Onkyo 818 6ohm /8ohm question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-24-2012, 12:22 PM - Thread Starter
jjpt4540's Avatar
I just picked up the Onkyo TX-NR818. Would it be a problem to run 8ohm front and 6ohm center/rear speakers? I'm a complete novice and have no clue.
Thanks in advance.
jjpt4540 is offline
post #2 of 5 Old 07-24-2012, 12:47 PM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
It won't be a problem. There are a lot of people doing what you describe and don't even know it.
jjpt4540 likes this.
KidHorn is offline
post #3 of 5 Old 07-24-2012, 12:53 PM - Thread Starter
jjpt4540's Avatar
Thanks I wans't sure and heard I could trigger the auto shutdown if the receiver runs to hot.
jjpt4540 is offline
post #4 of 5 Old 07-24-2012, 05:23 PM
AndrewS99's Avatar
The 6ohm/8ohm mode is confusing on onkyos. Basically if you set it for 6ohm, it reduces the amplifier power and handicaps your receiver so it won't overheat with a 6 or 4 ohm load.
From a while back I have read that you basically always want to run it in 8 ohm mode to get full amp power. Put a fan on top to cool it down. If the onkyo you have can't handle the 4 ohm load in 8 ohm mode then you probably need a different/more powerful amp.
I have been running 4 ohm speakers Axiom M80ti (very easy 4ohm load) on my TX-NR876 and now TX-NR818 with both of them set for 8 ohm. Never had the receiver shut off or overheat. Always had a 120mm fan on top in the back blowing up.
AndrewS99 is offline
post #5 of 5 Old 07-25-2012, 06:05 AM
KidHorn's Avatar
Liked: 877
I wouldn't bother with a fan. Onkyo's run hot but are designed to be cooled via natural convection. As long as you have a couple of inches on the top and at least an inch on each side, you'll be OK. Receivers don't run hotter powering 6 ohms over 8. At least not a noticeable amount. The heat produced per decibal is more influenced by speaker sensitivity than impedance.
KidHorn is offline
