be able to pick up one of last year's models on clearance for under your budget. Check with your local Best Buy stores for a demo.
jdsmoothie is offline
post #4 of 6 Old 09-10-2012, 11:04 AM
glazer1972's Avatar
I'm in the same boat. I have a found a Yamaha RX-V571BL Open Box (missing the remote and the YPAO setup mic) for $199.99 plus tax. Thinking of getting it since I have a Harmony One Remote and can borrow the YPAO setup mic from my brother.
glazer1972 is offline
post #5 of 6 Old 09-10-2012, 11:25 AM
jdsmoothie's Avatar
Liked: 5507
An "open box" unit should still come with the mfr's full warranty making it a good buy as well. smile.gif
post #6 of 6 Old 09-10-2012, 12:27 PM
glazer1972's Avatar
I should probably have mentioned that I think the open box might actually be missing the box too. eek.gif
