Getting a green screen when trying to watch 5.1 channel movies through Amazon on Roku 2 XS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-24-2012, 05:25 PM - Thread Starter
seandudley's Avatar
Hello everyone,
I'm hoping someone here might have some idea what is going wrong with my setup. I have a Roku 2 XS with Amazon Streaming (and Netflix, Hulu, etc). I have the Roku 2 XS going into an HDMI input on my Denon AVR-1913 A/V receiver. Everything works great, except that if I try to watch a 5.1 channel movie, the screen immediately goes to a strong green look. It apppears to me that I am losing all of my blues. What I have determined is that if I set the audio on the Roku to 5.1 channel, and go through the receiver, and try to watch a 5.1 channel movie this happens. If I go from the Roku 2 straight to the TV, the video is fine, but of course I don't get the 5.1 channel audio that way. If I turn off 5.1 channel output on the Roku, everything is fine. If I try to watch a 5.1 channel movie on anything except for Amazon, it works fine. I already tried swapping the Roku 2 XS out, which didn't help. I have tried swapping HDMI cables and inputs on the receiver, and it makes no difference. Once the green screen thing happens, it stays that way, even if I switch to Netflix or something else, until I go to video settings on the Roku and switch it from 1080P to 720P (and then I switch it back to 1080P), or reboot the Roku. If I disconnect the HDMI cable while the movie is running and put it back, it remains green. If I stop the movie, and then disconnect and reconnect the HDMI cable, it goes back to regular colors.
Any ideas what the problem might be? I'd really like to be able to have the 5.1 channel audio on the Amazon movies without the screen being green.
Sean Dudley
seandudley is offline
post #2 of 7 Old 07-24-2012, 05:32 PM - Thread Starter
seandudley's Avatar
Intersting.. just tried hooking up a 1st generation Roku up, and it works perfectly.. seems to be just a problem on the Roku 2 XS.
post #3 of 7 Old 07-24-2012, 05:42 PM
jdsmoothie's Avatar
Quoted: 12110 Post(s)
Liked: 5514
Seems to be an HDMI handshake issue with the Roku 2 XS. You can try the HDMI HDCP reset procedures listed below.
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100#user_L11
Also for more info on your 1913, join us in the Denon AVR-XX13 Owner's thread linked in my sig as well as reviewing the FAQ/Setup Guide.
jdsmoothie is online now
post #4 of 7 Old 07-25-2012, 09:19 AM - Thread Starter
seandudley's Avatar
Thanks for the suggestion.. Tried these steps, but it didn't help. I don't think it is a handshake issue since it only happens with Amazon streaming through the Roku and not other sources like Netflix or Hulu, and only with 5.1 channel audio programs with 5.1 channel audio enabled in the Roku 2. I would be interested to know if anyone has the Roku 2 set to 5.1 channel audio, is outputting through a Denon 1913 receiver and is streaming 5.1 channel content from Amazon successfully. Roku said they are elevating this situation to an advanced tech and hopefully they will do some testing and duplicate and fix it.. fingers crossed.
Sean
post #5 of 7 Old 08-07-2012, 08:01 AM
Answer Seeking / Sharing
cavchameleon's Avatar
Quoted: 194 Post(s)
Liked: 219
Hi Sean,
Any updates from Roku? Strange you have that issue. We have 5 of these units (Roku2 XS) and have no problem streaming from Amazon: HD with 5.1. 4 of the units are connected to Denon AVR's (not your particular model) and have no issues.
Ray
Ray
"Listen with an open heart and mind."
cavchameleon is offline
post #6 of 7 Old 08-07-2012, 08:13 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
Chances are your Roku is defective.
They should send you a new unit.
Have you tried rebooting your router?
commsysman is offline
post #7 of 7 Old 08-14-2012, 11:56 AM
JBWIII's Avatar
Liked: 43
Have you tried a different HDMI cable? Seems silly, but I've read other posts discussing similar issues and they claim that it fixed the problem.
JBWIII is offline
