NEW SONY STRDN1030 RECEIVER - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #151 of 234 Old 05-23-2013, 09:19 PM
jhowe204's Avatar
I meant to quote the guy who got it for $330.
jhowe204 is offline
post #152 of 234 Old 05-25-2013, 12:46 AM
2685Danny's Avatar
Repeated post
2685Danny is offline
post #153 of 234 Old 05-25-2013, 12:48 AM
2685Danny's Avatar
Posted twice
post #154 of 234 Old 05-31-2013, 12:29 PM
eah9's Avatar
Liked: 29
Originally Posted by eah9 View Post
I called Sony support trying to find out about the setup 3/4.2 - which doesn't seem to exist and could not get an answer. And I can't seem to get pre-out 2 to work. I did the normal trouble-shooting and determined the subs are both fine, the wires are both fine, but nothing out of pre-out 2 during the test tones. Haven't had a chance to stick my ear to the second subwoofer while playing a movie or test file yet. That will be the next step tonight maybe. Anyone had any luck with pre-out 2 during test tones or see the .2 in their setup menu. I updated the firmware a few months ago but need to check to see if there has been an update since.
Thanks. By the way - after 4-5 months of owning, I am really happy with the sound coming out of this receiver. Full and balanced. Hopefully even better with the second subwoofer.
So I figured out my issue with the pre-out 2. The tiny switch on the back of my sub got bumped from the auto to the off. I thought I had it moved it to the on postiion. Oh well...eek.gif
Anyway - even though the setup still only shows 3/4.1 it actually tests and calibrates with both subs. This is a fantastic receiver for the money. No " real" issues and the sound quality is just amazing. I really don't see the need to go to a theater anymore with the full rich sound. I got kind of lucky because I had only read a few reviews but had to get a new receiver for the SB, as my old one died a few days before. This was prior to joining AVS too, so i got really lucky. This receiver was definitely a great choice for me. So much detail and balance. So many other receivers even at a higher price point seem to have issues. I almost got talked into getting a receiver with audyssey xt32 which would be great, but I am just so satisfied with this receiver I just don't see the need.
Energy RC70 L/R | RC-LCR Center | C-R3 Surrounds | VMINI Bookshelves Surrounds | S12.3 and Dual S10.3 Subs | KRK 10s Sub | Benq w1070 pj | Elite 100" Sable Screen | SONY STR-DN1030| Sony S5100 and S3100 BDPs
eah9 is offline
post #155 of 234 Old 06-25-2013, 04:44 PM
dspblues's Avatar
Has anyone had issues with AirPlay working? It looks like it's playing the audio, but no sound. I appologize if this is somewhere in this thread already.
dspblues is offline
post #156 of 234 Old 06-25-2013, 04:50 PM
bareyb's Avatar
Seems to me I have had that happen too... Have you tried rebooting the device and Receiver? That solves a host of ills.
Obsessed is such an ugly word... We like to think of ourselves as extremely focused.
bareyb is offline
post #157 of 234 Old 06-25-2013, 05:55 PM
dspblues's Avatar
I've tried uplugged the receiver. Also, this experience happens on multiple iphone devices. Not just one. The same iphone can stream to my Denon with no issues.
dspblues is offline
post #158 of 234 Old 06-25-2013, 07:30 PM
dspblues's Avatar
I fixed it... I had to change the speaker options to get it to work. It was the "multi" something setting.
dspblues is offline
post #159 of 234 Old 07-31-2013, 08:17 AM
Drlink's Avatar
Quoted: 45 Post(s)
Liked: 55
Do any of you folks have a 7.1 system and use a PS3 for Bluray and gaming on your 1030? If so I'm trying to optimize the audio I'm getting from my 1030, 7.1 sorround speakers and PS3.
My understanding is that I'm supposed to set the PS3 to output bitstream over HDMI, and then to set the PS3 to output 7.1 with 48kHz max as the receiver manual says that several "measurement" functions don't work if the sampling frequency is above 48kHz.
Am I right so far...is there anything I'm missing? Any other settings that I should be using?
PN64F8500 & TH-42PX60U
STR-DN1030
Infinity Modulus 7.1
PS4, PS3, TiVo Roamio OTA (Lifetime), Roku 3 & Chromecast
Harmony 900 & 1X2 Monoprice PRO Series Powered HDMI Splitter
PSN ID: Kranin
Drlink is offline
post #160 of 234 Old 07-31-2013, 08:50 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Which type of PS3 do you have? Fat or slim. It
matters with Blu-ray playback.
Bitstream and 7.1 are two different settings. Bitstream means the player will send the encoded audio file with however many channels are in the mix, anywhere from mono to 7.1. As most sources are not 7.1, you need to apply a surround mode such as PLIIx in your receiver to expand 5.1 to 7.1. There is also very little content with sampling rates higher than 48kHz.
Drlink likes this.
BIslander is offline
post #161 of 234 Old 07-31-2013, 12:11 PM
Drlink's Avatar
Quoted: 45 Post(s)
Liked: 55
I have a slim.
I initially thought "Gee...it will be so easy to set up the PS3 with the 1030 because they are both Sony products!" Oh well... cool.gif
Thanks for your help!
STR-DN1030
PSN ID: Kranin
Drlink is offline
post #162 of 234 Old 08-05-2013, 01:59 AM
nflguy's Avatar
I just bought this from Costco and I'm already having HDMI issues. It struggles with 1080p
nflguy is offline
post #163 of 234 Old 08-05-2013, 09:51 AM
eah9's Avatar
Liked: 29
What specifically are you having issues with? This unit is not known for having hdmi issues that I am aware of. I have 3 hdmi connections and have no issues at all. In fact, I use blu-ray with lossless master-hd audio.
What hdmi cable are you using and from what device to the 1030? 1.3 cable or above should not have any issues. I had an older blu-ray player that was the cause of some skipping but it was not this avr causing the problem.
eah9 is offline
post #164 of 234 Old 08-05-2013, 11:01 AM
nflguy's Avatar
The HDMI that connects from the 1030 to the projector (30ft ultra slim redmere from monoprice) would only display 1080i, and 720p. It was replaced with an "ultra" 25ft HDMI cable my installer picked up. It displays 1080p but the cable can't be plugged in all the way at the Avr otherwise if its plugged in tight the picture is snowy/distorted and the image and audio blink on and off.
It's a brand new Sony bluray player I picked up at Costco a few weeks ago.
I have the same AVR in the livingroom connected with an older HDMI cable. The picture is fine when watching 1080p but the audio is out if synch. Install thinks new HDMI will fix.
nflguy is offline
post #165 of 234 Old 08-05-2013, 11:11 AM
eah9's Avatar
Liked: 29
Ok - good luck. Strange....have you tried a different hdmi slot? Also - make sure you have the latest firmware for the avr and not sure if you can do that for the projector also.
I have the new sony s3100 and send it to the str-dn1030 hdmi. There is an option on my blu-ray to change the timing with any sync issues. Works great.
Since you have 2 of the same str-dn1030's, have you tried swapping the unit from your living room? If the same problem occurs with the living room avr (which you know works), you will then know it's not the avr but the cable or possibly the projector.
If the problem is solved by this - you will know it's the hdmi on the first avr.
eah9 is offline
post #166 of 234 Old 08-05-2013, 01:38 PM
nflguy's Avatar
the 30ft cable that didn't work in the media room (with avr and projector) worked just fine when i connected a bluray player directly to our bedroom hdtv using that cable. I have not updated the software for either avr. Not having the update could cause these issues?
nflguy is offline
post #167 of 234 Old 08-05-2013, 01:53 PM
eah9's Avatar
Liked: 29
It's always good to update the firmware (well almost always).
So - it's not the cable. down to 2 things - projector or avr. If you swap the avr's that will give you the answer you are looking for....hopefully.
eah9 is offline
post #168 of 234 Old 08-05-2013, 02:19 PM
nflguy's Avatar
Here is what I'm thinking of doing:
The bluray player i connected to bedroom tv that worked fine with the 30ft redmere hdmi. Plug that player directly to projector using same 30 ft cable and see if any issues. If it has picture problems then i will know it's the projector. If not then it's the AVR.
nflguy is offline
post #169 of 234 Old 08-05-2013, 02:26 PM
eah9's Avatar
Liked: 29
Good plan - easier than switching the avrs. Let me know how it works out! I have not heard heard of any hdmi issues with this avr. I really think I made the right choice- the sound coming out of it with my energy speakers is so good. I have owned it for about 8 months now and have 0 issues.
If it works with the blu-ray, you might still want to try the other avr to make sure it's not an issue with the handshake between the projector and avr. That would also let you know if the one avr is truly faulty (which it could be).
eah9 is offline
post #170 of 234 Old 08-10-2013, 08:20 AM
cheneyp's Avatar
Hi all - I've had this receiver for about 10 months and yesterday it started providing only intermittent audio output from the HDMI Out. No video at all. I originally thought it was my TiVo as that was the source it was watching but i noticed it on my bluray output as well. I bypassed the AVR and connected both components directly to the TV and no problems; got video and sound (from the TV only, of course, after I switched to TV speakers only on my TV setup). Any ideas?
cheneyp is offline
post #171 of 234 Old 08-10-2013, 08:42 AM
eah9's Avatar
Liked: 29
assuming you used the same hdmi cable for all tests. if not that could be the culprit.
otherwise try a different hdmi port.
reset the avr.
firmware update.
I have had my avr about the same timeframe. hope this isn't an hdmi board issue. good luck.
eah9 is offline
post #172 of 234 Old 08-10-2013, 11:03 AM
cheneyp's Avatar
reset the avr.
firmware update.
Thanks for the feedback. Yes, I used the same HDMI cables and they worked with the direct connect method. I have pulled the power cord to "reset" it but is there a different reset method? I can also look into the firmware update. Don't believe I have done this since I got the AVR. I have not tried other HDMI inputs on the AVR but I am not hopeful since both the DVR and Bluray inputs have the issue.
cheneyp is offline
post #173 of 234 Old 08-10-2013, 12:16 PM
eah9's Avatar
Liked: 29
to reset hold the power button down for a few seconds. you will have to recalibrate and redo all your settings.
it wouldn't hurt to update the firmware.
eah9 is offline
post #174 of 234 Old 08-16-2013, 08:28 PM
cheneyp's Avatar
Did a whole lot of troubleshooting and finally picked up another one from Costco and it worked fine, so the other one is going back....
cheneyp is offline
post #175 of 234 Old 08-16-2013, 08:50 PM
eah9's Avatar
Liked: 29
Glad you got a good one. Hopefully no issues at all. It's a great avr IMHO.
eah9 is offline
post #176 of 234 Old 08-18-2013, 08:26 AM
cheneyp's Avatar
Thanks. I have noticed that the new one takes a bit longer to switch inputs than the first one. May be a firmware thing; not sure. I will check for the latest firmware - I could not figure out how to do it with the old one since i could not see anything on the TV screen with the problem I had.
cheneyp is offline
post #177 of 234 Old 08-20-2013, 08:49 PM
nflguy's Avatar
I noticed recently that sometimes the dialogue seem doesn't seem loud enough to me. But everything else (sound effects etc) are plenty loud. Could this be an issue with the AVR?
nflguy is offline
post #178 of 234 Old 08-20-2013, 08:53 PM
afrogt's Avatar
Quoted: 1062 Post(s)
Liked: 767
Could be the source material. You can always adjust the channel level for the center speaker.
Afro GT
afrogt is offline
post #179 of 234 Old 08-21-2013, 08:40 AM
eah9's Avatar
Liked: 29
Run the test tones and see if they sound similar in volume - that might isolate the problem to content if they are the same (like afrogt mentioned). Re-run the calibration if necessary in a completely quiet environment.
I bumped my center up 2db on mine after calibration to my liking for movie dialogue.
eah9 is offline
post #180 of 234 Old 08-26-2013, 01:13 PM
Mademedia's Avatar
I too bump my center up about 2db for better dialog.
Side note: I notice that Netflix and some of the streaming services can get wonky on their encoding/decoding of audio. Orange is the New Black was coming out of the right side of my system when 5.1 plus was selected thru their service. I had to select stereo for the audio on every episode. frown.gif
I'd play around with the auto volume feature... it's towards the bottom of the remote. It seems to help with quiet dialog. Best of luck!
Mademedia is offline
Sony Strdn1030 Receiver
